[STM32F1] 兰峰控制xc1004四轴SPI运动控制芯片直线圆弧插补代码,STM32单片机各个型号都可简单的....
538|0
 楼主| ww75815895 发表于 2023-2-2 14:57 | 显示全部楼层 |阅读模式
#include <intrins.h>
#include <reg52.h>
//MCU: stc8f2k08s2
sfr P0M1 = 0x93;
sfr P0M0 = 0x94;
sfr P1M1 = 0x91;
sfr P1M0 = 0x92;
sfr P2M1 = 0x95;
sfr P2M0 = 0x96;
sfr P3M1 = 0xb1;
sfr P3M0 = 0xb2;
sfr P4M1 = 0xb3;
sfr P4M0 = 0xb4;
sfr P5M1 = 0xC9;
sfr P5M0 = 0xCA;
sfr P6M1 = 0xCB;
sfr P6M0 = 0xCC;
sfr P7M1 = 0xE1;
sfr P7M0 = 0xE2;
sfr P5 = 0xC8;
sfr     SPSTAT      =   0xcd;
sfr     SPCTL       =   0xce;
sfr     SPDAT       =   0xcf;
sfr     IE2         =   0xaf;
sfr     AUXR        =   0x8e;
sfr     T2H         =   0xd6;
sfr     T2L         =   0xd7;
sfr     P_SW2       =   0xba;
#define CKSEL           (*(unsigned char volatile xdata *)0xfe00)
#define CKDIV           (*(unsigned char volatile xdata *)0xfe01)
#define IRC24MCR        (*(unsigned char volatile xdata *)0xfe02)
#define XOSCCR          (*(unsigned char volatile xdata *)0xfe03)
#define IRC32KCR        (*(unsigned char volatile xdata *)0xfe04)
//#define FOSC            16000000UL                        //使用外部16M晶振
#define FOSC            24000000UL                        //使用内部24M晶振
#define BRT             (65536 - FOSC / 115200 / 4)                   //定义115200波特率
sbit b2        =        P1^1;
sbit b1        =        P5^5;
sbit led        =        P3^5;
sbit cs3         = P3^3;
sbit cs2         = P3^2;
sbit cs1         = P1^2;
sbit sck = P1^5;
sbit in         = P1^4;
sbit out = P1^3;
#define SPI3_CSHIGH cs3=1 // CS3
#define SPI3_CSLOW         cs3=0
#define SPI2_CSHIGH cs2=1 // CS2
#define SPI2_CSLOW         cs2=0
#define SPI1_CSHIGH cs1=1 // CS1
#define SPI1_CSLOW         cs1=0
#define SPI_SCKHIGH sck=1 //SCK
#define SPI_SCKLOW sck=0
#define SPI_OUTHIGH out=1
#define SPI_OUTLOW  out=0//MOSI
#define SPI_IN in//MISO
unsigned char  inbuf[50] = {0};
unsigned char b1_state=0;
long sxnum;
void initial()
P1M1 =          0;
P1M0 =        0x2c;                    // 引脚模拟通信时,MOSI,SCK, CS        设为推挽输出
SPI1_CSHIGH;                 //CS不使用时设为高
SPI2_CSHIGH;
SPI3_CSHIGH;
SPI_SCKLOW;//SCK空闲状态一定要为低电平。
/////// spi模拟通信时不用
SPCTL = 0xd0;                               //使能SPI主机模式
SPSTAT = 0xc0;                              //清中断标志
void init_uart()
   SCON = 0x50;
    T2L = BRT;
    T2H = BRT >> 8;
    AUXR = 0x15;
串口发送一个字节。
void USART_Txbyte(unsigned char i)
    SBUF   =   i;
    while(TI ==0);
    TI     =   0;
串口发送一串数据。
void USRAT_transmit(unsigned char *fdata,unsigned char len)
   unsigned char i;
   for(i=0;i<len;i++)
      USART_Txbyte(fdata[i]);
void delay_nus(unsigned long n)
       unsigned long j;
       while(n--)
              j=1;
            while(j--);
//延时n ms
void delay_nms(unsigned long n)
       while(n--)
          delay_nus(1000);
函数名:   SPI_SendData
功能:软件模拟SPI通讯发送并接收一个8位字节数据。
如需使用硬件SPI,单片机作为主机,运动控制芯片为从机。CPHA=0,CPOL=0,高位在前,SPI数据宽度为8位。
空闲状态下单片机SCK引脚必须为低电平。每一条指令开始发送前将CS引脚置低,整条指令发送完成后必须将CS置高。
每条指令间需有时间间隔,推荐延时1MS以上。
unsigned char aSPI_SendData(unsigned char outdata)
unsigned char RecevieData=0,i;
SPI_SCKLOW;
//        _nop_(); _nop_(); _nop_();_nop_();        _nop_();_nop_(); _nop_(); _nop_(); _nop_(); _nop_();_nop_(); _nop_(); _nop_(); _nop_(); _nop_();
for(i=0;i<8;i++)
SPI_SCKLOW;
if(outdata&0x80)
   SPI_OUTHIGH;
else
  SPI_OUTLOW;
outdata<<=1;
SPI_SCKHIGH; //
  RecevieData <<= 1;
if(SPI_IN)
    RecevieData |= 1;
  SPI_SCKLOW;
  delay_nus(1);                  //发一个字节延时下
return RecevieData;
unsigned char SPI_SendData(unsigned char outdata)
SPDAT =  outdata;                           //发送数据
  while (!(SPSTAT & 0x80));               //查询完成标志
return SPDAT;
函数名:  enabled_cs
功能:SPI运动控制模块使能对应芯片模块的CS脚
参数:
cardno        卡号
用单片机不同引脚去控制不同芯片的CS脚,以便多个芯片模块关联使用。
void enabled_cs(unsigned char cardno)
if(cardno==1)
SPI1_CSLOW;
if(cardno==2)
SPI2_CSLOW;
if(cardno==3)
SPI3_CSLOW;
函数名:  disabled_cs
功能:SPI运动控制模块禁止对应芯片模块的CS脚
参数:
cardno        卡号
用单片机不同引脚去控制不同芯片的CS脚,以便多个芯片关联使用。
void disabled_cs(unsigned char cardno)
if(cardno==1)
SPI1_CSHIGH;
if(cardno==2)
SPI2_CSHIGH;
if(cardno==3)
SPI3_CSHIGH;
函数名:  set_speed
功能:设置轴速度
参数:
cardno        卡号
axis        轴号(1,2,3,4)
acc        加速度: 值(Hz/s2)
speed      运行频率为:值(Hz)
dec           减速度: 值(Hz/s2)
void set_speed(unsigned char cardno ,unsigned char axis ,unsigned long acc ,unsigned long speed,unsigned long dec )
unsigned char OutByte[25];
OutByte[0] = 1;                // 1
OutByte[1] = 0;
OutByte[2] = axis;
OutByte[3] = acc >>24;
OutByte[4] = acc >>16;
OutByte[5] = acc >>8;
OutByte[6] = acc ;
OutByte[7] = speed >>24;
OutByte[8] = speed >>16;
OutByte[9] = speed >>8;
OutByte[10] = speed ;
OutByte[11] = dec >>24;
OutByte[12] = dec >>16;
OutByte[13] = dec >>8;
OutByte[14] = dec ;
enabled_cs(cardno);
SPI_SendData(OutByte[0]);
SPI_SendData(OutByte[1]);
SPI_SendData(OutByte[2]);
SPI_SendData(OutByte[3]);
SPI_SendData(OutByte[4]);
SPI_SendData(OutByte[5]);
SPI_SendData(OutByte[6]);
SPI_SendData(OutByte[7]);
SPI_SendData(OutByte[8]);
SPI_SendData(OutByte[9]);
SPI_SendData(OutByte[10]);
SPI_SendData(OutByte[11]);
SPI_SendData(OutByte[12]);
SPI_SendData(OutByte[13]);
SPI_SendData(OutByte[14]);
disabled_cs(cardno);
delay_nms(1);
函数名:        change_speed
功能: 改变当前正在运行的轴的速度
参数:
cardno        卡号
axis        轴号(1,2,3,4)
speed 运行频率为:值(Hz)
void change_speed(unsigned char cardno ,unsigned char axis, long speed )
OutByte[0] = 0x11 ;
OutByte[1] = 0 ;
OutByte[2] = axis ;
OutByte[3] = speed >>24;
OutByte[4] = speed >>16;
OutByte[5] = speed >>8;
OutByte[6] = speed ;
enabled_cs(cardno);
delay_nms(1);
函数名:        set_command_pos
功能: 设置轴逻辑位置
参数:
cardno        卡号
axis        轴号(1,2,3,4)
pulse         位置脉冲数,范围(-268435455~+268435455)
void set_command_pos(unsigned char cardno ,unsigned char axis, long value )
OutByte[0] = 0x12 ;
OutByte[1] = 0 ;
OutByte[2] = axis ;
OutByte[3] = value >>24;
OutByte[4] = value >>16;
OutByte[5] = value >>8;
OutByte[6] = value ;
enabled_cs(cardno);
delay_nms(1);
函数名: sudden_stop
功能: 轴立即停止
参数:
cardno        卡号
axis        停止的轴号(1,2,3,4)
mode  0:急停并清空后面缓存的指令  2:急停不清后面缓存的指令
void sudden_stop(unsigned char cardno ,unsigned char axis ,unsigned char mode)
OutByte[0] = 0x17 ;
OutByte[1] = axis ;
OutByte[2] = mode;
enabled_cs(cardno);
delay_nms(1);
函数名: set_special
功能:设置特别功能
参数:
cardno        卡号
value
       0xfc          缓存插补运动暂停
       0xfd   取消缓存插补暂停
void set_special(unsigned char cardno,unsigned char value)
OutByte[0] = 0xFA ;
OutByte[1] = 0;
OutByte[2] = value;
enabled_cs(cardno);
delay_nms(1);
函数名: get_inp_state
功能: 获取轴状态,缓存剩余量,各轴逻辑位置。
参数:
cardno        卡号
amount         获取字节数量。        设为22将取全部数据。
inbuf[]   读取的数据存放的数组
void  get_inp_state( unsigned char cardno, unsigned char amount,unsigned char tinbuf[50])
unsigned char OutByte[50];
char i;
enabled_cs(cardno);
tinbuf[0]=SPI_SendData(0x04);
for(i=1;i<amount;i++)
tinbuf[i]=SPI_SendData(0);
delay_nms(1);
long  get_state( unsigned char cardno,unsigned char axis )
unsigned char inbuf[50];
char i;
        long tmp=0;
enabled_cs(cardno);
for(i=1;i<20;i++)
tmp=  (long)inbuf[0+axis*4]<<24;
tmp+= (long)inbuf[1+axis*4]<<16;
tmp+= (long)inbuf[2+axis*4]<<8;
tmp+= (long)inbuf[3+axis*4];
return tmp;
delay_nms(1);
函数名:         go_home
功能:回原点,回到原点开关会自动减速停止,随后离开原点开关自动急停
参数:
cardno         卡号
no   轴号
speed1      进入原点速度,运行频率为:值(Hz)
speed2      离开原点速度,运行频率为:值(Hz)
void go_home(unsigned char cardno,unsigned char no , long speed1 ,long speed2 )
OutByte[0] = 0x1a;
OutByte[1] = 0;
OutByte[2] = no;
OutByte[3] = speed1>>24;
OutByte[4] = speed1 >>16;
OutByte[5] = speed1>> 8;
OutByte[6] = speed1;
OutByte[7] = speed2 >>24;
OutByte[8] = speed2 >>16;
OutByte[9] = speed2 >>8;
OutByte[10] = speed2 ;
enabled_cs(cardno);
delay_nms(1);
函数名:         inp_move4
功能:四轴直线插补
参数:
cardno         卡号
no1   X轴轴号
no2   Y轴轴号
no3   Z轴轴号
no4   E轴轴号
pulse1,pulse2,pulse3,pulse4                                X-Y-Z-E轴移动的距离,范围(-8388608~+8388607)
mode  0:绝对位移  1:相对位移
void inp_move4(unsigned char cardno,unsigned char no1 ,unsigned char no2 ,unsigned char no3 ,unsigned char no4, long pulse1  ,long pulse2 ,long pulse3 ,long pulse4 ,unsigned char mode )
OutByte[0] = 0xa;
OutByte[1] = no1;
OutByte[2] = no2;
OutByte[3] = no3;
OutByte[4] = no4;
OutByte[5] = pulse1>>24;
OutByte[6] = pulse1 >>16;
OutByte[7] = pulse1>> 8;
OutByte[8] = pulse1;
OutByte[9] = pulse2 >>24;
OutByte[10] = pulse2 >>16;
OutByte[11] = pulse2 >>8;
OutByte[12] = pulse2 ;
  OutByte[13] = pulse3 >>24;
OutByte[14] = pulse3 >>16;
OutByte[15] = pulse3 >>8;
OutByte[16] = pulse3 ;
   OutByte[17] = pulse4 >>24;
OutByte[18] = pulse4 >>16;
OutByte[19] = pulse4 >>8;
OutByte[20] = pulse4 ;
OutByte[21] = 0 ;
OutByte[22] = mode;
enabled_cs(cardno);
SPI_SendData(OutByte[15]);
SPI_SendData(OutByte[16]);
SPI_SendData(OutByte[17]);
SPI_SendData(OutByte[18]);
SPI_SendData(OutByte[19]);
SPI_SendData(OutByte[20]);
SPI_SendData(OutByte[21]);
SPI_SendData(OutByte[22]);
delay_nms(100);
函数名: inp_arc
功能:二轴圆弧插补
参数:
cardno        卡号
no1                参与插补X轴的轴号
no2                参与插补Y轴的轴号
x,y                圆弧插补的终点位置(相对于起点),范围(-8388608~+8388607)
i,j                圆弧插补的圆心点位置(相对于起点),范围(-8388608~+8388607)
mode1       0:圆心法逆时针插补   1:圆心法顺时针插补   2:三点圆弧    3:半径法逆时针插补     4:半径法顺时针插补
mode2  0:绝对位移  1:相对位移
void inp_arc(unsigned char cardno ,unsigned char no1,unsigned char no2, long x , long y, long i, long j,unsigned char mode1,unsigned char mode2 )
OutByte[0] = 0xc;
OutByte[1] = no1;
OutByte[2] = no2;
OutByte[3] = x >>24;
OutByte[4] = x >>16;
OutByte[5] = x >>8;
OutByte[6] = x ;
OutByte[7] = y >>24;
OutByte[8] = y >>16;
OutByte[9] = y >>8;
OutByte[10] = y ;
OutByte[11] = i >>24;
OutByte[12] = i >>16;
OutByte[13] = i >>8;
OutByte[14] = i ;
OutByte[15] = j >>24;
OutByte[16] = j >>16;
OutByte[17] = j >>8;
OutByte[18] = j ;
OutByte[19] = mode1;
OutByte[20] = mode2;
enabled_cs(cardno);
delay_nms(100);
函数名: inp_helical
功能:圆弧螺旋插补
参数:
cardno        卡号
no1                参与插补X轴的轴号
no2                参与插补Y轴的轴号
no3                参与插补螺旋轴的轴号
z           参与插补螺旋轴的位置(相对于起点)
mode1      0:逆时针插补   1:顺时针插补
mode2     0:绝对位移  1:相对位移
void inp_helical(unsigned char cardno ,unsigned char no1,unsigned char no2,unsigned char no3,long x , long y,long z, long i, long j,unsigned char mode1,unsigned char mode2 )
unsigned char OutByte[30];
OutByte[0] = 0xd;
OutByte[1] = no1;
OutByte[2] = no2;
OutByte[3] = no3;
OutByte[4] = x >>24;
OutByte[5] = x >>16;
OutByte[6] = x >>8;
OutByte[7] = x ;
OutByte[8] = y >>24;
OutByte[9] = y >>16;
OutByte[10] = y >>8;
OutByte[11] = y ;
OutByte[12] = z >>24;
OutByte[13] = z >>16;
OutByte[14] = z >>8;
OutByte[15] = z ;
OutByte[16] = i >>24;
OutByte[17] = i >>16;
OutByte[18] = i >>8;
OutByte[19] = i ;
OutByte[20] = j >>24;
OutByte[21] = j >>16;
OutByte[22] = j >>8;
OutByte[23] = j ;
OutByte[24] = mode1;
OutByte[25] = mode2;
enabled_cs(cardno);
SPI_SendData(OutByte[23]);
SPI_SendData(OutByte[24]);
SPI_SendData(OutByte[25]);
delay_nms(1);
函数名: write_bit
功能:写输出口状态
参数:
cardno        卡号
number  端口号(0-6)  Y0-Y6
value   状态(0,1) 0 输出低电平   1 输出高电平
void write_bit(unsigned char cardno , unsigned char number, unsigned char value)
OutByte[0] = 0x03 ;
OutByte[1] = number;
OutByte[2] = value;
enabled_cs(cardno);
delay_nms(1);
函数名: wait_delay
功能:等待延时数
参数:
cardno        卡号
value          延时量(1-10000)MS
void wait_delay(unsigned char cardno ,unsigned int value)
OutByte[0] = 0x0e ;
OutByte[1] = value>>8;
OutByte[2] = value;
enabled_cs(cardno);
delay_nms(1);
函数名:         pmove
功能: e版本单轴运行
参数:
cardno         卡号
axis   轴号
mode  0:绝对位移  1:相对位移
pulse1                        轴移动的距离,范围(-8388608~+8388607)
void pmove(unsigned char cardno,unsigned char axis,unsigned char mode, long pulse1 )
OutByte[0] = 0x2;
OutByte[1] = axis ;
OutByte[2] = mode;
OutByte[3] = pulse1>>24;
OutByte[4] = pulse1 >>16;
OutByte[5] = pulse1>>8;
OutByte[6] = pulse1;
enabled_cs(cardno);
delay_nms(1);
函数名: wait_stop
功能: e版本等待轴停止
参数:
cardno        卡号
axis        停止的轴号(1,2,3,4)
void wait_stop(unsigned char cardno ,unsigned char axis)
OutByte[0] = 0xf ;
OutByte[1] = axis ;
enabled_cs(cardno);
delay_nms(1);
函数名:  set_cam
功能: 设置电子凸轮
参数:
cardno        卡号
num                 凸轮表数据段行号
xa                  主轴编码器脉冲数
xb                        从轴脉冲数
style      从轴运动方式
void set_cam(unsigned char cardno ,unsigned int num ,unsigned long xa ,unsigned long xb,unsigned char style )
OutByte[0] = 0x21;
OutByte[1] =  num >>8;
OutByte[2] =  num;
OutByte[3] = xa >>24;
OutByte[4] = xa >>16;
OutByte[5] = xa >>8;
OutByte[6] = xa ;
OutByte[7] = xb >>24;
OutByte[8] = xb >>16;
OutByte[9] = xb >>8;
OutByte[10] = xb ;
OutByte[11] = style ;
enabled_cs(cardno);
delay_nms(1);
函数名:   run_cam
功能: 运行电子凸轮
  参数:
cardno        卡号
axis      从轴轴号
mode      从轴运动方式
snum                 数据段起始行号
dnum                   数据段结束行号
  void run_cam(unsigned char cardno,unsigned char axis,unsigned char mode ,unsigned int snum ,unsigned int dnum )
OutByte[0] = 0x22;
OutByte[1] =  axis;
OutByte[2] =  mode;
OutByte[3] = snum >>8;
OutByte[4] = snum ;
OutByte[5] = dnum >>8;
OutByte[6] = dnum ;
enabled_cs(cardno);
delay_nms(1);
void main(void)
   initial();
   init_uart();
   // ES = 1;
   // EA = 1;
   // P_SW2 = 0x80;
   // XOSCCR = 0xc0;                              //启动外部晶振
   // while (!(XOSCCR & 1));                      //等待时钟稳定
   // CKDIV = 0x00;                               //时钟不分频
   // CKSEL = 0x01;                               //选择外部晶振
   // P_SW2 = 0x00;
         led=0;
    delay_nms(100)        ;
            /*下面指令为e型无缓存1轴2轴手动方式回原点,xc1006适用
         set_speed(1 ,1,80000,10000,80000);            // 设1轴速度
         set_speed(1 ,2,80000,10000,80000);                 // 设2轴速度
          pmove(1,1,1, -320000000);                  //         1轴多脉冲负方向运动 ,原点开关有效会停下
          pmove(1,2,1, -320000000);                  //         2轴多脉冲负方向运动,原点开关有效会停下
           do
         get_inp_state( 1, 4,inbuf);           //只需读出4个字节来判断轴状态
           while(inbuf[1]);                          //通过返回的第二个字节里面的4个位获取各轴状态,不全为0时表示轴还没停止 ,一直等到全为0
       set_command_pos(1,1,0);                //           设1轴此时坐标为0
           set_command_pos(1,2,0);                //           设2轴此时坐标为0
           /*下面的指令为f型1,2轴使用回原点指令自动二次回原点
          go_home(1,1,30000,5000 ) ;    //         1轴回原点
          go_home(1,2,30000,5000 ) ;        //         2轴回原点
          do
          while(inbuf[3]);           // 等待缓存数量为0 ,如果多条运动指令在缓存里 ,可以读取缓存数量来判断指令有没执行完成。
         //while(inbuf[1]);           // 等待轴停止 ,如果只有一条除圆弧外的运动指令,可以读取轴状态来判断有没执行完。
        set_command_pos(1 ,1,0);           //设1轴坐标
        set_command_pos(1 ,2,0);           //设2轴坐标
   //set_speed(1 ,1,80000,20000,80000);                 //设置1轴运行速度20K,加速度80k
        //set_speed(1 ,2,80000,20000,80000);                 //         设置2轴运行速度20K,加速度80k
        //set_speed(1 ,3,80000,20000,80000);                 //         设置3轴运行速度20K,加速度80k
        //set_speed(1 ,4,80000,20000,80000);                   //设置4轴运行速度20K,加速度80k
                  sudden_stop(1,1,3);
                set_speed(1 ,1,1600,1600,1600);
                   set_command_pos(1,1, 0x00f8 ) ;
                set_special(1,0xea);
         pmove(1,1,1, 3200);
   while(1)
        // write_bit(1 , 1, 0) ;
         // pmove(1,1,1, 3200);
         if(!b1)          //按下按键
                 delay_nms(10);
                if(!b1)
                 pmove(1,1,1, 3200);
                  /*下面指令为e型无缓存运行        ,xc1006适用
          pmove(1,1,1, 3200);                  //         1轴正方向运动
          pmove(1,2,1, 6400);                  //         2轴正方向运动
           do
           while(inbuf[1]&(1<<0));                          //通过返回的第二个字节里面的0位获取1轴状态,直到1轴停止
       pmove(1,1,1, -3200);                  //         1轴负方向运动
//        set_speed(1 ,4,80000,20000,80000);                   //设置4轴运行速度20K,加速度80k
//        pmove(1,1,1, 2);
                    // pmove(1,1,0, 0);
                          // pmove(1,1,1, 20000);
                //         pmove(1,3,1, 2);
                //         pmove(1,4,1, 2);
//        inp_move4(1,1,2,0,0,20000 ,20000,0 ,0 ,1);  //         4轴直线插补
                   /*e型带缓存测试指令*/
             // set_speed(1 ,1,200000,50000,80000);                 //设置1轴运行速度50K,加速度200k
                 // set_speed(1 ,2,200000,50000,80000);                 //设置1轴运行速度50K,加速度200k
                 // set_speed(1 ,3,40000,10000,80000);                 //设置1轴运行速度10K,加速度40k
                  //write_bit(1 , 6, 0);                                         // Y6输出低
                 // pmove(1,1,1, 1000);                                  //1轴相对运行速1000个脉冲
                 // pmove(1,2,1, 1000);                                  // 2轴相对运行速1000个脉冲
                  //wait_stop(1 ,1);                                          //等待1轴停止
                  //wait_stop(1 ,2);                                          //等待2轴停止
             // wait_delay(1 ,500);                                         // 延时500MS
                 // pmove(1,3,1, 1000);                                  //3轴相对运行速1000个脉冲
              //write_bit(1 , 6, 1);                            // Y6输出高
           /*f型测试指令*/
                //        write_bit(1 , 6, 0);
                //        set_speed(1 ,1,200000,50000,80000);        //设置运行速度50K,加速度200h
                  //        write_bit(1 , 2, 0);
        //        inp_move4(1,1,0,0,0,80000 ,0,0 ,0 ,1);  //  1,2轴插补
                        //        set_speed(1,1 ,800000,25000,80000);        //设置运行速度25K,加速度800K
                   //inp_move4(1,1,2,0,0,20000 ,10000,0 ,0 ,1);  //  1,2轴插补
                // inp_arc(1 ,1,2, -20000, 20000, -20000, 0,0,1) ;        //  1,2轴圆弧插补
                  // inp_arc(1 ,1,2, 3200, 3200,  3200, 0,0,1) ;        //  1,2轴圆弧插补
                        //   inp_arc(1 ,1,2, 20000, 20000,  20000, 0,0,1) ;        //  1,2轴圆弧插补
                 // inp_arc(1 ,1,2, -40000, 0, -20000, 20000,2,1) ;        //  1,2轴3点圆弧插补
                        //set_speed(1 ,1,800000,25000,80000);        //设置运行速度250K,加速度800K
          //                write_bit(1 , 6, 1);
    /*下面的指令会直接发到缓存区自动排队运行*/
        //        write_bit(1 , 6, 0);                   // Y6输出低
          //        set_speed(1 ,1,40000,25000,80000);
        // inp_move4(1,1,2,3,4,320000 ,32000,32000 ,32000 ,1);  //         4轴直线插补
          //wait_delay(1 ,2000);                          //模块内部指令间延时3S
          //inp_move4(1,1,2,0,0,32000 ,32000,0 ,0 ,1);  //         1,2轴直线插补
          // wait_delay(1 ,2000);
         // inp_move4(1,2,0,0,0,32000 ,0,0 ,0 ,1);  //         2轴单独运行
   //inp_arc(1 ,1,2, -20000, 20000, -20000, 0,0,1) ;                 //         2轴圆弧插补,终点相对起点坐标(-20000,20000),圆心相对起点坐标(-20000,0),逆时针方向,画出1/4圆弧。
         //        write_bit(1 , 6, 1);                               // Y6输出高        ,判断指令段有没执行完成也可以在指令段后面加一条端口输出指令,然后用单片机来读引脚来判断。
          /*下面指令为D型电子凸轮追剪运行测试        */
// set_cam(1,0 ,0 ,0 ,0) ;        //        初始位置
// set_cam(1,1 ,400 ,800,2 ) ;         //         轴加速
  //set_cam(1,2 ,800 ,2800,1 ) ;        //           轴同步
  //set_cam(1,3 ,1200 ,3200 ,3) ;        //           轴减速
  //set_cam(1,4 ,1600,400 ,2) ;        //                轴反方向加速
// set_cam(1,5 ,2000,0  ,3) ;        //                         轴反方向减速到初始位置
  //set_cam(1,6 ,3000,0  ,0) ;        //                         轴在初始位等待
  // run_cam(1,1,1 ,0 ,6 );                  //                          单次运行0-6条
           /*下面指令为D型电子凸轮飞剪运行测试        */
  //set_cam(1,0 ,0 ,0 ,0) ;        //        初始位置
  //set_cam(1,1 ,400 ,3200,2 ) ;         //         轴加速
  //set_cam(1,2 ,800 ,9600,1 ) ;        //           轴同步
  //set_cam(1,3 ,1200 ,12800,3) ;        //           轴减速到初始位
  //set_cam(1,4 ,3000,0 ,0) ;        //                         轴在初始位等待
  // run_cam(1,1,1 ,0 ,4 );                  //                          单次运行0-4条
                        while(!b1);
          if(!b2)            //按下按键
                 delay_nms(10)         ;
                 if(!b2)
                  // run_cam(1,1,1 ,0 ,5 );                  //                          凸轮表单次运行0-5条
                   pmove(1,1,1, 3200);
                        // pmove(1,2,1, 10000);
                // sudden_stop(1,1,0);
        //         pmove(1,1,0, 0);
                // sudden_stop(1,1,0);                          //           f型立即停止所有插补轴 ,并清缓存        。 e型立即停止1轴 ,并清缓存        。
                // sudden_stop(1,2,0);
                  // sudden_stop(1,3,0);                          //           f型立即停止所有插补轴 ,并清缓存        。 e型立即停止1轴 ,并清缓存        。
                 //sudden_stop(1,4,0);
                  //get_inp_state( 1, 28,inbuf);           //读出数据放入数组
                //USRAT_transmit(inbuf,28);           //  串口将数组数据发送出去查看
          // USART_Txbyte('\r');
          // USART_Txbyte('\n');
                //USART_Txbyte(0x0d);
          // USART_Txbyte(0x0a);
                   while(!b2);
        //        delay_nms(10) ;
                get_inp_state( 1, 22,inbuf);           //读出数据放入数组
                USRAT_transmit(inbuf,22);           //  串口将数组数据发送出去查看
                 //USART_Txbyte(inbuf[1]);
          // get_inp_state( 1, 20,inbuf);           //读出数据放入数组
        //         USRAT_transmit(inbuf,20);           //  串口将数组数据发送出去查看
             // USART_Txbyte(inbuf[3]);
                if(inbuf[1]==0)                         //inbuf[1]数据为0表示所有轴都停
                          led=1;
                  else
                          led=0;                  // 指示LED点亮
