[UNO] arduino 2个74hc595级联驱动8位数码管
22012|6
 楼主| xiaoqi976633690 发表于 2023-2-14 20:14 | 显示全部楼层 |阅读模式
C代码:
  1. /*
  2.    Arduino code for Individual control over each pin
  3.    Support for 40+ 74HC595 8 bit shift registers
  4.    http://bildr.org/2011/02/74hc595/
  5. */
  6. #define DATA_PIN  8  // Pin connected to DS of 74HC595串行数据输入
  7. #define LATCH_PIN 9  // Pin connected to STCP of 74HC595上升沿数据从寄存器输出到引脚
  8. #define CLOCK_PIN 10 // Pin connected to SHCP of 74HC595上升沿串行数据移位存入寄存器
  9. void disp(uint16_t V1,uint16_t V2);
  10. void write_74hc595(uint8_t *data);
  11. //数码管数量
  12. #define NUM_SHIFT_REGS  8
  13. //共阳数码管
  14. unsigned char leddata[]={
  15.                 0xC0,  //"0"
  16.                 0xF9,  //"1"
  17.                 0xA4,  //"2"
  18.                 0xB0,  //"3"
  19.                 0x99,  //"4"
  20.                 0x92,  //"5"
  21.                 0x82,  //"6"
  22.                 0xF8,  //"7"
  23.                 0x80,  //"8"
  24.                 0x90,  //"9"
  25.                 0x88,  //"A"
  26.                 0x83,  //"B"
  27.                 0xC6,  //"C"
  28.                 0xA1,  //"D"
  29.                 0x86,  //"E"
  30.                 0x8E,  //"F"
  31.                 0x89,  //"H"
  32.                 0xC7,  //"L"
  33.                 0xC8,  //"n"
  34.                 0xC1,  //"u"
  35.                 0x8C,  //"P"
  36.                 0xA3,  //"o"
  37.                 0xBF,  //"-"
  38.                 0xFF,  //熄灭
  39.                 0xFF  //自定义
  40.                          };
  41. uint8_t x595[NUM_SHIFT_REGS]={0x00,0xff};
  42. void setup() {
  43.   pinMode(DATA_PIN, OUTPUT);
  44.   pinMode(CLOCK_PIN, OUTPUT);
  45.   pinMode(LATCH_PIN, OUTPUT);
  46.   Serial.begin(9600);
  47.   pinMode(A0,INPUT);
  48.   pinMode(A1,INPUT);
  49. }
  50. bool toggle = false;
  51. uint16_t  x1=1990,x2=3520;
  52. uint16_t time=0;
  53. uint16_t ADC_vlue1=0,ADC_vlue2=0;
  54. float volt1,volt2;
  55. void loop() {
  56.       ADC_vlue1=analogRead(A0);
  57.       ADC_vlue2=analogRead(A1);
  58.       volt1=ADC_vlue1*0.48828125;
  59.       volt2=ADC_vlue2*0.48828125;
  60.       time++;
  61.       disp(volt1,volt2);
  62.       if(time==100)
  63.       {
  64.         time=0;
  65.         x1++;
  66.         x2++;
  67.         Serial.println(volt1);
  68.       }
  69. }
  70. void write_74hc595(uint8_t *data)
  71. {
  72.   uint8_t m[NUM_SHIFT_REGS];
  73.   digitalWrite(LATCH_PIN, LOW);
  74.   for(int x=0;x<2;x++)
  75.   {
  76.     m[x]=data[x];
  77.     for(int i=0;i<8;i++)
  78.       {
  79.         digitalWrite(CLOCK_PIN, LOW);
  80.         digitalWrite(DATA_PIN,(m[x]&0x80)>1?HIGH:LOW);
  81.         digitalWrite(CLOCK_PIN, HIGH);
  82.         m[x]<<=1;
  83.       }
  84.   }
  85.   digitalWrite(LATCH_PIN, HIGH);//上升沿输出
  86. }
  87. void disp(uint16_t V1,uint16_t V2)
  88. {
  89.   for(int8_t i=0;i<NUM_SHIFT_REGS;i++)
  90.   {
  91.       switch(i)
  92.       {
  93.         case 0:
  94.         if(V1>=1000) x595[0]=leddata[V1/1000%10];
  95.         else x595[0]=0xff;//小于1000的千位不显示
  96.         x595[1]=1<<i;write_74hc595(x595);break;
  97.         case 1: x595[0]=leddata[V1/100%10];x595[1]=1<<i;write_74hc595(x595);break;
  98.         case 2: x595[0]=leddata[V1/10%10];x595[1]=1<<i;write_74hc595(x595);break;
  99.         case 3: x595[0]=leddata[V1%10];x595[1]=1<<i;write_74hc595(x595);break;
  100.         case 4:
  101.         if(V2>=1000) x595[0]=leddata[V2/1000%10];
  102.         else x595[0]=0xff;//小于1000的千位不显示
  103.         x595[1]=1<<i;write_74hc595(x595);break;
  104.         case 5: x595[0]=leddata[V2/100%10];x595[1]=1<<i;write_74hc595(x595);break;
  105.         case 6: x595[0]=leddata[V2/10%10];x595[1]=1<<i;write_74hc595(x595);break;
  106.         case 7: x595[0]=leddata[V2%10];x595[1]=1<<i;write_74hc595(x595);break;
  107.       }
  108.   }
  109.         x595[0]=0x7F;x595[1]=1<<1;
  110.         write_74hc595(x595);
  111.         x595[0]=0x7F;x595[1]=1<<5;
  112.         write_74hc595(x595);
  113. }
电路图json:
  1. {
  2.   "version": 1,
  3.   "author": "Anderson Costa",
  4.   "editor": "wokwi",
  5.   "parts": [
  6.     { "type": "wokwi-arduino-uno", "id": "uno", "top": 0, "left": 0, "attrs": {} },
  7.     { "type": "wokwi-74hc595", "id": "sr1", "top": 255, "left": 200, "attrs": {} },
  8.     { "type": "wokwi-74hc595", "id": "sr2", "top": 255, "left": 360, "attrs": {} },
  9.     {
  10.       "type": "wokwi-resistor",
  11.       "id": "r1",
  12.       "top": 330,
  13.       "left": 140,
  14.       "rotate": 90,
  15.       "attrs": { "value": "180" }
  16.     },
  17.     {
  18.       "type": "wokwi-resistor",
  19.       "id": "r2",
  20.       "top": 330,
  21.       "left": 160,
  22.       "rotate": 90,
  23.       "attrs": { "value": "180" }
  24.     },
  25.     {
  26.       "type": "wokwi-resistor",
  27.       "id": "r3",
  28.       "top": 330,
  29.       "left": 180,
  30.       "rotate": 90,
  31.       "attrs": { "value": "180" }
  32.     },
  33.     {
  34.       "type": "wokwi-resistor",
  35.       "id": "r4",
  36.       "top": 330,
  37.       "left": 200,
  38.       "rotate": 90,
  39.       "attrs": { "value": "180" }
  40.     },
  41.     {
  42.       "type": "wokwi-resistor",
  43.       "id": "r5",
  44.       "top": 330,
  45.       "left": 220,
  46.       "rotate": 90,
  47.       "attrs": { "value": "180" }
  48.     },
  49.     {
  50.       "type": "wokwi-resistor",
  51.       "id": "r6",
  52.       "top": 330,
  53.       "left": 240,
  54.       "rotate": 90,
  55.       "attrs": { "value": "180" }
  56.     },
  57.     {
  58.       "type": "wokwi-resistor",
  59.       "id": "r7",
  60.       "top": 330,
  61.       "left": 260,
  62.       "rotate": 90,
  63.       "attrs": { "value": "180" }
  64.     },
  65.     {
  66.       "type": "wokwi-resistor",
  67.       "id": "r8",
  68.       "top": 330,
  69.       "left": 280,
  70.       "rotate": 90,
  71.       "attrs": { "value": "180" }
  72.     },
  73.     {
  74.       "type": "wokwi-resistor",
  75.       "id": "r9",
  76.       "top": 330,
  77.       "left": 300,
  78.       "rotate": 90,
  79.       "attrs": { "value": "180" }
  80.     },
  81.     {
  82.       "type": "wokwi-resistor",
  83.       "id": "r10",
  84.       "top": 330,
  85.       "left": 320,
  86.       "rotate": 90,
  87.       "attrs": { "value": "180" }
  88.     },
  89.     {
  90.       "type": "wokwi-resistor",
  91.       "id": "r11",
  92.       "top": 330,
  93.       "left": 340,
  94.       "rotate": 90,
  95.       "attrs": { "value": "180" }
  96.     },
  97.     {
  98.       "type": "wokwi-resistor",
  99.       "id": "r12",
  100.       "top": 330,
  101.       "left": 360,
  102.       "rotate": 90,
  103.       "attrs": { "value": "180" }
  104.     },
  105.     {
  106.       "type": "wokwi-resistor",
  107.       "id": "r13",
  108.       "top": 330,
  109.       "left": 380,
  110.       "rotate": 90,
  111.       "attrs": { "value": "180" }
  112.     },
  113.     {
  114.       "type": "wokwi-resistor",
  115.       "id": "r14",
  116.       "top": 330,
  117.       "left": 400,
  118.       "rotate": 90,
  119.       "attrs": { "value": "180" }
  120.     },
  121.     {
  122.       "type": "wokwi-resistor",
  123.       "id": "r15",
  124.       "top": 330,
  125.       "left": 420,
  126.       "rotate": 90,
  127.       "attrs": { "value": "180" }
  128.     },
  129.     {
  130.       "type": "wokwi-resistor",
  131.       "id": "r16",
  132.       "top": 330,
  133.       "left": 440,
  134.       "rotate": 90,
  135.       "attrs": { "value": "180" }
  136.     },
  137.     {
  138.       "type": "wokwi-led",
  139.       "id": "led1",
  140.       "top": 380,
  141.       "left": 154,
  142.       "rotate": 180,
  143.       "attrs": { "color": "red" }
  144.     },
  145.     {
  146.       "type": "wokwi-led",
  147.       "id": "led2",
  148.       "top": 380,
  149.       "left": 174,
  150.       "rotate": 180,
  151.       "attrs": { "color": "red" }
  152.     },
  153.     {
  154.       "type": "wokwi-led",
  155.       "id": "led3",
  156.       "top": 380,
  157.       "left": 194,
  158.       "rotate": 180,
  159.       "attrs": { "color": "red" }
  160.     },
  161.     {
  162.       "type": "wokwi-led",
  163.       "id": "led4",
  164.       "top": 380,
  165.       "left": 214,
  166.       "rotate": 180,
  167.       "attrs": { "color": "red" }
  168.     },
  169.     {
  170.       "type": "wokwi-led",
  171.       "id": "led5",
  172.       "top": 380,
  173.       "left": 234,
  174.       "rotate": 180,
  175.       "attrs": { "color": "red" }
  176.     },
  177.     {
  178.       "type": "wokwi-led",
  179.       "id": "led6",
  180.       "top": 380,
  181.       "left": 254,
  182.       "rotate": 180,
  183.       "attrs": { "color": "red" }
  184.     },
  185.     {
  186.       "type": "wokwi-led",
  187.       "id": "led7",
  188.       "top": 380,
  189.       "left": 274,
  190.       "rotate": 180,
  191.       "attrs": { "color": "red" }
  192.     },
  193.     {
  194.       "type": "wokwi-led",
  195.       "id": "led8",
  196.       "top": 380,
  197.       "left": 294,
  198.       "rotate": 180,
  199.       "attrs": { "color": "red" }
  200.     },
  201.     {
  202.       "type": "wokwi-led",
  203.       "id": "led9",
  204.       "top": 380,
  205.       "left": 314,
  206.       "rotate": 180,
  207.       "attrs": { "color": "red" }
  208.     },
  209.     {
  210.       "type": "wokwi-led",
  211.       "id": "led10",
  212.       "top": 380,
  213.       "left": 334,
  214.       "rotate": 180,
  215.       "attrs": { "color": "red" }
  216.     },
  217.     {
  218.       "type": "wokwi-led",
  219.       "id": "led11",
  220.       "top": 380,
  221.       "left": 354,
  222.       "rotate": 180,
  223.       "attrs": { "color": "red" }
  224.     },
  225.     {
  226.       "type": "wokwi-led",
  227.       "id": "led12",
  228.       "top": 380,
  229.       "left": 374,
  230.       "rotate": 180,
  231.       "attrs": { "color": "red" }
  232.     },
  233.     {
  234.       "type": "wokwi-led",
  235.       "id": "led13",
  236.       "top": 380,
  237.       "left": 394,
  238.       "rotate": 180,
  239.       "attrs": { "color": "red" }
  240.     },
  241.     {
  242.       "type": "wokwi-led",
  243.       "id": "led14",
  244.       "top": 380,
  245.       "left": 414,
  246.       "rotate": 180,
  247.       "attrs": { "color": "red" }
  248.     },
  249.     {
  250.       "type": "wokwi-led",
  251.       "id": "led15",
  252.       "top": 380,
  253.       "left": 434,
  254.       "rotate": 180,
  255.       "attrs": { "color": "red" }
  256.     },
  257.     {
  258.       "type": "wokwi-led",
  259.       "id": "led16",
  260.       "top": 380,
  261.       "left": 454,
  262.       "rotate": 180,
  263.       "attrs": { "color": "red" }
  264.     },
  265.     {
  266.       "type": "wokwi-7segment",
  267.       "id": "sevseg3",
  268.       "top": 529.21,
  269.       "left": 225.9,
  270.       "attrs": { "digits": "4" }
  271.     },
  272.     {
  273.       "type": "wokwi-7segment",
  274.       "id": "sevseg1",
  275.       "top": 528.62,
  276.       "left": 436.56,
  277.       "attrs": { "digits": "4" }
  278.     },
  279.     { "type": "wokwi-potentiometer", "id": "pot1", "top": 71.57, "left": 402.18, "attrs": {} },
  280.     { "type": "wokwi-potentiometer", "id": "pot2", "top": 73.12, "left": 519.64, "attrs": {} }
  281.   ],
  282.   "connections": [
  283.     [ "uno:GND.2", "sr1:OE", "black", [ "v50", "h102" ] ],
  284.     [ "uno:GND.2", "sr2:OE", "black", [ "v50", "h102" ] ],
  285.     [ "uno:GND.2", "sr1:GND", "black", [ "v50", "h150", "v50", "h-45" ] ],
  286.     [ "uno:GND.2", "sr2:GND", "black", [ "v50", "h300", "v50", "h-9" ] ],
  287.     [ "uno:GND.2", "led1:C", "black", [ "v50", "h150", "v137", "h-143" ] ],
  288.     [ "uno:GND.2", "led2:C", "black", [ "v50", "h150", "v137", "h-143" ] ],
  289.     [ "uno:GND.2", "led3:C", "black", [ "v50", "h150", "v137", "h-143" ] ],
  290.     [ "uno:GND.2", "led4:C", "black", [ "v50", "h150", "v137", "h-143" ] ],
  291.     [ "uno:GND.2", "led5:C", "black", [ "v50", "h150", "v137", "h-143" ] ],
  292.     [ "uno:GND.2", "led6:C", "black", [ "v50", "h150", "v137", "h-143" ] ],
  293.     [ "uno:GND.2", "led7:C", "black", [ "v50", "h150", "v137", "h-143" ] ],
  294.     [ "uno:GND.2", "led8:C", "black", [ "v50", "h150", "v137", "h-143" ] ],
  295.     [ "uno:GND.2", "led9:C", "black", [ "v50", "h150", "v137", "h-143" ] ],
  296.     [ "uno:GND.2", "led10:C", "black", [ "v50", "h150", "v137", "h-143" ] ],
  297.     [ "uno:GND.2", "led11:C", "black", [ "v50", "h150", "v137", "h-143" ] ],
  298.     [ "uno:GND.2", "led12:C", "black", [ "v50", "h150", "v137", "h-143" ] ],
  299.     [ "uno:GND.2", "led13:C", "black", [ "v50", "h150", "v137", "h-143" ] ],
  300.     [ "uno:GND.2", "led14:C", "black", [ "v50", "h150", "v137", "h-143" ] ],
  301.     [ "uno:GND.2", "led15:C", "black", [ "v50", "h150", "v137", "h-143" ] ],
  302.     [ "uno:GND.2", "led16:C", "black", [ "v50", "h150", "v137", "h-143" ] ],
  303.     [ "uno:5V", "sr1:VCC", "red", [ "v44", "h61" ] ],
  304.     [ "uno:5V", "sr1:MR", "red", [ "v44", "h61" ] ],
  305.     [ "uno:5V", "sr2:VCC", "red", [ "v44", "h61" ] ],
  306.     [ "uno:5V", "sr2:MR", "red", [ "v44", "h61" ] ],
  307.     [ "uno:8", "sr1:DS", "orange", [ "v-20", "h111", "v222", "h-42" ] ],
  308.     [ "uno:9", "sr1:STCP", "purple", [ "v-27", "h129", "v237", "h-34" ] ],
  309.     [ "uno:10", "sr1:SHCP", "brown", [ "v-34", "h147", "v252", "h-29" ] ],
  310.     [ "uno:9", "sr2:STCP", "purple", [ "v-27", "h129", "v237", "h-34" ] ],
  311.     [ "uno:10", "sr2:SHCP", "brown", [ "v-34", "h147", "v252", "h-29" ] ],
  312.     [ "sr1:Q7S", "sr2:DS", "orange", [ "h0", "v-9", "h112" ] ],
  313.     [ "sr1:Q0", "r1:1", "green", [ "v-7", "h-50" ] ],
  314.     [ "sr1:Q1", "r2:1", "green", [ "v8", "h-15" ] ],
  315.     [ "sr1:Q2", "r3:1", "green", [ "v13", "h-5" ] ],
  316.     [ "sr1:Q3", "r4:1", "green", [ "v24", "h6" ] ],
  317.     [ "sr1:Q4", "r5:1", "green", [ "v21", "h17" ] ],
  318.     [ "sr1:Q5", "r6:1", "green", [ "v17", "h29" ] ],
  319.     [ "sr1:Q6", "r7:1", "green", [ "v13", "h38" ] ],
  320.     [ "sr1:Q7", "r8:1", "green", [ "v9", "h48" ] ],
  321.     [ "sr2:Q0", "r9:1", "green", [ "v-4", "h-41" ] ],
  322.     [ "sr2:Q1", "r10:1", "green", [ "v8", "h-15" ] ],
  323.     [ "sr2:Q2", "r11:1", "green", [ "v13", "h-5" ] ],
  324.     [ "sr2:Q3", "r12:1", "green", [ "v24", "h6" ] ],
  325.     [ "sr2:Q4", "r13:1", "green", [ "v21", "h17" ] ],
  326.     [ "sr2:Q5", "r14:1", "green", [ "v17", "h29" ] ],
  327.     [ "sr2:Q6", "r15:1", "green", [ "v13", "h38" ] ],
  328.     [ "sr2:Q7", "r16:1", "green", [ "v9", "h48" ] ],
  329.     [ "led1:A", "r1:2", "green", [ "v0" ] ],
  330.     [ "led2:A", "r2:2", "green", [ "v0" ] ],
  331.     [ "led3:A", "r3:2", "green", [ "v0" ] ],
  332.     [ "led4:A", "r4:2", "green", [ "v0" ] ],
  333.     [ "led5:A", "r5:2", "green", [ "v0" ] ],
  334.     [ "led6:A", "r6:2", "green", [ "v0" ] ],
  335.     [ "led7:A", "r7:2", "green", [ "v0" ] ],
  336.     [ "led8:A", "r8:2", "green", [ "v0" ] ],
  337.     [ "led9:A", "r9:2", "green", [ "v0" ] ],
  338.     [ "led10:A", "r10:2", "green", [ "v0" ] ],
  339.     [ "led11:A", "r11:2", "green", [ "v0" ] ],
  340.     [ "led12:A", "r12:2", "green", [ "v0" ] ],
  341.     [ "led13:A", "r13:2", "green", [ "v0" ] ],
  342.     [ "led14:A", "r14:2", "green", [ "v0" ] ],
  343.     [ "led15:A", "r15:2", "green", [ "v0" ] ],
  344.     [ "led16:A", "r16:2", "green", [ "v0" ] ],
  345.     [ "sevseg3:DIG1", "r1:1", "green", [ "v-32.82", "h-179.17", "v-217.55" ] ],
  346.     [ "sevseg3:DIG2", "r2:1", "green", [ "v-38.39", "h-200.56", "v-176.05", "h37.06" ] ],
  347.     [ "sevseg3:DIG3", "r3:1", "green", [ "v-44.88", "h-203.68", "v-162.15", "h47.26" ] ],
  348.     [ "sevseg3:DIG4", "r4:1", "green", [ "v27", "h-205.87", "v-294.65", "h44.48" ] ],
  349.     [ "sevseg1:DIG1", "r5:1", "green", [ "v-53.55", "h-362.03", "v-138.99", "h38.92" ] ],
  350.     [ "sevseg1:DIG2", "r6:1", "green", [ "v-59.11", "h-385.28", "v-128.79", "h26.87" ] ],
  351.     [ "sevseg1:DIG3", "r7:1", "green", [ "v-62.82", "h-387.47", "v-119.53", "h27.8" ] ],
  352.     [ "sevseg1:DIG4", "r8:1", "green", [ "v40.56", "h-392.44", "v-285.39", "h44.48" ] ],
  353.     [ "sevseg3:A", "r9:1", "green", [ "v-106.96", "h205.95", "v-80.61", "h-53.74" ] ],
  354.     [ "sevseg3:A", "sevseg1:A", "green", [ "v-106.96", "h142.94" ] ],
  355.     [ "sevseg3:B", "r10:1", "green", [ "v-99.55", "h185.15", "v-93.58", "h-34.28" ] ],
  356.     [ "sevseg1:B", "sevseg3:B", "green", [ "v-98.68", "h-209.9", "v99.27" ] ],
  357.     [ "sevseg3:C", "sevseg1:C", "green", [ "v53.27", "h96.46" ] ],
  358.     [ "sevseg1:C", "r11:1", "green", [ "v53.26", "h122.12", "v-319.91", "h-142.52" ] ],
  359.     [ "sevseg3:D", "sevseg1:D", "green", [ "v64.1", "h61.54" ] ],
  360.     [ "sevseg1:D", "r12:1", "green", [ "v64.09", "h148.54", "v-336.14", "h-197.24" ] ],
  361.     [ "sevseg3:E", "sevseg1:E", "green", [ "v76.13", "h36.26" ] ],
  362.     [ "sevseg1:E", "r13:1", "green", [ "v75.51", "h167.16", "v-353.58", "h-173.78" ] ],
  363.     [ "sevseg3:F", "sevseg1:F", "green", [ "v-88.27", "h210.66" ] ],
  364.     [ "sevseg1:F", "r14:1", "green", [ "v-87.17", "h156.37", "v-128.48", "h-248.86" ] ],
  365.     [ "sevseg3:G", "sevseg1:G", "green", [ "v32.83", "h80.84" ] ],
  366.     [ "sevseg1:G", "r15:1", "green", [ "v31.62", "h144.39", "v-319.47", "h-236.08" ] ],
  367.     [ "sevseg3:DP", "sevseg1:DP", "green", [ "v89.25", "h100.12" ] ],
  368.     [ "sevseg1:DP", "r16:1", "green", [ "v89.84", "h168.66", "v-210.58" ] ],
  369.     [ "pot1:SIG", "uno:A0", "green", [ "v64.43", "h-232.5" ] ],
  370.     [ "pot1:GND", "sr2:GND", "black", [ "v100.96", "h38.4", "v49.86", "h-32.47" ] ],
  371.     [ "pot1:VCC", "sr2:MR", "red", [ "v95.74", "h-26.24" ] ],
  372.     [ "pot2:SIG", "uno:A1", "green", [ "v57.36", "h-335.08" ] ],
  373.     [ "pot1:GND", "pot2:GND", "black", [ "v30.78", "h63.24" ] ],
  374.     [ "pot1:VCC", "pot2:VCC", "red", [ "v41.26", "h86.82" ] ]
  375.   ],
  376.   "dependencies": {}
  377. }
实验现象:
在线模拟链接:https://wokwi.com/
gaochy1126 发表于 2023-2-18 14:56 | 显示全部楼层
74hc595还需要动态刷新才行,现在有专用的驱动芯片可以使用。
数码管驱动芯片有狠毒,TM1650数码管驱动芯片带有矩阵按键扫码功能。
gaochy1126 发表于 2023-2-18 14:57 | 显示全部楼层
数码管驱动芯片大多用TM1668,TM1628,SM1668,SM1628。
TM1629与单片机的连接是串行接口,只需要4个引脚,单片机随便用4个I/O脚与TM1629连接就行了。
闻则123 发表于 2023-12-8 16:45 | 显示全部楼层
感谢楼主分享
WoodData 发表于 2024-4-26 10:42 | 显示全部楼层
感谢分享
