[技术问答] MA35D1如何与内置的M4通信
642|4
 楼主| 两只袜子 发表于 2023-2-15 09:12 | 显示全部楼层 |阅读模式
MA35D1如何与内置的M4通信
jcky001 发表于 2023-2-15 11:46 | 显示全部楼层
  • 进入以下路径和进行内核配置
~/MA35D1_Buildroot$ make linux-menuconfig
  • 内核配置
Device Drivers --->
    Remoteproc drivers --->
  • Support for Remote Processor subsystem
            <*> MA35D1 remoteproc support
    Device Drivers --->
        Rpmsg drivers --->
        -*- RPMSG device interface
        <*> MA35D1 Shared Memory Driver
    • 配置内核设备树
    ~/MA35D1_Buildroot/output/build/linux-custom/arch/arm64/boot/dts/nuvoton/ma35d1.dtsi$ vi ma35d1.dtsi
    rproc {
                    compatible = "nuvoton, ma35d1-rproc";
                    resets = <&reset MA35D1_RESET_CM4>;
                    memory-region = <&rproc_buf>;
                    status = "okay";
    rpmsg {
                    compatible = "nuvoton,ma35d1-rpmsg";
                    share-mem-addr = <0x2401ff00>;
                    mboxes = <&wormhole 2>;
                    tx-smem-size = <128>;
                    rx-smem-size = <128>;
                    status = "okay";
    hwsem: hwspinlock@40380000 {
                    compatible = "nuvoton,ma35d1-hwsem";
                    reg = <0x0 0x40380000 0x0 0x1000>;
                    clocks = <&clk HWS_GATE>;
                    clock-names = "hws_gate";
                    nuvoton,sys = <&sys>;
                    status = "okay";
    • 重新编译内核
    ~/MA35D1_Buildroot$ make linux-rebuild
    • 编译rpmsg.c,并拷贝到rootfs
    ~/MA35D1_Buildroot$ source output/host/environment-setup
    ~/MA35D1_Buildroot$ $CC rpmsg.c -o rpmsg
    ~/MA35D1_Buildroot$ cp -rf rpmsg out/images/target
    • 拷贝Share_memory_demo.elf到rootfs
    ~/MA35D1_Buildroot$ cp -rf out/images/RTP-BSP out/image/target
    • 重新打包Image
    ~/Buildroot_MA35D1$ make
    • 烧录Image 到MA35D1板子
    • 测试
    # echo -n 固件路径 > /sys/module/firmware_class/parameters/path
    # echo Share_memory_demo.elf > /sys/class/remoteproc/remoteproc0/firmware
    # echo start > /sys/class/remoteproc/remoteproc0/state
    # ./rpmsg &
    幸福小强 发表于 2023-2-19 18:26 | 显示全部楼层
    双内核的单片机吗?
    小夏天的大西瓜 发表于 2023-2-22 15:55 | 显示全部楼层
    MA35D1系列为一颗异核同构的多核心微处理器
    小小蚂蚁举千斤 发表于 2023-2-23 15:59 | 显示全部楼层
    基于双核 64 位 Arm® Cortex-A35 内核,执行速度可达 1 GHz,并搭载一颗 180 MHz Arm Cortex-M4 内核。
