[STM32U5] 【NUCLEO-U575ZI-Q测评】+MAX7219
675|1
 楼主| 比神乐 发表于 2023-2-18 12:14 | 显示全部楼层 |阅读模式
今天搞了一下MAX7219。
MAX7219原理图,我自己做的模块:
代码:
  1. #include "main.h"
  2. /* Private includes ----------------------------------------------------------*/
  3. /* USER CODE BEGIN Includes */
  4. #define DIN_PIN                                GPIO_PIN_10
  5. #define DIN_GPIO_PORT                          GPIOC
  6. #define DIN_GPIO_CLK_ENABLE()                  __HAL_RCC_GPIOC_CLK_ENABLE()
  7. #define DIN_GPIO_CLK_DISABLE()                 __HAL_RCC_GPIOC_CLK_DISABLE()
  8. #define LOAD_PIN                                GPIO_PIN_12
  9. #define LOAD_GPIO_PORT                          GPIOC
  10. #define LOAD_GPIO_CLK_ENABLE()                  __HAL_RCC_GPIOC_CLK_ENABLE()
  11. #define LOAD_GPIO_CLK_DISABLE()                 __HAL_RCC_GPIOC_CLK_DISABLE()
  12. #define CLK_PIN                                GPIO_PIN_3
  13. #define CLK_GPIO_PORT                          GPIOH
  14. #define CLK_GPIO_CLK_ENABLE()                  __HAL_RCC_GPIOH_CLK_ENABLE()
  15. #define CLK_GPIO_CLK_DISABLE()                 __HAL_RCC_GPIOH_CLK_DISABLE()
  16. /* USER CODE END Includes */
  17. /* Private typedef -----------------------------------------------------------*/
  18. /* USER CODE BEGIN PTD */
  19. /* USER CODE END PTD */
  20. /* Private define ------------------------------------------------------------*/
  21. /* USER CODE BEGIN PD */
  22. /* USER CODE END PD */
  23. /* Private macro -------------------------------------------------------------*/
  24. /* USER CODE BEGIN PM */
  25. /* USER CODE END PM */
  26. /* Private variables ---------------------------------------------------------*/
  27. /* USER CODE BEGIN PV */
  28. static GPIO_InitTypeDef  GPIO_InitStruct;
  29. /* USER CODE END PV */
  30. /* Private function prototypes -----------------------------------------------*/
  31. void SystemClock_Config(void);
  32. static void SystemPower_Config(void);
  33. static void MX_ICACHE_Init(void);
  34. /* USER CODE BEGIN PFP */
  35. #define CLK_0           HAL_GPIO_WritePin(CLK_GPIO_PORT,GPIO_PIN_3,GPIO_PIN_RESET)
  36. #define CLK_1           HAL_GPIO_WritePin(CLK_GPIO_PORT,GPIO_PIN_3,GPIO_PIN_SET)
  37. #define LOAD_0          HAL_GPIO_WritePin(LOAD_GPIO_PORT,GPIO_PIN_12,GPIO_PIN_RESET)
  38. #define LOAD_1          HAL_GPIO_WritePin(LOAD_GPIO_PORT,GPIO_PIN_12,GPIO_PIN_SET)
  39. #define DIN_0           HAL_GPIO_WritePin(DIN_GPIO_PORT,GPIO_PIN_10,GPIO_PIN_RESET)
  40. #define DIN_1           HAL_GPIO_WritePin(DIN_GPIO_PORT,GPIO_PIN_10,GPIO_PIN_SET)
  41. #define NoOp   0x00           //??2ù×÷??'??÷
  42. #define Digit0 0x01           // êy??1ü1??'??÷
  43. #define Digit1 0x02           // êy??1ü2??'??÷
  44. #define Digit2 0x03           // êy??1ü3??'??÷
  45. #define Digit3 0x04           // êy??1ü4??'??÷
  46. #define Digit4 0x05           // êy??1ü5??'??÷
  47. #define Digit5 0x06           // êy??1ü6??'??÷
  48. #define Digit6 0x07           // êy??1ü7??'??÷
  49. #define Digit7 0x08           // êy??1ü8??'??÷
  50. #define DecodeMode 0x09       // ò?????ê???'??÷
  51. #define Intensity 0x0a        // áá?è??'??÷
  52. #define ScanLimit 0x0b        // é¨?è??êy??'??÷
  53. #define ShutDown 0x0c         // µí1|o???ê???'??÷
  54. #define DisplayTest 0x0f      // ??ê?2aê???'??÷
  55. #define ShutdownMode 0x00     // µí1|o?·?ê?
  56. #define NormalOperation 0x01  // ?y3?2ù×÷·?ê?
  57. #define ScanDigit 0x07        // é¨?è??êyéè??????ê?8??êy??1ü
  58. #define DecodeDigit 0xff      // ò???éè????8???ù?aBCD??
  59. #define IntensityGrade 0x0a   // áá?è??±eéè??
  60. #define TestMode 0x01         // ??ê?2aê???ê?
  61. #define TextEnd 0x00          // ??ê?2aê??áê??????'?y3?1¤×÷??ê?
  62. /*****************************************************************************
  63. * Function implementation - global ('extern') and local ('static')
  64. ******************************************************************************/
  65. uint8_t DisBuffer[8]={0,0,0,0,0,0,0,0};    // ??ê??o'???
  66. //******************?óê±toá??**************************************
  67. void delay(uint16_t t)
  68. {
  69.     uint16_t i;
  70.     while(t--)
  71.     {
  72.         /* ??óú12Mê±?ó?????óê±1ms */
  73.         for (i=0;i<36;i++)
  74.         {}
  75.     }
  76. }
  77. //*************?òMAX7219D'è?×??ú?¨8????********************
  78. void SendChar (uint8_t ch)
  79. {
  80.     uint8_t i,temp;
  81.     delay(1);
  82.     for (i=0;i<8;i++)
  83.     {
  84.         temp=ch&0x80;
  85.         ch=ch<<1;
  86.         if(temp)
  87.         {
  88.             DIN_1;
  89.             delay(1);
  90.             CLK_0;
  91.             delay(1);
  92.             CLK_1;
  93.             delay(1);
  94.         }
  95.         else
  96.         {
  97.             DIN_0;
  98.             delay(1);
  99.             CLK_0;
  100.             delay(1);
  101.             CLK_1;
  102.             delay(1);
  103.         }
  104.     }
  105. }
  106. //**************?òMAX7219D'è?×??¨16????*****************************
  107. void WriteWord (uint8_t addr,uint8_t num)
  108. {
  109.     LOAD_0;
  110.     delay(1);
  111.     SendChar(addr);
  112.     delay(1);
  113.     SendChar(num);
  114.     delay(1);
  115.     LOAD_1;                            // ??'????àó|??'??÷
  116. }
  117. //*********************** MAX72193?ê??¯ ******************
  118. void InitDisplay (void)
  119. {
  120.         WriteWord (ScanLimit,ScanDigit);         // éè??é¨?è???T
  121.         WriteWord (DecodeMode,DecodeDigit);      // éè??ò?????ê?
  122.         WriteWord (Intensity,IntensityGrade);    // éè??áá?è
  123.         WriteWord (ShutDown,NormalOperation);    // éè???a?y3?1¤×÷??ê?
  124. }
  125. /* USER CODE END PFP */
  126. /* Private user code ---------------------------------------------------------*/
  127. /* USER CODE BEGIN 0 */
  128. /* USER CODE END 0 */
  129. /**
  130.   * [url=home.php?mod=space&uid=247401]@brief[/url]  The application entry point.
  131.   * @retval int
  132.   */
  133. int main(void)
  134. {
  135.   /* USER CODE BEGIN 1 */
  136.   /* STM32U5xx HAL library initialization:
  137.        - Configure the Flash prefetch
  138.        - Configure the Systick to generate an interrupt each 1 msec
  139.        - Set NVIC Group Priority to 3
  140.        - Low Level Initialization
  141.      */
  142.   /* USER CODE END 1 */
  143.   /* MCU Configuration--------------------------------------------------------*/
  144.   /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  145.   HAL_Init();
  146.   /* USER CODE BEGIN Init */
  147.   /* USER CODE END Init */
  148.   /* Configure the system clock */
  149.   SystemClock_Config();
  150.   /* Configure the System Power */
  151.   SystemPower_Config();
  152.   /* USER CODE BEGIN SysInit */
  153.   /* USER CODE END SysInit */
  154.   /* Initialize all configured peripherals */
  155.   MX_ICACHE_Init();
  156.   /* USER CODE BEGIN 2 */
  157.    /* -1- Enable GPIO Clock (to be able to program the configuration registers) */
  158.   LED1_GPIO_CLK_ENABLE();
  159.   LED2_GPIO_CLK_ENABLE();
  160.         DIN_GPIO_CLK_ENABLE();
  161.         LOAD_GPIO_CLK_ENABLE();
  162.         CLK_GPIO_CLK_ENABLE();
  163.   /* -2- Configure IO in output push-pull mode to drive external LEDs */
  164.   GPIO_InitStruct.Mode  = GPIO_MODE_OUTPUT_PP;
  165.   GPIO_InitStruct.Pull  = GPIO_PULLUP;
  166.   GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
  167.   GPIO_InitStruct.Pin = LED1_PIN;
  168.   HAL_GPIO_Init(LED1_GPIO_PORT, &GPIO_InitStruct);
  169.   GPIO_InitStruct.Pin = LED2_PIN;
  170.   HAL_GPIO_Init(LED2_GPIO_PORT, &GPIO_InitStruct);
  171.   /* USER CODE END 2 */
  172.         GPIO_InitStruct.Pin = CLK_PIN;
  173.   HAL_GPIO_Init(CLK_GPIO_PORT, &GPIO_InitStruct);
  174.   GPIO_InitStruct.Pin = LOAD_PIN;
  175.   HAL_GPIO_Init(LOAD_GPIO_PORT, &GPIO_InitStruct);
  176.         GPIO_InitStruct.Pin = DIN_PIN;
  177.   HAL_GPIO_Init(DIN_GPIO_PORT, &GPIO_InitStruct);
  178.   /* Infinite loop */
  179.         InitDisplay (); // MAX7219???
  180.         WriteWord(DisplayTest,TestMode);  // ??????,????LED
  181.         delay(1500);                      // ???1.5s
  182.         WriteWord (DisplayTest,TextEnd);  // ????????
  183.         WriteWord (Digit0,0);
  184.         WriteWord (Digit1,1);
  185.         WriteWord (Digit2,2);
  186.         WriteWord (Digit3,3);
  187.   /* USER CODE BEGIN WHILE */
  188.   while (1)
  189.   {
  190.     /* USER CODE END WHILE */
  191.     /* USER CODE BEGIN 3 */
  192.
  193.     /* Insert delay 100 ms */
  194.     InitDisplay (); // MAX7219???
  195.                 delay(150);                      // ???1.5s
  196.                 WriteWord (DisplayTest,TextEnd);  // ????????
  197.                 WriteWord (Digit0,0);
  198.                 WriteWord (Digit1,1);
  199.                 WriteWord (Digit2,2);
  200.                 WriteWord (Digit3,3);
  201.   }
  202.   /* USER CODE END 3 */
  203. }
  204. /**
  205.   * @brief System Clock Configuration
  206.   * @retval None
  207.   */
  208. void SystemClock_Config(void)
  209. {
  210.   RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  211.   RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  212.   /** Configure the main internal regulator output voltage
  213.   */
  214.   if (HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1) != HAL_OK)
  215.   {
  216.     Error_Handler();
  217.   }
  218.   /** Initializes the CPU, AHB and APB busses clocks
  219.   */
  220.   RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_MSI;
  221.   RCC_OscInitStruct.MSIState = RCC_MSI_ON;
  222.   RCC_OscInitStruct.MSICalibrationValue = RCC_MSICALIBRATION_DEFAULT;
  223.   RCC_OscInitStruct.MSIClockRange = RCC_MSIRANGE_4;
  224.   RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  225.   RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_MSI;
  226.   RCC_OscInitStruct.PLL.PLLMBOOST = RCC_PLLMBOOST_DIV1;
  227.   RCC_OscInitStruct.PLL.PLLM = 1;
  228.   RCC_OscInitStruct.PLL.PLLN = 80;
  229.   RCC_OscInitStruct.PLL.PLLP = 2;
  230.   RCC_OscInitStruct.PLL.PLLQ = 2;
  231.   RCC_OscInitStruct.PLL.PLLR = 2;
  232.   RCC_OscInitStruct.PLL.PLLRGE = RCC_PLLVCIRANGE_0;
  233.   RCC_OscInitStruct.PLL.PLLFRACN = 0;
  234.   if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
  235.   {
  236.     Error_Handler();
  237.   }
  238.   /** Initializes the CPU, AHB and APB busses clocks
  239.   */
  240.   RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
  241.                               |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2
  242.                               |RCC_CLOCKTYPE_PCLK3;
  243.   RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  244.   RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  245.   RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  246.   RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  247.   RCC_ClkInitStruct.APB3CLKDivider = RCC_HCLK_DIV1;
  248.   if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_4) != HAL_OK)
  249.   {
  250.     Error_Handler();
  251.   }
  252. }
  253. /**
  254.   * @brief Power Configuration
  255.   * @retval None
  256.   */
  257. static void SystemPower_Config(void)
  258. {
  259.   /*
  260.    * Disable the internal Pull-Up in Dead Battery pins of UCPD peripheral
  261.    */
  262.   HAL_PWREx_DisableUCPDDeadBattery();
  263.   /*
  264.    * Switch to SMPS regulator instead of LDO
  265.    */
  266.   if (HAL_PWREx_ConfigSupply(PWR_SMPS_SUPPLY) != HAL_OK)
  267.   {
  268.     Error_Handler();
  269.   }
  270. }
  271. /**
  272.   * @brief ICACHE Initialization Function
  273.   * @param None
  274.   * @retval None
  275.   */
  276. static void MX_ICACHE_Init(void)
  277. {
  278.   /* USER CODE BEGIN ICACHE_Init 0 */
  279.   /* USER CODE END ICACHE_Init 0 */
  280.   /* USER CODE BEGIN ICACHE_Init 1 */
  281.   /* USER CODE END ICACHE_Init 1 */
  282.   /** Enable instruction cache in 1-way (direct mapped cache)
  283.   */
  284.   if (HAL_ICACHE_ConfigAssociativityMode(ICACHE_1WAY) != HAL_OK)
  285.   {
  286.     Error_Handler();
  287.   }
  288.   if (HAL_ICACHE_Enable() != HAL_OK)
  289.   {
  290.     Error_Handler();
  291.   }
  292.   /* USER CODE BEGIN ICACHE_Init 2 */
  293.   /* USER CODE END ICACHE_Init 2 */
  294. }
  295. /* USER CODE BEGIN 4 */
  296. /* USER CODE END 4 */
  297. /**
  298.   * @brief  This function is executed in case of error occurrence.
  299.   * @retval None
  300.   */
  301. void Error_Handler(void)
  302. {
  303.   /* USER CODE BEGIN Error_Handler_Debug */
  304.   /* User can add his own implementation to report the HAL error return state */
  305.   while(1)
  306.   {
  307.   }
  308.   /* USER CODE END Error_Handler_Debug */
  309. }
  310. #ifdef  USE_FULL_ASSERT
  311. /**
  312.   * @brief  Reports the name of the source file and the source line number
  313.   *         where the assert_param error has occurred.
  314.   * @param  file: pointer to the source file name
  315.   * @param  line: assert_param error line source number
  316.   * @retval None
  317.   */
  318. void assert_failed(uint8_t *file, uint32_t line)
  319. {
  320.   /* USER CODE BEGIN 6 */
  321.   /* User can add his own implementation to report the file name and line number,
  322.     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  323.   /* Infinite loop */
  324.   while (1)
  325.   {
  326.   }
  327.   /* USER CODE END 6 */
  328. }
  329. #endif /* USE_FULL_ASSERT */
效果图:
Jacquetry 发表于 2024-1-12 15:53 | 显示全部楼层
不加这驱动芯片可以吧
