串行通信问题
1824|6
 楼主| dfsa 发表于 2012-4-20 19:12 | 显示全部楼层 |阅读模式
我使用PC104总线的主板,挂一个数据采集卡,作为下位机采集模块,采集到结果通过RS485送给上位机,采用的是中断方式的串行通讯。一开始通讯正常,但是一端时间,大概发送1000次左右,下位机就会死机,反复调试都是这样,不是很明白。现在把代码贴出来,就高手指教!
void   interrupt(*oldport1isr)();
void   interrupt   ComInt()/*中断服务程序*/
unsigned   char   ReceiveFlag;
unsigned   int   cnt;
unsigned   char   panelid   =   0;
OverTimeFlag   =   0;
CheckSumReceive   =   0;
CountByte   =   0;
awresult   =   0;
tempresult   =   0;
ppmresult   =   0;
closeint();
for(cnt   =   0;   cnt   <   8;   cnt++)
CommandReceive[cnt]   =   0;
overtimejudge();
panelid   =   (unsigned   char)(para[0]);
if(OverTimeFlag   ==   0)
CommandReceive[0]   =   inport(PORT); /*First   byte   receive,if   don 't   match   panelid,return   interrupt   funtion*/
if(panelid   ==   CommandReceive[0])
panelright();
else
delay(DELAYTIME);
outportb(PORT   +   2,   0x07);
outport(0x20,   0x20);
void   readparameter()
FILE   *fp;
int   i;
fp   =   fopen( "config.ini ",   "r ");
if(fp   ==   NULL)
printf( "Can   not   open   file\n ");
for(i   =   0;   i   <   3;   i++)
fscanf(fp,   "%f ",   para   +   i);
fclose(fp);
void   senddata(char   data)
unsigned   int   i;
for(i   =   0;   i   <     SendDelayTime;   i++)
outportb(PORT   +   1,0x00); /*Turn   Off   Interrupt   */
outportb(PORT   +   4,   0x0B); /*Turn   on   DTR,RTS,OUT2,send   mode*/
outportb(PORT,   data);
void   initcom()/*串口初始化*/
outportb(PORT   +   1,   0); /*Turn   off   interrupt*/
oldport1isr   =   getvect(INTVECT); /*Save   old   interrupt   vector   for   recovery*/
setvect(INTVECT,   ComInt);
outportb(PORT   +   3,   0x80); /*Set   DLAB   on*/
outportb(PORT,0x0C); /*Set   9600   baud   rate*/
outportb(PORT   +   1,   0x00);
outportb(PORT   +   3,   0x3B); /*8   bits,1   parity,1   stop   bit   */
outportb(PORT   +   4,0x0A); /*Turn   off   DTR,Turn   on   RTS,OUT2,receive   mode*/
void   openint()/*开中断*/
outportb(0x21,   (inportb(0x21)   &   0xF7)); /*Set   programmable   interrupt   controller*/
outportb(PORT   +   1,   0x01); /*Interrupt   when   data   received*/
void   closeint()/*关中断*/
outportb(PORT   +   1,0);                                                       /*Turn   off   Com2   interrupt*/
outport(0x21,   (inportb(0x21)   |   0x08));
void   panelright()/*下位机判断是否命令是自己的板号*/
unsigned   char   i;
for(i   =   1;   i <   7;   i++)
receive6commandbyte(i);
if(OverTimeFlag   !=   0)
break;
if(CountByte   ==   6)
receive6bytecomplete();
void   receive6commandbyte(unsigned   char   order)
overtimejudge();
CommandReceive[order]   =   inport(PORT);
CheckSumReceive   +=   CommandReceive[order];
CountByte++;
void   receive6bytecomplete()
overtimejudge();
CommandReceive[7]   =   inport(PORT);
if(CommandReceive[7]   ==   CheckSumReceive)
if(BeginJudge   ==   0)
beginmeasure();
else
sendresult();
else
checksumwrong();
void   sendresult()
      /*发送测量结果*/
void   beginmeasure()
/*开始测量*/
void   beginsucess()
          /*返回启动测试成功的信息*/
void   checksumwrong()
    /*上位机命令校验和出错后下位机返回出错信息*/
void   overtimejudge()/*上位机命令是8个字节,判断有没有接收超时*/
unsigned   long   cnt   =   0;
do
ReceiveFlag   =   inport(PORT   +   5);
cnt++;
if(cnt   >   TimeExceed) /*Overtime   judge,wait   for   300ms*/
OverTimeFlag   =   1;
break;
while(!(ReceiveFlag&1));
unsigned   int   sample(int   chx)
    /*开始采样*/
void   main()
clrscr();
arrayinit();
readparameter();
enable_gpio();
initcom();
openint();
while(1)         /*一直等待上位机命令*/
initcom();
openint();
delay(DELAYTIME);
feedDog();
setvect(INTVECT,   oldport1isr);
pkat 发表于 2012-4-20 19:25 | 显示全部楼层
太长了:L
火箭球迷 发表于 2012-4-20 19:34 | 显示全部楼层
的确是太长了,LZ精炼一下
vivilzb1985 发表于 2012-4-22 15:28 | 显示全部楼层
汗颜啊,太长了源码,看的是不明不白的啊
shenmu2012 发表于 2012-4-22 16:10 | 显示全部楼层
这个貌似是上位机软件代码的吧,,求解
mohanwei 发表于 2012-4-22 16:42 | 显示全部楼层
自己把注释加全,也就搞定了
firstblood 发表于 2012-4-26 18:05 | 显示全部楼层
同意6楼的观点的啊,些代码的时候养成加注释的习惯是非常好的啊
