使用RTThreadNano 版本, board.c中的代码 /* Copyright (c) 2006-2019, RT-Thread Development Team SPDX-License-Identifier: Apache-2.0 Change Logs:
Date Author Notes
2021-05-24 the first version
#include <rthw.h>
#include <rtthread.h>
#include "main.h"
#if defined(RT_USING_USER_MAIN) && defined(RT_USING_HEAP)
Please modify RT_HEAP_SIZE if you enable RT_USING_HEAP
the RT_HEAP_SIZE max value = (sram size - ZI size), 1024 means 1024 bytes
#define RT_HEAP_SIZE (151024)
static rt_uint8_t rt_heap[RT_HEAP_SIZE];
RT_WEAK void rt_heap_begin_get(void)
return rt_heap;
RT_WEAK void rt_heap_end_get(void)
return rt_heap + RT_HEAP_SIZE;
#elif defined (RT_USING_USER_MAIN)&&defined(RT_USING_MEMHEAP)
#define RT_HEAP_RAM_SIZE (151024)
static rt_uint8_t rt_heap_ram[RT_HEAP_RAM_SIZE];
#define RT_HEAP_EXRAM_SIZE (8001024)
static rt_uint8_t rt_heap_exram[RT_HEAP_EXRAM_SIZE] __attribute((used,section("EXRAM")));
struct rt_memheap Strucmem;
#endif
void SysTick_Handler(void)
rt_interrupt_enter();
rt_tick_increase();
rt_interrupt_leave();
This function will initial your board.
void rt_hw_board_init(void)
extern void SystemClock_Config(void);
HAL_Init();
SystemClock_Config();
SystemCoreClockUpdate();
1: OS Tick Configuration
Enable the hardware timer and call the rt_os_tick_callback function
periodically with the frequency RT_TICK_PER_SECOND.
HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/RT_TICK_PER_SECOND);
/ Call components board initial (use INIT_BOARD_EXPORT()) /
#ifdef RT_USING_COMPONENTS_INIT
rt_components_board_init();
#endif
rt_system_heap_init(rt_heap_begin_get(), rt_heap_end_get());
rt_memheap_init(&Strucmem,"memram", rt_heap_ram, RT_HEAP_RAM_SIZE);
//rt_memheap_init(&Strucmem,"memexram", rt_heap_exram, RT_HEAP_EXRAM_SIZE);
#endif
#ifdef RT_USING_CONSOLE
static UART_HandleTypeDef UartHandle;
static int uart_init(void)
/ TODO: Please modify the UART port number according to your needs */
UartHandle.Instance = USART1;
UartHandle.Init.BaudRate = 115200;
UartHandle.Init.WordLength = UART_WORDLENGTH_8B;
UartHandle.Init.StopBits = UART_STOPBITS_1;
UartHandle.Init.Parity = UART_PARITY_NONE;
UartHandle.Init.Mode = UART_MODE_TX_RX;
UartHandle.Init.HwFlowCtl = UART_HWCONTROL_NONE;
UartHandle.Init.OverSampling = UART_OVERSAMPLING_16;
if (HAL_UART_Init(&UartHandle) != HAL_OK)
while (1);
return 0;
INIT_BOARD_EXPORT(uart_init);
void rt_hw_console_output(const char str)
rt_size_t i = 0, size = 0;
char a = '\r';
__HAL_UNLOCK(&UartHandle);
size = rt_strlen(str);
for (i = 0; i < size; i++)
if ((str + i) == '\n')
HAL_UART_Transmit(&UartHandle, (uint8_t *)&a, 1, 1);
HAL_UART_Transmit(&UartHandle, (uint8_t )(str + i), 1, 1);
#endif
#ifdef RT_USING_FINSH
char rt_hw_console_getchar(void)
/ Note: the initial value of ch must < 0 */
int ch = -1;
if (__HAL_UART_GET_FLAG(&UartHandle, UART_FLAG_RXNE) != RESET)
ch = UartHandle.Instance->DR & 0xff;
else
rt_thread_mdelay(10);
return ch;
#endif
其中只要一把屏蔽的 //rt_memheap_init(&Strucmem,"memexram", rt_heap_exram,
打开,即只要一初始化片外sram 就会死机,我该如何查呢 ?
其中,片外sram 使用的fsmc 驱动
