今天搞了一下TN9,TN9是红外测温模块。
截取一部分数据手册:
ACK接PC9,DATA接PC7,CLK接PC8.
代码:
- #include "main.h"
- #include <stdio.h>
- #include <string.h>
- /** @addtogroup Examples
- #define uchar unsigned char
- #define uint unsigned int
- void ACK_0() { GPIO_ResetBit(ACK_GPIO_PORT,GPIO_PIN_9);} //
- void ACK_1() { GPIO_SetBit(ACK_GPIO_PORT,GPIO_PIN_9);}
- #define DATA GPIO_ReadInputBit(DATA_GPIO_PORT,DATA_PIN)
- #define CLOCK GPIO_ReadInputBit(CLOCK_GPIO_PORT,CLOCK_PIN)
- float Temp;
- float Temp1,Temp2;
- uchar ReadData[5];
- uint bai,shi,ge;
- uint a,b;
- volatile uint32_t tick = 0;
- uint8_t txBuf1[] = "Body temperature=: \r\nAmbient temperature=: \r\n";
- char txBuf2[4] = {};
- //????:Delay()
- void Delay1(unsigned char us) //5,7,9
- while(--us);
- //????:Delayms()
- void Delayms(unsigned int ims)
- unsigned int i,j;
- for(i=0;i<ims;i++)
- for(j=0;j<65;j++) { Delay1(1); }
- void TN_IRACK_EN(void)
- ACK_0();
- Delay1(1);
- void TN_IRACK_UN(void)
- ACK_1();
- Delay1(1);
- void InitIO(void)
- GPIO_Config_T configStruct;
- /* Enable the GPIO_LED Clock */
- RCM_EnableAPB2PeriphClock(RCM_APB2_PERIPH_GPIOC);
- /* Configure the GPIO_LED pin */
- configStruct.pin = ACK_PIN;
- configStruct.mode = GPIO_MODE_OUT_PP;
- configStruct.speed = GPIO_SPEED_50MHz;
- GPIO_Config(GPIOC, &configStruct);
- configStruct.pin = DATA_PIN | CLOCK_PIN;
- configStruct.mode = GPIO_MODE_IN_FLOATING;
- void TN_ReadData(unsigned char Flag)
- unsigned char i,j,k,BitState=0;
- for(k=0;k<7;k++)
- for(j=0;j<5;j++)
- for(i=0;i<8;i++)
- while(1)
- if(CLOCK==0)
- break;
- Delay1(1);
- Delay1(1);
- if(DATA==1)
- BitState=1;
- else
- BitState=0;
- ReadData[j]= ReadData[j]<<1;
- ReadData[j]= ReadData[j]|BitState;
- Delay1(1);
- while(1)
- if(CLOCK==1)
- break;
- Delay1(1);
- if(ReadData[0]==Flag)
- k=8;
- TN_IRACK_UN();
- float TN_GetData(unsigned char X)
- //Ack_Clk_Data_init;
- InitIO();
- TN_ReadData(X);
- Temp=(ReadData[1]<<8)|ReadData[2];
- Temp=(float)Temp/16.00-273.15;
- return Temp;
- float TN_GetTemp(unsigned char mode)
- float T;
- TN_IRACK_UN();
- TN_IRACK_EN();
- if(mode==0)
- T=TN_GetData(0x4c);
- else
- T=TN_GetData(0x66);
- return T;
- /** @addtogroup USART_Printf
- /** @addtogroup USART_Printf_Variables Variables
- /**@} end of group USART_Printf_Variables */
- /** @addtogroup USART_Printf_Functions Functions
- * [url=home.php?mod=space&uid=247401]@brief[/url] Main program
- * @param None
- * @retval None
- int main(void)
- uint8_t i;
- GPIO_Config_T GPIO_ConfigStruct;
- USART_Config_T USART_ConfigStruct;
- APM_MINI_LEDInit(LED2);
- RCM_EnableAPB2PeriphClock((RCM_APB2_PERIPH_T)(RCM_APB2_PERIPH_GPIOA | RCM_APB2_PERIPH_USART1));
- GPIO_ConfigStruct.mode = GPIO_MODE_AF_PP;
- GPIO_ConfigStruct.pin = GPIO_PIN_9;
- GPIO_ConfigStruct.speed = GPIO_SPEED_50MHz;
- GPIO_Config(GPIOA, &GPIO_ConfigStruct);
- USART_ConfigStruct.baudRate = 115200;
- USART_ConfigStruct.hardwareFlow = USART_HARDWARE_FLOW_NONE;
- USART_ConfigStruct.mode = USART_MODE_TX;
- USART_ConfigStruct.parity = USART_PARITY_NONE;
- USART_ConfigStruct.stopBits = USART_STOP_BIT_1;
- USART_ConfigStruct.wordLength = USART_WORD_LEN_8B;
- USART_Config(USART1, &USART_ConfigStruct);
- USART_Enable(USART1);
- SysTick_Config(SystemCoreClock / 1000);
- while(1)
- Temp1=TN_GetTemp(0);
- Temp2=TN_GetTemp(1);
- sprintf(txBuf2,"%.1f",Temp1);
- txBuf1[18]=txBuf2[0];
- txBuf1[19]=txBuf2[1];
- txBuf1[20]=txBuf2[2];
- txBuf1[21]=txBuf2[3];
- sprintf(txBuf2,"%.1f",Temp2);
- txBuf1[45]=txBuf2[0];
- txBuf1[46]=txBuf2[1];
- txBuf1[47]=txBuf2[2];
- txBuf1[48]=txBuf2[3];
- for(i = 0; i < sizeof(txBuf1); i++)
- while(USART_ReadStatusFlag(USART1, USART_FLAG_TXBE) == RESET);
- USART_TxData(USART1, txBuf1[i]);
- Delayms(500);
- APM_MINI_LEDToggle(LED2);
- * @brief Delay
- * @param None
- * @retval None
- void Delay(void)
- tick = 0;
- while(tick < 500);
效果图:
