[无线通信] Wallys 2×2.4GHz 2x5GHz #MT7915 #MT7975 /support openwrt
971|0
 楼主| Cindy@wallys 发表于 2023-2-21 16:53 | 显示全部楼层 |阅读模式
DR7915
MT7915+MT7975 Chipset
2.4GHz max 23dBm & 5GHz max 20dBm output power
IEEE 802.11ac / ax compliant & backward compatible with 802.11ax/ac/a/b/g/n
2×2 2.4G & 2×2 5G  MIMO Technology, up to 1.8Gbps Mini PCI Express edge connector
SupporttheFrequency2412MHz~2482MHz
SupporttheFrequency5180MHz~5825MHz
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Supports Spatial Multiplexing,Cyclic-Delay Diversity (CDD), Low-Density Parity Check  (LDPC) Codes,Maximal Ratio Combining (MRC), Space Time Block Code (STBC)
Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards
Supports Dynamic Frequency Selection (DFS)
CardsareindividuallycalibratedforQualityAssurance
The MT7915+MT7975 chipset is a 2.4GHz and 5GHz 802.11ac/ax compliant and backward compatible with 802.11ax/ac/a/b/g/n wireless networking solution. The chipset offers both 2×2 MIMO technology and high-end features such as IEEE 802.11d, e, h, i, k, r, v time stamp, w standards support and dynamic frequency selection (DFS).
It comes with 2×2 2.4G & 2×2 5G MIMO Technology which provides up to 1.8Gbps data rate for the distance of up to 100 meters indoor or 400 meters outdoor. This ensures that you get the best performance in your home or office environment without any interference from other devices nearby.
The MT7915+MT7975 is RoHS compliant and so it is guaranteed a high level protection of human health and the environment from risks that can be posed by chemicals like lead or mercury resulting from improper disposal of old products in landfills or even incineration at waste facilities (such as hospitals).
Wallys Communications (Suzhou ) Co., LTDis a professional supplier of wireless communication products and has a complete industrial chain in China.
Its main business is to design and manufacture the latest industrial wireless products, such as router boards, network interface cards, access points, etc., with a wide range of industrial applications.Our biggest advantage is our independent research and development ability.We can provide one-stop customized solutions according to customers’ detailed requirements.
Recently, our company launched many new products, such as Antenna (DRA24126ESBE),DR6018-S,DR6018C V01,DR8072 V01,DR40X9,DR9074-6E,DR9074-5G and so on.
