[N32G45x] 国民技术MCU产品(N32G452/N32G455/N32G457系列
837|0
 楼主| 断桥不断 发表于 2023-2-22 19:00 | 显示全部楼层 |阅读模式
国民技术Roadmap:
封装尺寸:
WLCSP
UFQFPN20
QFN20
QFN32
QFN40
QFN48
QFN64
3mm*3mm
3mm*3mm/
4mm*4mm
4mm*4mm/
5mm*5mm
5mm*5mm
6mm*6mm
8mm*8mm
QFN88
LQFP32
LQFP48
LQFP64
LQFP80
LQFP100
LQFP128
10mm*10mm
7mm*7mm
7mm*7mm
10mm*10mm
12mm*12mm
14mm*14mm
14mm*14mm
MCU命名规则:
N:公司简称
32:处理器位宽(32 = 32bit)
G:产品家族(G=通用;L=低功耗;WB=无线蓝牙;M=电机控制;A=汽车级)
4:处理器内核(4=ARM Cortex-M4F;0=ARM Cortex-M0)
52:产品系列(x0=超值系列;x2=基本系列;x3/5=增强系列;x6=LCD系列;x7=互联系列;FR=指纹识别系列)
R:引脚个数(F=20脚;P=25脚;K=32脚;C=48脚;R=64脚;M=80脚;V=100脚;Q=128脚)
B:Flash容量(6=32KB Flash ;8=64KB Flash ;B=128KB Flash ;C=256KB Flash ;E=512KB Flash)
L:封装(L=LQFP;Q=QFN;W=WLCSP;S=TSSOP;U=UFQFPN)
7:温度等级(6=-40~+85°C;7=-40~+105°C)
N32G45x 系列MCU选型表(展示仅部分型号,完整内容请下载附件查看)
产品系列产品型号主频MHzFlash(KB)SRAM(KB)I/O定时器PWM通道数ADCDAC
定时器RTCPWM互补PWM个数*精度通道数
N32G452N32G452CBL71441288037812362x12bit102x12bit
N32G452CCL714425614437812362x12bit102x12bit
N32G452RBL714412880518124122x12bit162x12bit
N32G452RCL7144256144518124122x12bit162x12bit
N32G452REL7144512144518124122x12bit162x12bit
N32G452MBL714412880678124122x12bit162x12bit
N32G452MCL7144256144678124122x12bit162x12bit
N32G452MEL7144512144678124122x12bit162x12bit
N32G452VCL7144256144808124122x12bit162x12bit
N32G452VEL7144512144808124122x12bit162x12bit
N32G452QCL7144256144978124122x12bit182x12bit
N32G452QEL7144512144978124122x12bit182x12bit
N32G455N32G455CBL71441288037812364x12bit162x12bit
N32G455CCL714425614437812364x12bit162x12bit
N32G455RBL714412880518124124x12bit222x12bit
N32G455RCL7144256144518124124x12bit222x12bit
N32G455REL7144512144518124124x12bit222x12bit
N32G455MBL714412880678124124x12bit332x12bit
N32G455MCL7144256144678124124x12bit332x12bit
N32G455MEL7144512144678124124x12bit332x12bit
N32G455VBL714412880808124124x12bit382x12bit
N32G455VCL7144256144808124124x12bit382x12bit
N32G455VEL7144512144808124124x12bit382x12bit
N32G457N32G457RCL7144256144518124124x12bit222x12bit
N32G457REL7144512144518124124x12bit222x12bit
N32G457MCL7144256144678124124x12bit332x12bit
N32G457MEL7144512144678124124x12bit332x12bit
N32G457VCL7144256144808124124x12bit382x12bit
N32G457VEL7144512144808124124x12bit382x12bit
N32G457QEL7144512144978124124x12bit402x12bit
