[技术问答] 小华单片机HC32F460的跑官方例程时会发送不成功
712|3
 楼主| luckyren 发表于 2023-3-2 10:41 | 显示全部楼层 |阅读模式
目前在调试HC32F460时会卡在如下代码:while (CAN_GetStatus(CAN_UNIT, CAN_FLAG_STB_TX) == RESET) { },有人指点一下吗?
  1. static void CanTx(void)
  3.     uint8_t i;
  4.     static uint8_t u8Data;
  5.     for (i = 0U; i < CAN_TX_DATA_SIZE; i++) {
  6.         m_stcTx1.au8Data[i] = u8Data++;
  7.         m_stcTx2.au8Data[i] = u8Data++;
  8.         m_stcTx3.au8Data[i] = u8Data++;
  9.     }
  10.     /* Frame with CAN_ID1 */
  11.     m_stcTx1.u32Ctrl = 0x0UL;
  12.     m_stcTx1.u32ID   = CAN_TX_ID1;
  13.     m_stcTx1.IDE     = CAN_TX_ID1_IDE;
  14.     m_stcTx1.DLC     = CAN_TX_DLC;
  15.     (void)CAN_FillTxFrame(CAN_UNIT, CAN_TX_BUF_PTB, &m_stcTx1);
  16.     /* Start PTB TX */
  17.     CAN_StartTx(CAN_UNIT, CAN_TX_REQ_PTB);
  18.     /* Check transmission end. */
  19.     while (CAN_GetStatus(CAN_UNIT, CAN_FLAG_PTB_TX) == RESET) { }
  20.     CAN_ClearStatus(CAN_UNIT, CAN_FLAG_PTB_TX);
  21.     /* Frame with CAN_ID2 */
  22.     m_stcTx2.u32Ctrl = 0x0UL;
  23.     m_stcTx2.u32ID   = CAN_TX_ID2;
  24.     m_stcTx2.IDE     = CAN_TX_ID2_IDE;
  25.     m_stcTx2.DLC     = CAN_TX_DLC;
  26.     (void)CAN_FillTxFrame(CAN_UNIT, CAN_TX_BUF_STB, &m_stcTx2);
  27.     /* Frame with CAN_ID3 */
  28.     m_stcTx3.u32Ctrl = 0x0UL;
  29.     m_stcTx3.u32ID   = CAN_TX_ID3;
  30.     m_stcTx3.IDE     = CAN_TX_ID3_IDE;
  31.     m_stcTx3.DLC     = CAN_TX_DLC;
  32.     (void)CAN_FillTxFrame(CAN_UNIT, CAN_TX_BUF_STB, &m_stcTx3);
  33.     /* Start STB TX */
  34.     CAN_StartTx(CAN_UNIT, CAN_TX_REQ_STB_ALL);
  35.     /* Check transmission end. */
  36.     while (CAN_GetStatus(CAN_UNIT, CAN_FLAG_STB_TX) == RESET) { }
  37.     CAN_ClearStatus(CAN_UNIT, CAN_FLAG_STB_TX);
  38. }
wubangmi 发表于 2023-3-2 11:05 | 显示全部楼层
请去官网下最新的库
 楼主| luckyren 发表于 2023-3-2 11:09 | 显示全部楼层
请去官网下最新的库
为什么在另一块板子上就没有问题,这个应该不是库的问题吧
换个CAN驱动芯片试试,可能是硬件原因。  发表于 2023-3-2 16:39
