液晶图形显示实例
2043|6
tianli1980|  楼主 | 2012-4-21 21:59 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
点阵图形液晶显示模块除信息外,另一个优势是可以显示图形。现在介绍的是单色液晶,只能显示黑白图形,因此需要首先将图片转化为黑白图。图形的点点阵信息可以逐个查看像素点的黑白值。为了更快地得到图像的点阵信息,得到任何一个图形的点阵信息,可以选择一款字模提取程序,从中打开黑白图像即可。
使用液晶显示图形的程序代码示例如下
#include<reg52.h>
#include<stdio.h>
unsigned data i;
unsigned char q;
unsigned char *p2;    //建立数组指针
unsigned char wbyte;
unsigned char Column;   //定义列
unsigned char Page;    //定义页
sbit E=P3^2;     //读写使能信号,1有效
sbit R_W=P3^1;    //读写选择信号;1为读选通,0为写选通
sbit RS=P3^0;
sbit D_I=P3^0;     //数据指令选择信号;1为数据操作,0为写指令或读状态
unsigned char data j;
unsigned char data k;
/********************扩充指令集画图********************/
unsigned char data z;   //图形数组的页,为实际点阵行数
unsigned char data y;   //图形数组的列,为实际点阵列数除以8
unsigned char data Column;  //起始点设定:为在液晶中显示的实际起始列
unsigned char data Page;   //起始点设定:为在液晶中显示的实际起始行
char code Tu[64][16]=    //图形数组,龙的标志
0x00,0x30,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xFF,
0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xFF,0xC0,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x03,0xFF,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xFF,0xF0,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x07,0xFF,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0xFC,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x07,0xFF,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,
0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x0F,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xFF,0xC0,
0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xFF,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,
0x0F,0xFF,0xFF,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xFF,0xE0,0x00,0x00,
0x00,0x00,0x00,0x00,0x0F,0xFF,0xFF,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,
0xFF,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xFF,0xF8,0x80,0x00,0x00,0x00,
0x00,0x00,0x1F,0xFF,0xFF,0xF8,0x80,0x00,0x00,0x00,0x00,0x00,0x1F,0xFF,0xFF,0xF8,
0x80,0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xFF,0xF8,0x80,0x00,0x00,0x00,0xFF,0x1C,
0x0F,0xFF,0xFF,0xFC,0x80,0x00,0x00,0x07,0xFF,0x1F,0x0F,0xFF,0xFF,0xFC,0x80,0x06,
0x00,0x3F,0xFF,0x1F,0x0F,0xFF,0xFF,0xFE,0x80,0x06,0x03,0xFF,0xFF,0x1F,0x07,0xFF,
0xFF,0xFE,0x80,0x04,0x07,0xFF,0xFF,0x1F,0x07,0xFF,0xFF,0xFE,0xC0,0x1C,0x3F,0xFF,
0xFF,0x1F,0x07,0xFF,0xFF,0xFE,0x60,0x30,0xFF,0xFF,0xFF,0x1F,0x07,0xFF,0xFF,0xFE,
0x20,0xE1,0xFF,0xFF,0xFF,0x1F,0x07,0xFF,0xFF,0xFE,0x23,0x87,0xFF,0xFF,0xFF,0x1F,
0x03,0xFF,0xFF,0xFF,0x26,0x1F,0xFF,0xFF,0xFF,0x1E,0x01,0xFF,0xFF,0xFF,0x24,0x3F,
0xFF,0xFF,0xFF,0x1E,0x01,0xFF,0xFF,0xFF,0xFC,0xFF,0xFF,0xFF,0xFF,0x1E,0x00,0x3F,
0xFF,0xFF,0xF8,0xFF,0xFF,0xFF,0xFF,0x1C,0x00,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0x18,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x10,0x07,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0x10,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,
0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFE,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x00,0x7F,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFC,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x00,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xF0,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x80,0x00,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x80,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0x00,0x00,0x7F,0xFF,
0xF9,0xFF,0xFF,0xFF,0xFF,0xF0,0x00,0x00,0x7F,0xFF,0xFB,0xFF,0xFF,0xFF,0xFB,0xC0,
0x00,0x00,0x7F,0xFF,0xEF,0xFF,0xFF,0xFF,0xFC,0x00,0x00,0x00,0x1F,0xFF,0x99,0xFB,
0xFF,0xFF,0xFC,0x00,0x00,0x00,0x3F,0xFF,0xBB,0xFB,0xFF,0xFF,0xFE,0x00,0x00,0x00,
0x3F,0xFF,0xF7,0x7B,0x9F,0xFF,0xFF,0x00,0x00,0x00,0x07,0xFE,0xCE,0x7B,0xDF,0xFF,
0xFF,0x00,0x00,0x00,0x07,0xFF,0xDE,0x7B,0xDF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x1F,
0xB8,0x62,0xFF,0xFF,0xFE,0x00,0x00,0x00,0x00,0x1E,0x30,0x02,0x7F,0xFF,0xFE,0x00,
0x00,0x00,0x00,0x0F,0xE0,0x02,0x7F,0xFF,0xFF,0x00,0x00,0x00,0x00,0x07,0x80,0x02,
0x7F,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x7F,0xFF,0xFF,0x00,0x00,0x00,
0x00,0x00,0x00,0x03,0x7F,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x3F,0xFF,
0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x3F,0xFF,0xFC,0x00,0x00,0x00,0x00,0x00,
0x00,0x03,0x3F,0xFF,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xBF,0xFF,0xE0,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0xFC,0xFF,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0xFF,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xC0,0x00,0x00,0x00
void WCOM(unsigned char dcode);  //指令操作子函数
void Dat(unsigned char ddata);  //数据操作子函数
void Imim();     //初始化子函数
void EClearlcd();    //扩充指令集清屏子函数
void Tuxing();    //图形显示子函数
void main()
Imim();      //初始化
z=64;      //图形数组的页,为实际点阵行数
y=16;      //图形数组的列,为实际点阵列数除以8
Column=0;     //起始点设定:为在液晶中显示的实际起始列
Page=0;      //起始点设定:为在液晶中显示的实际起始行
p2=Tu;      //图形数组
Tuxing();         //蝴蝶图案
while(1)
void WCOM(unsigned char dcode)     //写指令程序
unsigned char q;
R_W=1;
D_I=0;      //设置状态
Loop:
P1=0xFF;
E=1;      //使能有效
q=P1;      //将P1口状态读入
E=0;      //关闭使能信号
if(q&0x80)     //判断屏幕是否忙
goto Loop;     //若忙,循环等待
R_W=0;
D_I=0;      //写数据指令
P1= dcode;     //将数据送入P1口
E=1;      //使能信号开
E=0;      //使能信号关
unsigned char q;
R_W=1;
D_I=0;      //读状态指令
Loop:
P1=0xFF;
E=1;      //使能
q=P1;
E=0;
if(q&0x80)     //判忙
goto Loop;
D_I=1;      //送数据指令
R_W=0;
P1= ddata;     //写入数据
E=1;      //使能信号开
E=0;      //使能信号关
void Clearlcd()
D_I=0;
R_W=0;
P1=0x01;
WCOM(0x01);     //清除显示
void Imim()
P0=0xFF;     //初始化单片机端口
P1=0xFF;
P2=0xFF;
P3=0xFF;
E=0;
WCOM(0x38);     //功能设定
WCOM(0x08);     //关显示指令
WCOM(0x06);     //游标右移
Clearlcd();     //清屏
WCOM(0x0c);     //开显示指令
void Tuxing()
unsigned char data v;
unsigned char data w;
unsigned char data x;
unsigned char data h;
unsigned char *pp;    //图形数组指针
WCOM(0x34);     //功能设定
WCOM(0x36);     //扩充功能设定
pp=p2;
pp=pp+16*y*2;
for(h=0;h<z/2;h++)     //页循环
  v=Column|0x80;
  w=Page|0x80;
  WCOM(w);     //送入起始页地址
  WCOM(v);     //送入起始列地址
  Page++;      //准备对下一页进行操作
  for(x=0;x<2*y;x++)    //列循环
    if(x<y)
     wbyte=*p2;
     Dat(wbyte);    //循环送入图形数据
     p2=p2+1;
    else
      wbyte=*pp;
      pp=pp+1;
void EClearlcd()
  unsigned char data Disp_Page;
  unsigned char data i;
  for(i=0;i<64;i++)    //共32页
   Disp_Page=i|0x80;   //设置页地址
   WCOM(Disp_Page);   //送入页地址
   WCOM(0x80);    //送入起始列地址
   for(j=0;j<32;j++)
    Dat(0x00);     //清屏
shenmu2012| | 2012-4-22 16:16 | 只看该作者
这个比较好,有引导意义的,学习下
jxmzzr| | 2012-4-22 20:45 | 只看该作者
很实用的资料,对进行设计很有帮助。谢谢楼主,学习了。
joing1999| | 2012-4-23 14:21 | 只看该作者
支持支持!
ji7423| | 2012-4-23 14:52 | 只看该作者
不错。支持·!~
jiang390625| | 2012-4-23 15:31 | 只看该作者
支持!学习下
拿起书本| | 2012-4-24 21:51 | 只看该作者
液晶显示在单片机系统中应用广泛,很有指导意义。
