[技术问答]
MA35D1的USB Host 过流保护Pin改为普通GPIO
248|1
两只袜子|  楼主 | 2023-3-6 14:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
jcky001| | 2023-3-6 14:44 | 只看该作者
修改linux代码
inux-5.4.y/drivers/usb/host/ehci-ma35d1.c
linux-5.4.y/drivers/usb/host/ohci-ma35d1.c
ehci-ma35d1.c
    regmap_write(ma35d1_ehci->sysregmap, REG_SYS_MISCFCR0, (reg & ~(1<<12)));
改为
    regmap_write(ma35d1_ehci->sysregmap, REG_SYS_MISCFCR0, (reg | (1<<12)));
ohci-ma35d1.c
        regmap_write(ma35d1_ohci->sysregmap, REG_SYS_MISCFCR0, (reg & ~(1<<12)));
改为
    regmap_write(ma35d1_ohci->sysregmap, REG_SYS_MISCFCR0, (reg | (1<<12)));
    2.配置内核设备树
    修改linux-custom/arch/arm64/boot/dts/nuvoton/ma35d1-som-256m.dts 里面的
hsusbh {
                pinctrl_hsusbh: hsusbhgrp{
                        nuvoton,pins =
                                <SYS_GPL_MFPH_PL12MFP_HSUSBH_PWREN &pcfg_default>,
                                <SYS_GPL_MFPH_PL13MFP_HSUSBH_OVC &pcfg_default>;
改为以下
hsusbh {
                        nuvoton,pins =
                                < SYS_GPL_MFPH_PL12MFP_GPIO &pcfg_default>,
                                < SYS_GPL_MFPH_PL13MFP_GPIO &pcfg_default>;
