链表问题
1784|1
 楼主| gxgclg 发表于 2012-4-22 19:22 | 显示全部楼层 |阅读模式
双向链表数据输出错误
[code=C/C++][/code]
#include "iostream"
#include "stdlib.h"
#define OK 1
#define ERROR -1
typedef int Elemtype;
typedef int Stutaus;
using namespace std;
typedef struct DuLNode
int data;
struct DuLNode *next,*prior;
}DuLNode,*DuLinkList;
void Create_L(DuLinkList &L,int n)
L=(DuLinkList)malloc(sizeof(DuLNode));
L->next=L->prior=L;
for(int i=n;i>0;--i)
DuLNode *p=(DuLinkList)malloc(sizeof(DuLNode));
cin>>(p->data);
//p->next=L->next;
//L->next=p;
p->prior=L->next;
p=L->prior;
L->prior=p->next;
L=p->prior;
//p=L->next->prior;
//L->next->prior=p;
void Print_L(DuLinkList &L,int n)
  DuLinkList p;
int i=0;
  p=L;
while (i<n)
++i;
//p=p->next;
cout<<p->data;
cout<<endl;
void main()
int n;
DuLinkList La;
cout<<"please input data num: "<<endl;
cin>>n;
Create_L(La,n);
cout<<"data is:"<<endl;
Print_L(La,n);
baidudz 发表于 2012-4-22 19:32 | 显示全部楼层
链表需要自己多琢磨,多用笔画画,不好说清楚的.
