[STM32U5] 【NUCLEO-U575ZI-Q测评】红外+串口打印
880|2
 楼主| 比神乐 发表于 2023-3-12 13:54 | 显示全部楼层 |阅读模式
我今天搞了一下红外,把PC10接到STM8开发板的红外腿上。
原理图:
STM32U5:
3.jpg STM8:
主程序代码:
  1. #include "main.h"
  2. /* Private includes ----------------------------------------------------------*/
  3. /* USER CODE BEGIN Includes */
  4. /* USER CODE END Includes */
  5. /* Private typedef -----------------------------------------------------------*/
  6. /* USER CODE BEGIN PTD */
  7. /* USER CODE END PTD */
  8. /* Private define ------------------------------------------------------------*/
  9. /* USER CODE BEGIN PD */
  10. /* USER CODE END PD */
  11. /* Private macro -------------------------------------------------------------*/
  12. /* USER CODE BEGIN PM */
  13. /* USER CODE END PM */
  14. #define TXBUFFERSIZE                      (COUNTOF(aTxBuffer)+4)
  15. /* USER CODE END Includes */
  16. uint8_t aTxBuffer[] = "Key value:0x        \r\n    ";
  17. /* Private variables ---------------------------------------------------------*/
  18. TIM_HandleTypeDef htim1;
  19. UART_HandleTypeDef huart2;
  20. u16 Interval_tim1=0;
  21. uint8_t Data[8];
  22. /* USER CODE BEGIN PV */
  23. /* USER CODE END PV */
  24. typedef void (* BSP_EXTI_LineCallback)(void);
  25. /* Private function prototypes -----------------------------------------------*/
  26. void SystemClock_Config(void);
  27. static void SystemPower_Config(void);
  28. static void MX_GPIO_Init(void);
  29. static void MX_TIM1_Init(void);
  30. static void MX_USART2_UART_Init(void);
  31. /* USER CODE BEGIN PFP */
  32. /* USER CODE END PFP */
  33. static void MX_ICACHE_Init(void)
  34. {
  35.   /* USER CODE BEGIN ICACHE_Init 0 */
  36.   /* USER CODE END ICACHE_Init 0 */
  37.   /* USER CODE BEGIN ICACHE_Init 1 */
  38.   /* USER CODE END ICACHE_Init 1 */
  39.   /** Enable instruction cache in 1-way (direct mapped cache)
  40.   */
  41.   if (HAL_ICACHE_ConfigAssociativityMode(ICACHE_1WAY) != HAL_OK)
  42.   {
  43.     Error_Handler();
  44.   }
  45.   if (HAL_ICACHE_Enable() != HAL_OK)
  46.   {
  47.     Error_Handler();
  48.   }
  49.   /* USER CODE BEGIN ICACHE_Init 2 */
  50.   /* USER CODE END ICACHE_Init 2 */
  51. }
  52. /* Private user code ---------------------------------------------------------*/
  53. /* USER CODE BEGIN 0 */
  54. /* USER CODE END 0 */
  55. void HAL_GPIO_EXTI_Falling_Callback(uint16_t GPIO_Pin)
  56. {
  57.         if (GPIO_Pin == GPIO_PIN_10)
  58.   {
  59.                 VS838_Receive_Handle();
  60.         }
  61.         //HAL_UART_Transmit(&huart2, (uint8_t *)aTxBuffer8, 5, 5000);
  62. }
  63. static void MX_GPIO_EXTI_Init(void)
  64. {
  65.   GPIO_InitTypeDef GPIO_InitStruct = {0};
  66. /* USER CODE BEGIN MX_GPIO_Init_1 */
  67. /* USER CODE END MX_GPIO_Init_1 */
  68.   /* GPIO Ports Clock Enable */
  69.   __HAL_RCC_GPIOC_CLK_ENABLE();
  70.   /*Configure GPIO pin : PC10 */
  71.   GPIO_InitStruct.Pin = GPIO_PIN_10;
  72.   GPIO_InitStruct.Mode = GPIO_MODE_IT_FALLING;
  73.   GPIO_InitStruct.Pull = GPIO_PULLUP;
  74.   HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
  75.   /* EXTI interrupt init*/
  76.   HAL_NVIC_SetPriority(EXTI10_IRQn, 0, 0);
  77.   HAL_NVIC_EnableIRQ(EXTI10_IRQn);
  78. /* USER CODE BEGIN MX_GPIO_Init_2 */
  79. /* USER CODE END MX_GPIO_Init_2 */
  80. }
  81. void HAL_GPIO_EXTI_IRQHandler1(uint16_t GPIO_Pin)
  82. {
  83.   /* EXTI line interrupt detected */
  84.   if (__HAL_GPIO_EXTI_GET_RISING_IT(GPIO_Pin) != 0U)
  85.   {
  86.     __HAL_GPIO_EXTI_CLEAR_RISING_IT(GPIO_Pin);
  87.     HAL_GPIO_EXTI_Rising_Callback(GPIO_Pin);
  88.   }
  89.   if (__HAL_GPIO_EXTI_GET_FALLING_IT(GPIO_Pin) != 0U)
  90.   {
  91.     __HAL_GPIO_EXTI_CLEAR_FALLING_IT(GPIO_Pin);
  92.     HAL_GPIO_EXTI_Falling_Callback(GPIO_Pin);
  93.   }
  94. }
  95. /**
  96.   * [url=home.php?mod=space&uid=247401]@brief[/url]  The application entry point.
  97.   * @retval int
  98.   */
  99. int main(void)
  100. {
  101.         u8 wan,qian,bai,shi,ge;
  102.   /* USER CODE BEGIN 1 */
  103.   /* USER CODE END 1 */
  104.   /* MCU Configuration--------------------------------------------------------*/
  105.   /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  106.   HAL_Init();
  107.   /* USER CODE BEGIN Init */
  108.   /* USER CODE END Init */
  109.   /* Configure the system clock */
  110.   SystemClock_Config();
  111.   /* Configure the System Power */
  112.   SystemPower_Config();
  113.   /* USER CODE BEGIN SysInit */
  114.         MX_ICACHE_Init();
  115.   /* USER CODE END SysInit */
  116.   /* Initialize all configured peripherals */
  117.   MX_GPIO_Init();
  118.         MX_GPIO_EXTI_Init();
  119.   MX_TIM1_Init();
  120.   MX_USART2_UART_Init();
  121.   /* USER CODE BEGIN 2 */
  122.
  123.   /* USER CODE END 2 */
  124.
  125.   /* Infinite loop */
  126.   HAL_TIM_Base_Start(&htim1);
  127.   while (1)
  128.   {
  129.     /* USER CODE END WHILE */
  130.                 if( VS838_receive_ok == 1 ) //Ò»Ö¡ºìÍâÊý¾Ý½ÓÊÕÍê³É
  131.     {
  132.         VS838_receive_ok=0;
  133.                                 aTxBuffer[13]=(uint8_t)(VS838_Receive_Data>>28);
  134.                                 if(aTxBuffer[13]>=0 && aTxBuffer[13]<=9)
  135.                                         aTxBuffer[13]+=0x30;
  136.                                 else if(aTxBuffer[13]>=10 && aTxBuffer[13]<=15)
  137.                                         aTxBuffer[13]+=55;
  138.
  139.                                 aTxBuffer[14]=(uint8_t)((VS838_Receive_Data>>24)&0x0f);
  140.                                 if(aTxBuffer[14]>=0 && aTxBuffer[14]<=9)
  141.                                         aTxBuffer[14]+=0x30;
  142.                                 else if(aTxBuffer[14]>=10 && aTxBuffer[14]<=15)
  143.                                         aTxBuffer[14]+=55;
  144.
  145.                                 aTxBuffer[15]=(uint8_t)((VS838_Receive_Data>>20)&0x0f);
  146.                                 if(aTxBuffer[15]>=0 && aTxBuffer[15]<=9)
  147.                                         aTxBuffer[15]+=0x30;
  148.                                 else if(aTxBuffer[15]>=10 && aTxBuffer[15]<=15)
  149.                                         aTxBuffer[15]+=55;
  150.
  151.                                 aTxBuffer[16]=(uint8_t)((VS838_Receive_Data>>16)&0x0f);
  152.                                 if(aTxBuffer[16]>=0 && aTxBuffer[16]<=9)
  153.                                         aTxBuffer[16]+=0x30;
  154.                                 else if(aTxBuffer[16]>=10 && aTxBuffer[16]<=15)
  155.                                         aTxBuffer[16]+=55;
  156.
  157.                                 aTxBuffer[17]=(uint8_t)((VS838_Receive_Data>>12)&0x0f);
  158.                                 if(aTxBuffer[17]>=0 && aTxBuffer[17]<=9)
  159.                                         aTxBuffer[17]+=0x30;
  160.                                 else if(aTxBuffer[17]>=10 && aTxBuffer[17]<=15)
  161.                                         aTxBuffer[17]+=55;
  162.
  163.                                 aTxBuffer[18]=(uint8_t)((VS838_Receive_Data>>8)&0x0f);
  164.                                 if(aTxBuffer[18]>=0 && aTxBuffer[18]<=9)
  165.                                         aTxBuffer[18]+=0x30;
  166.                                 else if(aTxBuffer[18]>=10 && aTxBuffer[18]<=15)
  167.                                         aTxBuffer[18]+=55;
  168.
  169.                                 aTxBuffer[19]=(uint8_t)((VS838_Receive_Data>>4)&0x0f);
  170.                                 if(aTxBuffer[19]>=0 && aTxBuffer[19]<=9)
  171.                                         aTxBuffer[19]+=0x30;
  172.                                 else if(aTxBuffer[19]>=10 && aTxBuffer[19]<=15)
  173.                                         aTxBuffer[19]+=55;
  174.
  175.                                 aTxBuffer[20]=(uint8_t)(VS838_Receive_Data&0x0f);
  176.                                 if(aTxBuffer[20]>=0 && aTxBuffer[20]<=9)
  177.                                         aTxBuffer[20]+=0x30;
  178.                                 else if(aTxBuffer[20]>=10 && aTxBuffer[20]<=15)
  179.                                         aTxBuffer[20]+=55;
  180.
  181.         if (HAL_UART_Transmit(&huart2, (uint8_t *)aTxBuffer, TXBUFFERSIZE, 5000) != HAL_OK)
  182.                                 {
  183.                                         Error_Handler();
  184.                                 }
  185.         VS838_Receive_Data=0;
  186.     }
  187.     /* USER CODE BEGIN 3 */
  188.   }
  189.   /* USER CODE END 3 */
  190. }
  191. /**
  192.   * @brief System Clock Configuration
  193.   * @retval None
  194.   */
  195. void SystemClock_Config(void)
  196. {
  197.   RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  198.   RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  199.   /** Configure the main internal regulator output voltage
  200.   */
  201.   if (HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE4) != HAL_OK)
  202.   {
  203.     Error_Handler();
  204.   }
  205.   /** Initializes the CPU, AHB and APB buses clocks
  206.   */
  207.   RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_MSI;
  208.   RCC_OscInitStruct.MSIState = RCC_MSI_ON;
  209.   RCC_OscInitStruct.MSICalibrationValue = RCC_MSICALIBRATION_DEFAULT;
  210.   RCC_OscInitStruct.MSIClockRange = RCC_MSIRANGE_4;
  211.   RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
  212.   if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
  213.   {
  214.     Error_Handler();
  215.   }
  216.   /** Initializes the CPU, AHB and APB buses clocks
  217.   */
  218.   RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
  219.                               |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2
  220.                               |RCC_CLOCKTYPE_PCLK3;
  221.   RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_MSI;
  222.   RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  223.   RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  224.   RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  225.   RCC_ClkInitStruct.APB3CLKDivider = RCC_HCLK_DIV1;
  226.   if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
  227.   {
  228.     Error_Handler();
  229.   }
  230. }
  231. /**
  232.   * @brief Power Configuration
  233.   * @retval None
  234.   */
  235. static void SystemPower_Config(void)
  236. {
  237.   HAL_PWREx_EnableVddIO2();
  238.   /*
  239.    * Disable the internal Pull-Up in Dead Battery pins of UCPD peripheral
  240.    */
  241.   HAL_PWREx_DisableUCPDDeadBattery();
  242.   /*
  243.    * Switch to SMPS regulator instead of LDO
  244.    */
  245.   if (HAL_PWREx_ConfigSupply(PWR_SMPS_SUPPLY) != HAL_OK)
  246.   {
  247.     Error_Handler();
  248.   }
  249. /* USER CODE BEGIN PWR */
  250. /* USER CODE END PWR */
  251. }
  252. /**
  253.   * @brief TIM1 Initialization Function
  254.   * @param None
  255.   * @retval None
  256.   */
  257. static void MX_TIM1_Init(void)
  258. {
  259.   /* USER CODE BEGIN TIM1_Init 0 */
  260.   /* USER CODE END TIM1_Init 0 */
  261.   TIM_ClockConfigTypeDef sClockSourceConfig = {0};
  262.   TIM_MasterConfigTypeDef sMasterConfig = {0};
  263.   /* USER CODE BEGIN TIM1_Init 1 */
  264.   /* USER CODE END TIM1_Init 1 */
  265.   htim1.Instance = TIM1;
  266.   htim1.Init.Prescaler = 3;
  267.   htim1.Init.CounterMode = TIM_COUNTERMODE_UP;
  268.   htim1.Init.Period = 60000;
  269.   htim1.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
  270.   htim1.Init.RepetitionCounter = 0;
  271.   htim1.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
  272.   if (HAL_TIM_Base_Init(&htim1) != HAL_OK)
  273.   {
  274.     Error_Handler();
  275.   }
  276.   sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
  277.   if (HAL_TIM_ConfigClockSource(&htim1, &sClockSourceConfig) != HAL_OK)
  278.   {
  279.     Error_Handler();
  280.   }
  281.   sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
  282.   sMasterConfig.MasterOutputTrigger2 = TIM_TRGO2_RESET;
  283.   sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
  284.   if (HAL_TIMEx_MasterConfigSynchronization(&htim1, &sMasterConfig) != HAL_OK)
  285.   {
  286.     Error_Handler();
  287.   }
  288.   /* USER CODE BEGIN TIM1_Init 2 */
  289.   /* USER CODE END TIM1_Init 2 */
  290. }
  291. /**
  292.   * @brief USART2 Initialization Function
  293.   * @param None
  294.   * @retval None
  295.   */
  296. static void MX_USART2_UART_Init(void)
  297. {
  298.   /* USER CODE BEGIN USART2_Init 0 */
  299.   /* USER CODE END USART2_Init 0 */
  300.   /* USER CODE BEGIN USART2_Init 1 */
  301.   /* USER CODE END USART2_Init 1 */
  302.   huart2.Instance = USART2;
  303.   huart2.Init.BaudRate = 115200;
  304.   huart2.Init.WordLength = UART_WORDLENGTH_8B;
  305.   huart2.Init.StopBits = UART_STOPBITS_1;
  306.   huart2.Init.Parity = UART_PARITY_NONE;
  307.   huart2.Init.Mode = UART_MODE_TX_RX;
  308.   huart2.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  309.   huart2.Init.OverSampling = UART_OVERSAMPLING_16;
  310.   huart2.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE;
  311.   huart2.Init.ClockPrescaler = UART_PRESCALER_DIV1;
  312.   huart2.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
  313.   if (HAL_UART_Init(&huart2) != HAL_OK)
  314.   {
  315.     Error_Handler();
  316.   }
  317.   if (HAL_UARTEx_SetTxFifoThreshold(&huart2, UART_TXFIFO_THRESHOLD_1_8) != HAL_OK)
  318.   {
  319.     Error_Handler();
  320.   }
  321.   if (HAL_UARTEx_SetRxFifoThreshold(&huart2, UART_RXFIFO_THRESHOLD_1_8) != HAL_OK)
  322.   {
  323.     Error_Handler();
  324.   }
  325.   if (HAL_UARTEx_DisableFifoMode(&huart2) != HAL_OK)
  326.   {
  327.     Error_Handler();
  328.   }
  329.   /* USER CODE BEGIN USART2_Init 2 */
  330.   /* USER CODE END USART2_Init 2 */
  331. }
  332. /**
  333.   * @brief GPIO Initialization Function
  334.   * @param None
  335.   * @retval None
  336.   */
  337. static void MX_GPIO_Init(void)
  338. {
  339.   GPIO_InitTypeDef GPIO_InitStruct = {0};
  340. /* USER CODE BEGIN MX_GPIO_Init_1 */
  341. /* USER CODE END MX_GPIO_Init_1 */
  342.   /* GPIO Ports Clock Enable */
  343.   __HAL_RCC_GPIOC_CLK_ENABLE();
  344.   __HAL_RCC_GPIOA_CLK_ENABLE();
  345.   __HAL_RCC_GPIOB_CLK_ENABLE();
  346.         __HAL_RCC_GPIOF_CLK_ENABLE();
  347.   __HAL_RCC_GPIOG_CLK_ENABLE();
  348.   /*Configure GPIO pin Output Level */
  349.
  350.   /*Configure GPIO pin : USER_BUTTON_Pin */
  351.   GPIO_InitStruct.Pin = GPIO_PIN_7;
  352.   GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  353.   GPIO_InitStruct.Pull = GPIO_NOPULL;
  354.   HAL_GPIO_Init(GPIOF, &GPIO_InitStruct);
  355.   /*Configure GPIO pin : VBUS_SENSE_Pin */
  356.
  357.   /*Configure GPIO pin : PB15 */
  358.
  359.   /*Configure GPIO pins : PA9 PA10 */
  360.
  361. /* USER CODE BEGIN MX_GPIO_Init_2 */
  362. /* USER CODE END MX_GPIO_Init_2 */
  363. }
  364. /* USER CODE BEGIN 4 */
  365. /* USER CODE END 4 */
  366. /**
  367.   * @brief  Period elapsed callback in non blocking mode
  368.   * [url=home.php?mod=space&uid=536309]@NOTE[/url]   This function is called  when TIM17 interrupt took place, inside
  369.   * HAL_TIM_IRQHandler(). It makes a direct call to HAL_IncTick() to increment
  370.   * a global variable "uwTick" used as application time base.
  371.   * @param  htim : TIM handle
  372.   * @retval None
  373.   */
  374. void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
  375. {
  376.   /* USER CODE BEGIN Callback 0 */
  377.   /* USER CODE END Callback 0 */
  378.   if (htim->Instance == TIM17) {
  379.     HAL_IncTick();
  380.   }
  381.   /* USER CODE BEGIN Callback 1 */
  382.   /* USER CODE END Callback 1 */
  383. }
  384. /**
  385.   * @brief  This function is executed in case of error occurrence.
  386.   * @retval None
  387.   */
  388. void Error_Handler(void)
  389. {
  390.   /* USER CODE BEGIN Error_Handler_Debug */
  391.   /* User can add his own implementation to report the HAL error return state */
  392.   __disable_irq();
  393.   while (1)
  394.   {
  395.   }
  396.   /* USER CODE END Error_Handler_Debug */
  397. }
  398. #ifdef  USE_FULL_ASSERT
  399. /**
  400.   * @brief  Reports the name of the source file and the source line number
  401.   *         where the assert_param error has occurred.
  402.   * @param  file: pointer to the source file name
  403.   * @param  line: assert_param error line source number
  404.   * @retval None
  405.   */
  406. void assert_failed(uint8_t *file, uint32_t line)
  407. {
  408.   /* USER CODE BEGIN 6 */
  409.   /* User can add his own implementation to report the file name and line number,
  410.      ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  411.   /* USER CODE END 6 */
  412. }
  413. #endif /* USE_FULL_ASSERT */
vs838.c:
  2. u8  VS838_Status=0;              //ºìÍâ½ÓÊÕ´¦Àí״̬
  3. u8  VS838_Receive_Count=0;       //ºìÍâ½ÓÊÕÊý¾Ýλ¼ÆÊý
  4. u32 VS838_Receive_Data=0;        //32λµÄºìÍâ½ÓÊÕÊý¾Ý
  5. u8  VS838_receive_ok=0;          //ºìÍâ½ÓÊÕÍê³É±êÖ¾
  6. extern TIM_HandleTypeDef htim1;
  7. extern UART_HandleTypeDef huart2;
  8. /*
  9. ********************************************************************************
  10.             GPIO³õʼ»¯
  11. ********************************************************************************
  12. */
  13. void VS838_GPIO(void)
  14. {
  15. }
  16. /*
  17. ********************************************************************************
  18.             ¶¨Ê±Æ÷³õʼ»¯
  19. ********************************************************************************
  20. */
  21. void TIM2_Config(void)//¶¨Ê±Æ÷³õʼ»¯
  22. {
  23. }
  24. /*
  25. ********************************************************************************
  26.                           ºìÍâ½âÂë³õʼ»¯º¯Êý
  27. ********************************************************************************
  28. */
  29. void VS838_Init(void)//ºìÍâ½âÂë³õʼ»¯º¯Êý
  30. {
  31.   VS838_GPIO();
  32.   TIM2_Config();
  33. }
  34. /*
  35. ********************************************************************************
  36.                           ºìÍâ½ÓÊÕÊý¾Ý´¦Àíº¯Êý
  37. ********************************************************************************
  38. */
  39. uint8_t VS838_Process(void)//ºìÍâ½ÓÊÕÊý¾Ý´¦Àíº¯
  40. {
  41.   uint8_t VS838_num=0;               //×îÖÕ´¦ÀíºóµÄ¼üÖµ·µ»ØÖµ
  42.   uint8_t Address_H,Address_L;       //µØÖ·Âë,µØÖ··´Âë
  43.   uint8_t Data_H,Data_L;             //Êý¾ÝÂë,Êý¾Ý·´Âë
  44.
  45.   if(VS838_receive_ok==1)          //½ÓÊÕÍê³É
  46.   {
  47.        Address_H=VS838_Receive_Data>>24;                //µÃµ½µØÖ·Âë
  48.        Address_L=(VS838_Receive_Data>>16)&0xff;         //µÃµ½µØÖ··´Âë
  49.        if((Address_H==(uint8_t)~Address_L))//¼ìÑéÒ£¿ØÊ¶±ðÂë(ID)¼°µØÖ·
  50.        {
  51.             Data_H=VS838_Receive_Data>>8;              //µÃµ½Êý¾ÝÂë
  52.             Data_L=VS838_Receive_Data;                 //µÃµ½Êý¾Ý·´Âë
  53.             if(Data_H==(uint8_t)~Data_L)                 //½ÓÊÕÊý¾ÝÂëÕýÈ·
  54.             {
  55.                   VS838_num=Data_H;                      //ÕýÈ·¼üÖµ
  56.                   VS838_Receive_Data=0;
  57.             }
  58.         }
  59.    }
  60.    return  VS838_num;      //·µ»Ø¼üÖµ
  61. }
  62. /*
  63. ********************************************************************************
  64.                           ºìÍâ½ÓÊÕÖжϴ¦Àíº¯Êý
  65. ********************************************************************************
  66. */
  67. void VS838_Receive_Handle(void)//ºìÍâ½ÓÊÕÖжϴ¦Àíº¯Êý
  68. {
  69.   u16 Interval_tim=0;//Á½¸öϽµÑؼä¸ôʱ¼ä
  70.   switch(VS838_Status)
  71.   {
  72.     case 0://µÚÒ»¸öϽµÑØ£¬¶¨Ê±Æ÷¿ªÊ¼¼ÆÊý
  73.             VS838_Status=1;
  74.             HAL_TIM_Base_Start(&htim1);                   //Enable TIM2
  75.                            //¶¨Ê±Æ÷¼ÆÊýÖµÇåÁã
  76.                                                 TIM1->CNT=0;
  77.
  78.             break;
  79.
  80.     case 1://µÚ¶þ¸öϽµÑØ£¬¶¨Ê±Æ÷¹Ø±Õ£¬¶ÁÈ¡¶¨Ê±Æ÷¼ÆÊýÖµ
  81.             HAL_TIM_Base_Stop(&htim1);
  82.             Interval_tim=0;
  83.             Interval_tim=TIM1->CNT;     //¶ÁÈ¡¶¨Ê±Æ÷¼ÆÊýÖµ
  84.             TIM1->CNT = 0;                //¶¨Ê±Æ÷¼ÆÊýÖµÇåÁã
  85.             HAL_TIM_Base_Start(&htim1);                   //Enable TIM2
  86.
  87.             if( (Interval_tim>=12500)&&(Interval_tim<=14500) )//ÅжÏÒýµ¼ÂëÊÇ·ñÕýÈ·9+4.5ms
  88.             {
  89.                 VS838_Status=2;                    //½øÈëÏÂһ״̬
  90.
  91.             }
  92.             else                                //Òýµ¼Âë´íÎ󣬴ÓнÓÊÕ
  93.             {
  94.                 VS838_Status=0;
  95.                 VS838_Receive_Count=0;
  96.             }
  97.             break;
  98.
  99.     case 2://¿ªÊ¼32λÊý¾ÝµÄ½ÓÊÕ
  100.             HAL_TIM_Base_Stop(&htim1);
  101.
  102.             Interval_tim=0;
  103.             Interval_tim=TIM1->CNT;
  104.             TIM1->CNT=0;
  105.             HAL_TIM_Base_Start(&htim1);   //Enable TIM2
  106.
  107.             if( (Interval_tim>=1000)&&(Interval_tim<=1300) )        //¼ä¸ô1.12ms ->0
  108.             {
  109.                   VS838_Receive_Data=VS838_Receive_Data<<1;
  110.                   VS838_Receive_Count++;
  111.
  112.             }
  113.             else if( (Interval_tim>=2000)&&(Interval_tim<=2600) )   //¼ä¸ô2.25ms ->1
  114.             {
  115.                   VS838_Receive_Data=VS838_Receive_Data<<1;
  116.                   VS838_Receive_Data=VS838_Receive_Data|0x0001;
  117.                   VS838_Receive_Count++;
  118.
  119.             }
  120.             else//²»ÊÇ0,1 ½ÓÊÕ´íÎ󣬴ÓнÓÊÕ
  121.             {
  122.                   VS838_Status=0;
  123.                   VS838_Receive_Data=0;
  124.                   VS838_Receive_Count=0;
  125.             }
  126.
  127.             //³¬³ö½ÓÊÕÊý¾ÝλÊý£¬½ÓÊÕÏÂÒ»¸ö
  128.           while(VS838_Receive_Count==32)
  129.             {
  130.                 VS838_receive_ok=1;//ºìÍâ½ÓÊÕÍê³É
  131.                 VS838_Status=0;
  132.                 VS838_Receive_Count=0;
  133.
  134.                 break;
  135.             }
  136.             break;
  137.
  138.     default :
  139.             {
  140.                 VS838_Status=0;
  141.             }
  142.             break;
  143.     }
  144. }
  145. void VS838_Demo(void)  //ºìÍâÊý¾Ý½ÓÊÕÊý¾Ý´¦ÀíÀý³Ì
  146. {
  147.
  148.
  149.     if( VS838_receive_ok == 1 ) //Ò»Ö¡ºìÍâÊý¾Ý½ÓÊÕÍê³É
  150.     {
  151.         VS838_receive_ok=0;
  152.
  153.
  154.         VS838_Receive_Data=0;
  155.     }
  156. }
中断函数:
  1. void EXTI10_IRQHandler(void)
  3.   /* USER CODE BEGIN EXTI10_IRQn 0 */
  4.   /* USER CODE END EXTI10_IRQn 0 */
  5.   HAL_GPIO_EXTI_IRQHandler1(GPIO_PIN_10);
  6.   /* USER CODE BEGIN EXTI10_IRQn 1 */
  7.   /* USER CODE END EXTI10_IRQn 1 */
  8. }
效果图:
Henryko 发表于 2024-1-12 16:13 | 显示全部楼层
强光对红外有影响不?
 楼主| 比神乐 发表于 2024-9-21 17:16 | 显示全部楼层
红外是看不见的光,应该没影响吧?
