[华大MCU] 华大HC32F030F8TA移植FreeRTOS之后,程序中的LED无法正常闪烁
1236|2
 楼主| wsdmzz 发表于 2023-3-15 17:14 | 显示全部楼层 |阅读模式
附件地址:http://deershare.com/recv/982136 取件码:982136
[code]
#ifndef FREERTOS_CONFIG_H
#define FREERTOS_CONFIG_H
#include "hc32f030.h"
/* Ensure stdint is only used by the compiler, and not the assembler. */
#if defined(__ICCARM__) || defined(__CC_ARM) || defined(__GNUC__)
        #include <stdint.h>
        extern uint32_t SystemCoreClock;
#endif
#define configUSE_PREEMPTION                1//��ռʽ����������
#define configUSE_IDLE_HOOK                 0//���������Ӻ���
#define configUSE_TICK_HOOK                 0//ʱ��Ƭ���Ӻ���
#define configCPU_CLOCK_HZ                  ( SystemCoreClock )//CPU��Ƶ
#define configTICK_RATE_HZ                  ( ( TickType_t ) 1000 )//RTOS����Ƶ�� ��1����жϴ���
#define configMAX_PRIORITIES                ( 5 )//��ʹ�õ�������ȼ�
#define configMINIMAL_STACK_SIZE            ( ( unsigned short ) 64 )//�����������ʹ�õĶ�ջ��С
#define configTOTAL_HEAP_SIZE               ( ( size_t ) ( 6*1024 ) )//RTOS�ں��ܼƿ��õ���Ч��RAM��С
#define configMAX_TASK_NAME_LEN             ( 12 )//��������
 楼主| wsdmzz 发表于 2023-3-17 11:15 | 显示全部楼层
zwsam 发表于 2023-10-31 08:52 | 显示全部楼层
