[PCB设计资料] IPQ9574+QCN9274 realizes high-speed and stable wireless network connection and expands coverage
674|0
 楼主| wirelesswifi6 发表于 2023-3-21 13:55 | 显示全部楼层 |阅读模式
WiFi7 is the latest WiFi standard being developed by the IEEE (Institute of Electrical and Electronics Engineers), also known as the IEEE 802.11be standard, and is expected to be officially launched in the next few years. The WiFi7 standard will adopt features such as higher frequency bands, faster data transmission rates, lower latency, and better network efficiency to meet the needs of future higher-speed, more reliable wireless networks.
At present, the wifi7 combination of motherboard and card will be launched by Wallys, IPQ9574+QCN9274, to improve the speed, coverage and stability of the wireless network, and at the same time provide functions such as low-power connection and accurate positioning services.
Wallys is the most worth working with, as Wallys has over 10 years of experience with quaclomm WiFi chips, from ar5414 to ar7161, with full access to the chip's code.As a result, Wallys can help customers solve many of the problems that customers encounter on WiFi.Wallys has also developed special protocols such as time division multiple access over WiFi and fast roaming.  You can run WiFi within 20km and even disable ack to extend WiFi range.Wallys can also develop a 4.9Ghz narrow band such as 5/10Mhz.Wallys is a professional WiFi company that can solve any technical problem you encounter, so we can help customers make many innovative products.Wallys has a strong software team and hardware team to meet customers' various customized needs for wifi products.
Qualcomm QCN9274 introduction:
QCN9274 is a client wireless chip, which is often used in wireless network cards built into laptops, tablets, smartphones and other mobile devices to provide high-speed and stable WiFi connection services. QCN9274 supports 802.11ac Wave 2 standard, which can provide high-speed WiFi connection with a data transmission rate of up to 867 Mbps. At the same time, it also supports a variety of security protocols, including WPA3, WiFi CERTIFIED Passpoint and WiFi CERTIFIED Enhanced Open, etc., which can provide more secure WiFi connections for mobile devices.
Qualcomm QCN9274 is a WiFi chip, which adopts Qualcomm's technology and design, and is specially used for wireless connection in scenarios such as mobile devices, smart home and Internet of Things. Following are some features and functions of QCN9274:
Support 802.11ac Wave 2 standard, can provide high-speed WiFi connection, up to 867 Mbps data transfer rate.
Built-in Bluetooth 5.0, supports multiple Bluetooth protocols such as BLE (Bluetooth Low Energy) and Classic Bluetooth.
It integrates Qualcomm's positioning technology, supports WiFi positioning and iZat positioning, and can provide high-precision positioning services for devices.
Built-in Qualcomm's mobile device security technologies, including WPA3, WiFi CERTIFIED Passpoint and WiFi CERTIFIED Enhanced Open, etc., can provide more secure WiFi connections.
Supports multiple operating systems, including Android, Linux, and Windows.
In general, Qualcomm QCN9274 is a high-performance WiFi chip, which is suitable for various mobile devices and IoT application scenarios, and can provide high-speed, stable and secure wireless connection services.
What powerful functions will IPQ9574+QCN9274 use together?
Both IPQ9574 and QCN9274 are Qualcomm's wireless chips, and they can be used together to achieve more powerful wireless network functions. Specifically, their combination can achieve the following functions:
High-speed wireless network: IPQ9574 is a high-performance WiFi chip, supports 802.11ac Wave 2 standard, and can provide high-speed wireless network connection. The QCN9274 is a client chip that supports the Wave 2 standard, and can be paired with the IPQ9574 to achieve high-speed and stable wireless network connections.
Broadband network coverage: IPQ9574 also has up to 4 antennas MIMO (Multiple Input Multiple Output) technology and Beamforming (beamforming) technology, which can expand the coverage and strength of the WiFi network. Using it with QCN9274 can make the client device receive the signal better and improve the coverage of the wireless network.
Low-power connection: QCN9274 supports BLE (Bluetooth Low Energy) protocol, and can be paired with IPQ9574 to achieve low-power wireless connection. It is suitable for mobile devices and smart home applications that require long-term battery use.
Positioning service: IPQ9574 supports WiFi positioning and iZat positioning, and can provide accurate positioning services for client devices. The QCN9274 integrates Qualcomm's positioning technology and can be used in conjunction with the IPQ9574 to provide more accurate positioning services for client devices.
To sum up, the combination of IPQ9574 and QCN9274 can improve the speed, coverage and stability of the wireless network, and can also provide functions such as low-power connection and accurate positioning services, which are suitable for various mobile devices, smart home and IoT application scenarios.
