[PCB]
PCB封装设计焊盘设计要点
196|0
forgot|  楼主 | 2023-3-22 16:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
常规焊盘
焊盘大小:Regular Pad = 器件管教尺寸+补偿值
阻焊大小:Solder Mask=Regular Pad + 0.15mm
=Regular Pad + 0.1mm(BGA)
钢网层大小:Paste Mask= Regular Pad
Shape类型
焊盘大小:Regular Pad = shape 大小
阻焊大小:Solder Mask = Regular Pad
通孔焊盘
孔径大小:Drill Size = Physical Pin(参考管脚补偿计算)
通孔焊盘大小 Regular Pad=Drill Size + 0.4mm(drill<0.8)
=Drill Size + 0.6mm(3mm>=drill>=0.8)
=Drill Size + 1mm(drill>3)
热风焊盘:Thermal Pad = Thermal Pad(参考Flash计算规则)
反焊盘:Anti Pad = Drill_Size + 0.8
阻焊层:Solder Mask= Regular Pad + 0.15
