n32wb031 蓝牙数据读取
1177|0
 楼主| v小小的和你浪费 发表于 2023-4-24 16:20 | 显示全部楼层 |阅读模式
n32wb031 当主机 APP 读取从机数据时,数据类型只能是uint8_t吗?uint8_t Adc_Data[] = {0x10,0x30};/** * @brief  rdtss value require indicate handler * @param    * @return  * @NOTE   Note */static int rdtss_value_req_ind_handler(ke_msg_id_t const msgid,                                          struct rdtss_value_req_ind const *req_value,                                          ke_task_id_t const dest_id,                                          ke_task_id_t const src_id){    NS_LOG_DEBUG("%s\r\n",__func__);        // Initialize length    uint8_t len = 0;    // Pointer to the data    uint8_t *data = NULL;    //    len = APP_RDTSS_MANUFACTURER_NAME_LEN;//    data = (uint8_t *)APP_RDTSS_MANUFACTURER_NAME;    len = sizeof(Adc_Data);    data = (uint8_t *)Adc_Data;        // Allocate confirmation to send the value    struct rdtss_value_req_rsp *rsp_value = KE_MSG_ALLOC_DYN(RDTSS_VALUE_REQ_RSP,        src_id, dest_id,        rdtss_value_req_rsp,        len);    rsp_value->length = len;    rsp_value->att_idx = req_value->att_idx;    if (len)    {        // Copy data        memcpy(&rsp_value->value, data, len);    }    // Send message    ke_msg_send(rsp_value);        return (KE_MSG_CONSUMED);}
