Wifi7-QCN6274 SoC|LTE Cat 6, support LTE, FDD-LTE, TDD-LTE
796|0
 楼主| wirelesswifi6 发表于 2023-5-11 11:05 | 显示全部楼层 |阅读模式
QCN6274 is a chip of Qualcomm (Qualcomm), which is used for wireless communication and network connection.
The QCN6274 is a System-on-Chip (SoC) integrating multiple functions designed to provide powerful performance and connectivity for mobile devices, smartphones and other wireless devices. Here are some possible functions and features:
Wireless connectivity: The QCN6274 supports multiple wireless connectivity standards, including 4G LTE and 5G networks. It can provide high-speed data transmission and stable network connection to meet users' communication needs.
Multi-mode support: The chip supports multiple wireless communication modes, including LTE FDD, LTE TDD, WCDMA, CDMA2000, TD-SCDMA, and GSM. This makes it compatible and interoperable with various networks on a global scale.
Multi-band support: QCN6274 can operate on multiple frequency bands to meet the needs of different regions and operators. In this way, users can use the device in different network environments.
High-performance processor: The chip integrates a high-performance processor, which can handle complex computing tasks and multimedia applications. This helps provide a smooth user experience and fast data processing.
Low Power Design: The QCN6274 adopts an energy-saving design to prolong the battery life of the device. It adjusts power consumption as needed and automatically reduces power consumption when idle to provide longer battery life.
The following are some common wireless communication frequency bands:
LTE frequency band: QCN6274 usually supports LTE (Long-Term Evolution) network, including FDD-LTE (Frequency Division Duplexing LTE) and TDD-LTE (Time Division Duplexing LTE) frequency bands. Common LTE bands include:
LTE FDD frequency bands: 1, 2, 3, 4, 5, 7, 8, 12, 13, 17, 18, 19, 20, 25, 26, 28, 29, 30, 66, etc.
LTE TDD frequency bands: 38, 39, 40, 41, 46, 48, etc.
WCDMA frequency band: QCN6274 may also support WCDMA (Wideband Code Division Multiple Access) network for 2G and 3G communication. Common WCDMA frequency bands include:
850 MHz (Band 5)
900 MHz (Band 8)
1700/2100 MHz (Band 4)
1900 MHz (Band 2)
2100 MHz (Band 1)
CDMA2000 frequency band: QCN6274 may also support CDMA2000 network for 2G and 3G communication. Common CDMA2000 frequency bands include:
800 MHz (Band 0)
1900 MHz (Band 1).
Wallys is currently preparing to sample the motherboard and network card of wifi7, the chip is mainly IPQ9574
IPQ9554, QCN9274, QCN6274.
According to the engineer of wallystech, there will be 6g on the motherboard, and the wifi card will have two versions of DBDC and DB to meet the project needs of different customers.
Wallys has over  10 years of research and development experience, experienced in linux, wifi protocol and other aspects, Qualcomm chip development drivers, kernel and other important software development, modification and compilation, to meet customers' different wifi functional needs.
We have a strong hardware design team, and experienced people know that the most difficult part of hardware design is RF circuit design, baseband, etc., while wallys team made 0 error to achieve signal integrity, such as frequency conversion of network card, from 2.4G to 900M, which is a technological breakthrough.
Clients: TIP,Facebook, Openwrt, etc
Email:sales@wallystech.com
WEB:https://www.wallystech.com/
