[研电赛技术支持] GD32E503工程编译错误
2449|1
 楼主| andarm 发表于 2023-5-21 09:32 | 显示全部楼层 |阅读模式
官方下载的demo编译失败
- Keil 版本5.25
*** Using Compiler 'V5.06 update 6 (build 750)', folder: 'C:\Keil_v5\ARM\ARMCC\Bin'
Rebuild target 'GD32E503C_START'
compiling systick.c...
Fatal error: C3903U: Argument 'NOT_SUPPORTED' not permitted for option 'cpu'.
compiling main.c...
compiling system_gd32e50x.c...
compiling gd32e50x_adc.c...
compiling gd32e50x_it.c...
compiling gd32e50x_crc.c...
compiling gd32e50x_bkp.c...
compiling gd32e50x_cmp.c...
compiling gd32e50x_dbg.c...
compiling gd32e50x_dac.c...
compiling gd32e50x_ctc.c...
compiling gd32e50x_enet.c...
compiling gd32e50x_exmc.c...
compiling gd32e50x_dma.c...
compiling gd32e50x_fwdgt.c...
compiling gd32e50x_exti.c...
compiling gd32e50x_fmc.c...
compiling gd32e50x_gpio.c...
compiling gd32e50x_i2c.c...
compiling gd32e50x_misc.c...
compiling gd32e50x_rcu.c...
compiling gd32e50x_rtc.c...
compiling gd32e50x_pmu.c...
compiling gd32e50x_sdio.c...
compiling gd32e50x_shrtimer.c...
compiling gd32e50x_spi.c...
compiling gd32e50x_tmu.c...
compiling gd32e50x_sqpi.c...
compiling gd32e50x_timer.c...
compiling gd32e50x_usart.c...
compiling gd32e50x_wwdgt.c...
compiling gd32e50x_can.c...
compiling gd32e503c_start.c...
assembling startup_gd32e50x_hd.s...
startup_gd32e50x_hd.s: error: A3903U: Argument 'Cortex-M33' not permitted for option 'cpu'.
".\output\Project.axf" - 34 Error(s), 0 Warning(s).
Target not created.
Build Time Elapsed:  00:00:06
 楼主| andarm 发表于 2023-5-21 11:20 | 显示全部楼层
升级Keil 解决了。
