[FPGA] libero FLASHpro下载程序报错
2593|4
 楼主| leixc 发表于 2023-5-22 10:09 | 显示全部楼层 |阅读模式
请问大家有人知道flashpro下载程序的时候报这个错怎么解决呢?
Error: programmer 'S20059I89F' : Signal Integrity Failure
       Integrity Check Pattern Not Found.
       Integrity Check Pattern :
       550FAAF000FF0000FFFF
       IrScan Error.
       TDO stuck at 0
       Chain Analysis Failed.
Error: programmer 'S20059I89F' : Data Bit length : 8272
Error: programmer 'S20059I89F' : Compare Data  : 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000080
Error: programmer 'S20059I89F' : Scan Chain FAILED.
Error: Failed to run Action.
gaoyang9992006 发表于 2023-5-23 21:49 | 显示全部楼层
我在微芯的国外网站看到了类似的问题,回答的是:对于这个问题,
如果您使用的是微芯片套件,请根据您使用的跳线选择JTAG接头或嵌入式编程器。
如果没有,请检查JTAG信号的信号完整性。
检查JTAG信号是否提供足够的电源且无噪声。
有关供应要求,请参阅闪存专业快速用户指南
lixl0918 发表于 2023-5-25 16:09 | 显示全部楼层
如果 PC 的 BIOS 设置未设置为 EPP 或 ECP 或 双向,FlashPro Lite 将无法被软件正确识别并且扫描链将失败。 PC 开机期间可以访问 BIOS 设置,确认一下设置。
ynndmalh21 发表于 2023-12-29 12:11 | 显示全部楼层
FPGA是不是很难学习
