[STM32L0] STM32L0系列之【TIM通用定时器】
1353|0
 楼主| duo点 发表于 2023-5-29 14:28 | 显示全部楼层 |阅读模式
频率2.097Mhz , TIM2定时1s触发一次中断
1.TIM2初始化
HAL_TIM_Base_Init>HAL_TIM_ConfigClockSource>HAL_TIMEx_MasterConfigSynchronization
  * @brief TIM2 Initialization Function
  * @param None
  * @retval None
TIM_HandleTypeDef htim2;
void MX_TIM2_Init(uint16_t time)
  TIM_ClockConfigTypeDef sClockSourceConfig = {0};
  TIM_MasterConfigTypeDef sMasterConfig = {0};
  htim2.Instance = TIM2;
  htim2.Init.Prescaler = 2000;
  htim2.Init.CounterMode = TIM_COUNTERMODE_UP;
  htim2.Init.Period = time - 1;
  htim2.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
  htim2.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
  if (HAL_TIM_Base_Init(&htim2) != HAL_OK)
    Error_Handler();
  sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
  if (HAL_TIM_ConfigClockSource(&htim2, &sClockSourceConfig) != HAL_OK)
    Error_Handler();
  sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
  sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
  if (HAL_TIMEx_MasterConfigSynchronization(&htim2, &sMasterConfig) != HAL_OK)
    Error_Handler();
复制代码
2.TIM2 中断处理函数
  * @brief This function handles TIM2 global interrupt.
void TIM2_IRQHandler(void)
  HAL_TIM_IRQHandler(&htim2);
复制代码
3.主函数main
int main(void)
         HAL_Init();
    SystemClock_Config();
    LED_Init();//LED初始化
        MX_TIM2_Init(1001); //1s一次
        HAL_TIM_Base_Stop_IT(&htim2);
        HAL_TIM_Base_Start_IT(&htim2);
        while(1)
复制代码
4.TIM中断回调处理函数
void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
    if(htim == &htim2)
            HAL_GPIO_TogglePin(GPIOB,GPIO_PIN8);
