修改后的代码如下:- FlagStatus HRTIM_GetFlagStatus(HRTIM_TypeDef * HRTIMx, uint32_t TimerIdx, uint32_t HRTIM_FLAG)
- FlagStatus bitstatus = RESET;
- assert_param(IS_HRTIM_TIMERINDEX(TimerIdx));
- switch(TimerIdx)
- case HRTIM_TIMERINDEX_MASTER:
- if ((HRTIMx->HRTIM_MASTER.MISR & HRTIM_FLAG) != RESET)
- bitstatus = SET;
- else
- bitstatus = RESET;
- break;
- case HRTIM_TIMERINDEX_TIMER_A:
- case HRTIM_TIMERINDEX_TIMER_B:
- case HRTIM_TIMERINDEX_TIMER_C:
- case HRTIM_TIMERINDEX_TIMER_D:
- case HRTIM_TIMERINDEX_TIMER_E:
- if ((HRTIMx->HRTIM_TIMERx[TimerIdx].TIMxISR & HRTIM_FLAG) != RESET)
- bitstatus = SET;
- else
- break;
- default:
- break;
- return bitstatus;
