MM32F031F6U6 tim1定时器使用ETR外部时钟
1854|0
 楼主| s1351141178 发表于 2023-6-5 19:54 | 显示全部楼层 |阅读模式
使用MM32F013F6 TIM1的外部时钟功能,配置如下:
void TIM1_Init()
        TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
        NVIC_InitTypeDef NVIC_InitStructure;
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);            //开启GPIOA时钟
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);            //Open TIM1 clock
        //GPIO初始化
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
       GPIO_PinAFConfig(GPIOA, GPIO_PinSource6, GPIO_AF_4);                        //PA6复用功能的AF1/*特别注意:引脚功能复用参考数据手册,不要参考库函数中的代码说明*/
       TIM_TimeBaseStructure.TIM_Period = 0xffff;   //自动重装载寄存器周期的值
       TIM_TimeBaseStructure.TIM_Prescaler = 0;      //设置用来作为TIMx时钟频率除数的预分频值
       TIM_TimeBaseStructure.TIM_ClockDivision = 0;                                //设置时钟分割:TDTS = Tck_tim
       TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;    //TIM向上计数模式
       TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
       TIM_ETRClockMode2Config(TIM1,TIM_ExtTRGPSC_DIV2,TIM_ExtTRGPolarity_NonInverted,0x00);
        NVIC_InitStructure.NVIC_IRQChannel = TIM1_BRK_UP_TRG_COM_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPriority = 1;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStructure);
       TIM_ClearITPendingBit(TIM1,TIM_IT_Update);
       TIM_ITConfig(TIM1,TIM_IT_Update, ENABLE);
       TIM_SetCounter(TIM1, 0);
       TIM_Cmd(TIM1, ENABLE);
TIM初始化后,并给PA6引脚输入方波信号,定时器可以正常工作。
