求大神帮分析一下GD32F407ZET6 485通信问题
1357|0
 楼主| wangkl11 发表于 2023-7-6 13:29 | 显示全部楼层 |阅读模式
接收的数据一直是 FCFC
程序文件
main.c
void gd_eval_com_init(void)
    /* enable GPIO clock */
                usart_deinit(USART1);
                usart_disable(USART1);
    rcu_periph_clock_enable(RCU_GPIOD);//使能GPIOD时钟
    /* enable USART clock */
    rcu_periph_clock_enable(RCU_USART1);//使能USART1时钟
                gpio_af_set(GPIOD, GPIO_AF_7, GPIO_PIN_5|GPIO_PIN_6);//复用功能7
                gpio_mode_set(GPIOD, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_5);//PD5配置成串口输出
                gpio_output_options_set(GPIOD, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_5);
                gpio_mode_set(GPIOD, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_6);//PD6配置成串口输入
                gpio_output_options_set(GPIOD, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_6);
    /* USART configure */
    usart_interrupt_enable(USART1,USART_INT_RBNE);
    usart_baudrate_set(USART1,115200);
                usart_word_length_set(USART1, USART_WL_8BIT);
    usart_stop_bit_set(USART1, USART_STB_1BIT);
    usart_parity_config(USART1, USART_PM_NONE);
          usart_hardware_flow_coherence_config(USART1,USART_HCM_NONE);//无硬件流控
                usart_transmit_config(USART1,USART_TRANSMIT_ENABLE);//发送使能
                usart_receive_config(USART1,USART_RECEIVE_ENABLE);//接收使能
                usart_data_first_config(USART1,USART_MSBF_LSB);//LSB模式
                usart_enable(USART1);//使能串口
                nvic_irq_enable(USART1_IRQn, 0, 0);//使能USART1中断
//关闭串口
int32_t uart_stop(void)
    return 0;
//串口发送
int32_t uart_send(uint8_t *data,uint32_t len)
    uint32_t i = 0;
        while(len--)
                usart_data_transmit(USART1,data);
                while(usart_flag_get(USART1,USART_FLAG_TBE) == RESET);
                i++;
        return 0;
int main(void)
                uint8_t buff[4]={0xaa,0xbb,0x11,0x22};
    systick_config();//配置系统主频168M,外部8M晶振,配置在#define __SYSTEM_CLOCK_168M_PLL_8M_HXTAL        (uint32_t)(168000000)
                rcu_periph_clock_enable(RCU_GPIOG);//使能GPIOA时钟
                gpio_mode_set(GPIOG, GPIO_MODE_OUTPUT, GPIO_PUPD_PULLDOWN, GPIO_PIN_9);//PG9配置成串口输出
                gpio_output_options_set(GPIOG, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_9);
                gpio_bit_reset(GPIOG, GPIO_PIN_9);
    fwdgt_write_enable();
                 fwdgt_config(100,FWDGT_PSC_DIV32);
                 fwdgt_enable();
        //USART相关配置
                gd_eval_com_init();
                delay_1ms(7);
    while(1)
                        uart_send(buff,4);
                //        fwdgt_counter_reload();
                        (void)gpio_bit_set(GPIOG,GPIO_PIN_9);
                        delay_1ms(500);
                        (void)gpio_bit_reset(GPIOG,GPIO_PIN_9);
void USART1_IRQHandler(void)
           if( g_recv_positin >= sizeof(g_serial_recv_buf) )
        memset(g_serial_recv_buf,0,sizeof(g_serial_recv_buf));
        g_recv_positin = 0;
        if(usart_interrupt_flag_get(USART1,USART_INT_FLAG_ERR_ORERR) != RESET)
                usart_interrupt_flag_clear(USART1,USART_INT_FLAG_ERR_ORERR);
        if(usart_interrupt_flag_get(USART1,USART_INT_FLAG_RBNE) != RESET)
                usart_interrupt_flag_clear(USART1,USART_INT_FLAG_RBNE);
                g_serial_recv_buf[g_recv_positin++] = usart_data_receive(USART1);
        if(usart_interrupt_flag_get(USART1,USART_INT_FLAG_TBE) != RESET)
                usart_interrupt_flag_clear(USART1,USART_INT_FLAG_TBE);
