[应用相关]
STM32启动文件讲解
357|1
tpgf|  楼主 | 2023-7-12 08:17 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
1. 启动文件
从STM32 官方提供的文件中找到启动文件 Libraries\CMSIS\CM3\DeviceSupport\ST\STM32F10x\startup\arm 下有许多启动文件
我这里以stm32f10x_md.s进行讲解
;******************** (C) COPYRIGHT 2011 STMicroelectronics ********************
;* File Name          : startup_stm32f10x_md.s
;* Author             : MCD Application Team
;* Version            : V3.5.1
;* Date               : 08-September-2021
;* Description        : STM32F10x Medium Density Devices vector table for MDK-ARM
;*                      toolchain.
;*                      This module performs:
;*                      - Set the initial SP
;*                      - Set the initial PC == Reset_Handler
;*                      - Set the vector table entries with the exceptions ISR address
;*                      - Configure the clock system
;*                      - Branches to __main in the C library (which eventually
;*                        calls main()).
;*                      After Reset the CortexM3 processor is in Thread mode,
;*                      priority is Privileged, and the Stack is set to Main.
;* <<< Use Configuration Wizard in Context Menu >>>
;* Copyright (c) 2011 STMicroelectronics.
;* All rights reserved.
;* This software is licensed under terms that can be found in the LICENSE file
;* in the root directory of this software component.
;* If no LICENSE file comes with this software, it is provided AS-IS.
; Amount of memory (in bytes) allocated for Stack
; Tailor this value to your application needs
; <h> Stack Configuration
; 配置栈大小, 变量(局部、全局),函数调用
;   <o> Stack Size (in Bytes) <0x0-0xFFFFFFFF:8>
; </h>
Stack_Size      EQU     0x00000400
                AREA    STACK, NOINIT, READWRITE, ALIGN=3
Stack_Mem       SPACE   Stack_Size
__initial_sp
; <h> Heap Configuration
; 堆配置,主要用于动态内存的分配
;   <o>  Heap Size (in Bytes) <0x0-0xFFFFFFFF:8>
; </h>
Heap_Size       EQU     0x00000200
                AREA    HEAP, NOINIT, READWRITE, ALIGN=3
__heap_base
Heap_Mem        SPACE   Heap_Size
__heap_limit
                PRESERVE8  ; 当前堆栈以8字节对齐
                THUMB
; Vector Table Mapped to Address 0 at Reset
                AREA    RESET, DATA, READONLY
                EXPORT  __Vectors
                EXPORT  __Vectors_End
                EXPORT  __Vectors_Size
__Vectors       DCD     __initial_sp               ; Top of Stack
                DCD     Reset_Handler              ; Reset Handler
                DCD     NMI_Handler                ; NMI Handler
                DCD     HardFault_Handler          ; Hard Fault Handler
                DCD     MemManage_Handler          ; MPU Fault Handler
                DCD     BusFault_Handler           ; Bus Fault Handler
                DCD     UsageFault_Handler         ; Usage Fault Handler
                DCD     0                          ; Reserved
                DCD     0                          ; Reserved
                DCD     0                          ; Reserved
                DCD     0                          ; Reserved
                DCD     SVC_Handler                ; SVCall Handler
                DCD     DebugMon_Handler           ; Debug Monitor Handler
                DCD     0                          ; Reserved
                DCD     PendSV_Handler             ; PendSV Handler
                DCD     SysTick_Handler            ; SysTick Handler
                ; External Interrupts
                DCD     WWDG_IRQHandler            ; Window Watchdog
                DCD     PVD_IRQHandler             ; PVD through EXTI Line detect
                DCD     TAMPER_IRQHandler          ; Tamper
                DCD     RTC_IRQHandler             ; RTC
                DCD     FLASH_IRQHandler           ; Flash
                DCD     RCC_IRQHandler             ; RCC
                DCD     EXTI0_IRQHandler           ; EXTI Line 0
                DCD     EXTI1_IRQHandler           ; EXTI Line 1
                DCD     EXTI2_IRQHandler           ; EXTI Line 2
                DCD     EXTI3_IRQHandler           ; EXTI Line 3
                DCD     EXTI4_IRQHandler           ; EXTI Line 4
                DCD     DMA1_Channel1_IRQHandler   ; DMA1 Channel 1
                DCD     DMA1_Channel2_IRQHandler   ; DMA1 Channel 2
                DCD     DMA1_Channel3_IRQHandler   ; DMA1 Channel 3
                DCD     DMA1_Channel4_IRQHandler   ; DMA1 Channel 4
                DCD     DMA1_Channel5_IRQHandler   ; DMA1 Channel 5
                DCD     DMA1_Channel6_IRQHandler   ; DMA1 Channel 6
                DCD     DMA1_Channel7_IRQHandler   ; DMA1 Channel 7
                DCD     ADC1_2_IRQHandler          ; ADC1_2
                DCD     USB_HP_CAN1_TX_IRQHandler  ; USB High Priority or CAN1 TX
                DCD     USB_LP_CAN1_RX0_IRQHandler ; USB Low  Priority or CAN1 RX0
                DCD     CAN1_RX1_IRQHandler        ; CAN1 RX1
                DCD     CAN1_SCE_IRQHandler        ; CAN1 SCE
                DCD     EXTI9_5_IRQHandler         ; EXTI Line 9..5
                DCD     TIM1_BRK_IRQHandler        ; TIM1 Break
                DCD     TIM1_UP_IRQHandler         ; TIM1 Update
                DCD     TIM1_TRG_COM_IRQHandler    ; TIM1 Trigger and Commutation
                DCD     TIM1_CC_IRQHandler         ; TIM1 Capture Compare
                DCD     TIM2_IRQHandler            ; TIM2
                DCD     TIM3_IRQHandler            ; TIM3
                DCD     TIM4_IRQHandler            ; TIM4
                DCD     I2C1_EV_IRQHandler         ; I2C1 Event
                DCD     I2C1_ER_IRQHandler         ; I2C1 Error
                DCD     I2C2_EV_IRQHandler         ; I2C2 Event
                DCD     I2C2_ER_IRQHandler         ; I2C2 Error
                DCD     SPI1_IRQHandler            ; SPI1
                DCD     SPI2_IRQHandler            ; SPI2
                DCD     USART1_IRQHandler          ; USART1
                DCD     USART2_IRQHandler          ; USART2
                DCD     USART3_IRQHandler          ; USART3
                DCD     EXTI15_10_IRQHandler       ; EXTI Line 15..10
                DCD     RTCAlarm_IRQHandler        ; RTC Alarm through EXTI Line
                DCD     USBWakeUp_IRQHandler       ; USB Wakeup from suspend
__Vectors_End
__Vectors_Size  EQU  __Vectors_End - __Vectors
                AREA    |.text|, CODE, READONLY
; Reset handler
Reset_Handler    PROC
                 EXPORT  Reset_Handler             [WEAK]
     IMPORT  __main
     IMPORT  SystemInit
                 LDR     R0, =SystemInit
                 BLX     R0
                 LDR     R0, =__main
                 BX      R0
                 ENDP
; Dummy Exception Handlers (infinite loops which can be modified)
NMI_Handler     PROC
                EXPORT  NMI_Handler                [WEAK]
                B       .
                ENDP
HardFault_Handler\
                PROC
                EXPORT  HardFault_Handler          [WEAK]
                B       .
                ENDP
MemManage_Handler\
                PROC
                EXPORT  MemManage_Handler          [WEAK]
                B       .
                ENDP
BusFault_Handler\
                PROC
                EXPORT  BusFault_Handler           [WEAK]
                B       .
                ENDP
UsageFault_Handler\
                PROC
                EXPORT  UsageFault_Handler         [WEAK]
                B       .
                ENDP
SVC_Handler     PROC
                EXPORT  SVC_Handler                [WEAK]
                B       .
                ENDP
DebugMon_Handler\
                PROC
                EXPORT  DebugMon_Handler           [WEAK]
                B       .
                ENDP
PendSV_Handler  PROC
                EXPORT  PendSV_Handler             [WEAK]
                B       .
                ENDP
SysTick_Handler PROC
                EXPORT  SysTick_Handler            [WEAK]
                B       .
                ENDP
Default_Handler PROC
                EXPORT  WWDG_IRQHandler            [WEAK]
                EXPORT  PVD_IRQHandler             [WEAK]
                EXPORT  TAMPER_IRQHandler          [WEAK]
                EXPORT  RTC_IRQHandler             [WEAK]
                EXPORT  FLASH_IRQHandler           [WEAK]
                EXPORT  RCC_IRQHandler             [WEAK]
                EXPORT  EXTI0_IRQHandler           [WEAK]
                EXPORT  EXTI1_IRQHandler           [WEAK]
                EXPORT  EXTI2_IRQHandler           [WEAK]
                EXPORT  EXTI3_IRQHandler           [WEAK]
                EXPORT  EXTI4_IRQHandler           [WEAK]
                EXPORT  DMA1_Channel1_IRQHandler   [WEAK]
                EXPORT  DMA1_Channel2_IRQHandler   [WEAK]
                EXPORT  DMA1_Channel3_IRQHandler   [WEAK]
                EXPORT  DMA1_Channel4_IRQHandler   [WEAK]
                EXPORT  DMA1_Channel5_IRQHandler   [WEAK]
                EXPORT  DMA1_Channel6_IRQHandler   [WEAK]
                EXPORT  DMA1_Channel7_IRQHandler   [WEAK]
                EXPORT  ADC1_2_IRQHandler          [WEAK]
                EXPORT  USB_HP_CAN1_TX_IRQHandler  [WEAK]
                EXPORT  USB_LP_CAN1_RX0_IRQHandler [WEAK]
                EXPORT  CAN1_RX1_IRQHandler        [WEAK]
                EXPORT  CAN1_SCE_IRQHandler        [WEAK]
                EXPORT  EXTI9_5_IRQHandler         [WEAK]
                EXPORT  TIM1_BRK_IRQHandler        [WEAK]
                EXPORT  TIM1_UP_IRQHandler         [WEAK]
                EXPORT  TIM1_TRG_COM_IRQHandler    [WEAK]
                EXPORT  TIM1_CC_IRQHandler         [WEAK]
                EXPORT  TIM2_IRQHandler            [WEAK]
                EXPORT  TIM3_IRQHandler            [WEAK]
                EXPORT  TIM4_IRQHandler            [WEAK]
                EXPORT  I2C1_EV_IRQHandler         [WEAK]
                EXPORT  I2C1_ER_IRQHandler         [WEAK]
                EXPORT  I2C2_EV_IRQHandler         [WEAK]
                EXPORT  I2C2_ER_IRQHandler         [WEAK]
                EXPORT  SPI1_IRQHandler            [WEAK]
                EXPORT  SPI2_IRQHandler            [WEAK]
                EXPORT  USART1_IRQHandler          [WEAK]
                EXPORT  USART2_IRQHandler          [WEAK]
                EXPORT  USART3_IRQHandler          [WEAK]
                EXPORT  EXTI15_10_IRQHandler       [WEAK]
                EXPORT  RTCAlarm_IRQHandler        [WEAK]
                EXPORT  USBWakeUp_IRQHandler       [WEAK]
WWDG_IRQHandler
PVD_IRQHandler
TAMPER_IRQHandler
RTC_IRQHandler
FLASH_IRQHandler
RCC_IRQHandler
EXTI0_IRQHandler
EXTI1_IRQHandler
EXTI2_IRQHandler
EXTI3_IRQHandler
EXTI4_IRQHandler
ADC1_2_IRQHandler
CAN1_RX1_IRQHandler
CAN1_SCE_IRQHandler
EXTI9_5_IRQHandler
TIM1_BRK_IRQHandler
TIM1_UP_IRQHandler
TIM1_CC_IRQHandler
TIM2_IRQHandler
TIM3_IRQHandler
TIM4_IRQHandler
I2C1_EV_IRQHandler
I2C1_ER_IRQHandler
I2C2_EV_IRQHandler
I2C2_ER_IRQHandler
SPI1_IRQHandler
SPI2_IRQHandler
USART1_IRQHandler
USART2_IRQHandler
USART3_IRQHandler
RTCAlarm_IRQHandler
                B       .
                ENDP
                ALIGN
; User Stack and Heap initialization
                 IF      :DEF:__MICROLIB
                 EXPORT  __initial_sp
                 EXPORT  __heap_base
                 EXPORT  __heap_limit
                 ELSE
                 IMPORT  __use_two_region_memory
                 EXPORT  __user_initial_stackheap
                 LDR     R0, =  Heap_Mem
                 LDR     R1, =(Stack_Mem + Stack_Size)
                 LDR     R2, = (Heap_Mem +  Heap_Size)
                 LDR     R3, = Stack_Mem
                 BX      LR
                 ALIGN
                 ENDIF
                 END
源码如上所示,采用汇编语言所写。
参考手册:《STM32F10x参考手册》第10章-Interrupts and events
1.1 启动文件简介
启动文件有汇编语言编写,是系统上电复位后第一个执行的程序,主要做了一下工作:
初始化堆栈指针 SP = _initial_sp
初始化PC指针 = Reset_Hander
初始化中断向量表
配置系统时钟
调用C库函数_main初始化用户堆栈,从而最终调用main函数去C的世界
1.2 汇编指令
2. 启动文件解读
2.1 栈
__initial_sp
2.2 堆
__heap_base
__heap_limit
                THUMB
2.3 中断向量表
                EXPORT  __Vectors
                DCD     0                          ; Reserved
                DCD     0                          ; Reserved
                DCD     0                          ; Reserved
                DCD     0                          ; Reserved
                DCD     0                          ; Reserved
__Vectors_End
2.4 复位程序
; Reset handler
Reset_Handler    PROC
                 EXPORT  Reset_Handler             [WEAK] ;弱定义
     IMPORT  __main
     IMPORT  SystemInit  ; 系统时钟配置函数,由用户编写
                 LDR     R0, =SystemInit
                 BLX     R0
                 LDR     R0, =__main
                 BX      R0
                 ENDP
2.5 中断服务程序
NMI_Handler     PROC
                B       .
                ENDP
HardFault_Handler\
                PROC
                B       .
                ENDP
                B       .
                ENDP
                ALIGN ; 一般后面跟一个立即数,不跟默认4字节对齐
2.6 堆栈初始化
                 IF      :DEF:__MICROLIB   ; 在IDE中开启
                 EXPORT  __initial_sp
                 EXPORT  __heap_base
                 EXPORT  __heap_limit
                 ELSE
                 IMPORT  __use_two_region_memory ; 用户自己实现
                 LDR     R0, =  Heap_Mem
                 LDR     R3, = Stack_Mem
                 BX      LR
                 ALIGN
                 ENDIF
                 END
1. GPIO的位带操作
1.1 位带在哪里
1.2 位带去大小
1.3 地址转换
1.4 统一地址
版权声明:本文为CSDN博主「XYJ_Tiger」的原创文章,遵循CC 4.0 BY-SA版权协议,转载请附上原文出处链接及本声明。
原文链接:https://blog.csdn.net/XYJ_Tiger/article/details/124786646
guijial511| | 2023-7-12 08:38 | 只看该作者
只知道启动文件是干什么用的,还没有仔细去分析过里面的代码。
