[应用方案] N76E003此款芯片的定时器、ADC功能
1347|7
 楼主| eefas 发表于 2023-7-14 11:00 | 显示全部楼层 |阅读模式
多通道采集:
Uint32_t Get_ADC_Val(char channels)//获取ADC通道ADC值
        uint32_t ADC;
//        CKDIV=0x02;
        switch(channels)
                case 4:
                        Enable_ADC_AIN4;
                        break;
                case 5:
                        Enable_ADC_AIN5;
                        break;
                case 6:
                        Enable_ADC_AIN6;
                        break;
                case 7:
                        Enable_ADC_AIN7;
                        break;
        clr_ADCF;
        set_ADCS;        // ADC start trig signal
  while(ADCF == 0);
        ADC=(ADCRH<<4)+ADCRL;
        clr_ADCF;
//        CKDIV=0x00;
        return ADC;
小节总结:ADC的使用相信各位大神已经是使用的滚瓜烂熟了,我这种新手就不多提了,哈哈
附上一篇截图官方文档的ADC使用资料:
定时器模块:官方库中有各个定时器各个模式的sample Code附图:
简单附上定时器0模式1(部分执行代码)的官方代码:
*    TIMER 1 interrupt subroutine
void Timer1_ISR (void) interrupt 3  //interrupt address is 0x001B
    TH1 = u8TH1_Tmp;
    TL1 = u8TL1_Tmp;
    P03 = ~P03;                     //P0.3 toggle when interrupt
*    Main function
void main (void)
    Set_All_GPIO_Quasi_Mode;
                TIMER0_MODE1_ENABLE;
                TIMER1_MODE1_ENABLE;
    clr_T1M;
    //set_T1M;
    u8TH0_Tmp = (65536-TH0_INIT)/256;
    u8TL0_Tmp = (65536-TL0_INIT)%256;
    u8TH1_Tmp = (65536-TH1_INIT)/256;
    u8TL1_Tmp = (65536-TL1_INIT)%256;
    TH0 = u8TH0_Tmp;
    TL0 = u8TL0_Tmp;
    TH1 = u8TH1_Tmp;
    TL1 = u8TL1_Tmp;
    set_ET0;                                    //enable Timer0 interrupt
    set_ET1;                                    //enable Timer1 interrupt
    set_EA;                                     //enable interrupts
    set_TR0;                                    //Timer0 run
    set_TR1;                                    //Timer1 run
    while(1);
附上我自己(基于新唐官方库)修改后的使用定时器执行代码:
void Timer0_Init(void)//
        //TMOD = 0XFF;
        CKDIV=0X0C;
        TIMER0_MODE1_ENABLE;                   //Timer 0 and Timer 1 mode configuration
//        TIMER1_MODE2_ENABLE;
        clr_T0M;
    u8TH0_Tmp =TIMER_DIV12_VALUE_1ms>>8; //12分频初值
    u8TL0_Tmp =TIMER_DIV12_VALUE_1ms; //
          TH0 = u8TH0_Tmp;
    TL0 = u8TL0_Tmp;
//set_ET1;                                    //enable Timer1 interrupt
//set_TR1;                                    //Timer1 run
        CKDIV=0X00;
void Timer0_ISR (void) interrupt 1
          TH0 = u8TH0_Tmp;
    TL0 = u8TL0_Tmp;
        time_count++;
        key_handle=1;
        if(time_count==1000)
                time_count=0;
    miao++;
    if(miao==60)
      miao=0;
      fen++;
      if(fen==60)
        fen=0;
        shi++;
        if(shi==24)
          shi=0;
        TF0=0;
附上一张官方文档:
小节总结:官方提供的sample CODE 覆盖了整个定时器模块,给新人使用还是很有参考价值的,这次我也是第一次使用新唐的单片机,个人感觉还是挺方便的, N76E003  纯C51风格开发,(但就是定时器的使用让我思考起来人生),下载了官方库下来参考,看工程,咦!代码风格不一般,内设使用起来这么方便(库都已近定义好了),这不是Ctrl+c\Ctrl+v就能解决了吗!
这样新手 用起来就难堪了,我怎么调试定时中断时间都不对,难道是初值算错了,于是又找度娘,看看定时器初值怎么计算。改了改溢出值(还是不对,能力不够或者是解决问题的方向不对)于是又滑动鼠标滚轮看起了规格书(还好新唐的规格书是中文,不然就尴尬了)
规格书介绍的也挺简单的呀,看了看又调试,还是不行。于是又回到了官方库sample Code
附上一张官方库的文件图片:(提供的图片没什么用,就看看)
在官方库中的定时器模块没有找到解决方法。
哎,再仔细看看官方的库
有这么一个源文件:
看到有以下这些像是定时器的延时代码,想会不会是这些。
void Timer0_Delay100us(UINT32 u32CNT)
    clr_T0M;                                                //T0M=0, Timer0 Clock = Fsys/12
    TMOD |= 0x01;                                           //Timer0 is 16-bit mode
    set_TR0;                                                //Start Timer0
    while (u32CNT != 0)
        TL0 = LOBYTE(TIMER_DIV12_VALUE_100us);        //Find  define in "Function_define.h" "TIMER VALUE"
        TH0 = HIBYTE(TIMER_DIV12_VALUE_100us);
        while (TF0 != 1);                                   //Check Timer0 Time-Out Flag
        clr_TF0;
        u32CNT --;
    clr_TR0;                                                       //Stop Timer0
void Timer0_Delay1ms(UINT32 u32CNT)
    while (u32CNT != 0)
        TL0 = LOBYTE(TIMER_DIV12_VALUE_1ms);                 //Find  define in "Function_define.h" "TIMER VALUE"
        TH0 = HIBYTE(TIMER_DIV12_VALUE_1ms);
        clr_TF0;
        u32CNT --;
像延时一样,填上定时器初值看看定时中断对不对,调试又不对
TL0 = Timer0_Delay1ms(1);//1ms定时中断 初值
TH0 = Timer0_Delay1ms(1);
不对,,,,,,,还是不对。
再找找看看怎么解决,(又回到了下面的文件里,定时器初值的定义),填上去试试对不对,还是不对,呀呀呀呀呀。
仔细思考了一会,#define TIMER_DIV12_VALUE_1ms        65536-1334//1334*12/16000000 = 1 mS,                         // Timer divider = 12
这个初值是要对定时器模块进行相关的分频后的初值吗?
于是又看起了官方库,没有相关的定时器分频的使用参考呀,于是再回到了规格书:
找分频的使用介绍看看:附上图片:
看到这些资料,试试对定时器进行时钟分频调调看:于是就又了以下代码:
前面已经贴出,这里贴图片只做经验介绍总结。这里箭头和圈圈的就是我的解决方法了,定时器1ms中断实现了
tpgf 发表于 2024-2-4 08:06 | 显示全部楼层
有没有实际进行采样看看采样精度咋样啊
qcliu 发表于 2024-2-4 08:44 | 显示全部楼层
adc采集功能可以有不同的模式  这些模式应该如何进行选用呢
wiba 发表于 2024-2-4 09:50 | 显示全部楼层
这款芯片的定时器能输出pwm波控制电机吗
drer 发表于 2024-2-4 18:01 | 显示全部楼层
在adc采集过程中可以实时调整adc的采样频率吗
coshi 发表于 2024-2-4 18:37 | 显示全部楼层
应该也有普通定时器以及高级定时器的差别
kxsi 发表于 2024-2-4 19:11 | 显示全部楼层
可以考虑附一下adc的初始化代码以作参考
雨下纪事 发表于 2025-9-11 14:20 | 显示全部楼层
N76E003 有 3 个 16 位定时器(含 PWM),10 位 ADC(8 通道),支持单次 / 连续转换,可用于定时控制与模拟量采集。
