[其他ST产品] 进不了中断,求大神指点
820|13
 楼主| probedog 发表于 2023-7-26 10:12 | 显示全部楼层 |阅读模式
#include "bsp_spwm_output.h"
uint16_t  CCR1_Val ;
uint16_t  CCR2_Val = 1500 ;
uint16_t  CCR3_Val = 900;
static void TIM1_Mode_Config(void)
    TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
    TIM_OCInitTypeDef  TIM_OCInitStructure;
    /* GPIOA clocks enable */
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
    /* TIM1 clock enable */
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
    GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_9 | GPIO_Pin_10;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
    GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
    GPIO_Init(GPIOA,&GPIO_InitStructure);
    /* Connect TIM pins to AF6 */
    GPIO_PinAFConfig(GPIOA, GPIO_PinSource8, GPIO_AF_6);
    GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_6);
    GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_6);
    /* Time Base configuration */
    TIM_TimeBaseStructure.TIM_Period =2999;
  TIM_TimeBaseStructure.TIM_Prescaler = 0;
  TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;    //ÉèÖÃÔ¤·ÖƵ£º²»Ô¤·ÖƵ£¬¼´Îª72MHz
  TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;    //ÉèÖÃʱÖÓ·ÖÆµÏµÊý£º²»·ÖƵ(ÕâÀïÓò»µ½)
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_CenterAligned1;  //ÏòÉϼÆÊýģʽ
  TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
  /*PWM1 Mode configuration: Channel1 */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;        //ÅäÖÃΪPWMģʽ1
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse = CCR2_Val;       //ÉèÖÃÌø±äÖµ£¬µ±¼ÆÊýÆ÷¼ÆÊýµ½Õâ¸öֵʱ£¬µçƽ·¢ÉúÌø±ä
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;  //µ±¶¨Ê±Æ÷¼ÆÊýֵСÓÚCCR1_ValʱΪ¸ßµçƽ
    TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
    TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
    TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCNIdleState_Set;
  TIM_OC2Init(TIM1, &TIM_OCInitStructure);     //ʹÄÜͨµÀ1
  TIM_OC2PreloadConfig(TIM1, TIM_OCPreload_Enable);
  TIM_ARRPreloadConfig( TIM1,ENABLE);
  TIM_OCInitStructure.TIM_Pulse = CCR3_Val;
  TIM_OC3Init(TIM1, &TIM_OCInitStructure);     //ʹÄÜͨµÀ4
  TIM_OC3PreloadConfig(TIM1, TIM_OCPreload_Enable);
    TIM_UpdateRequestConfig( TIM1, TIM_UpdateSource_Regular);
  TIM_ITConfig(TIM1,TIM_IT_Update | TIM_IT_Trigger,ENABLE);/* TIM3 enable counter */
  TIM_Cmd(TIM1, ENABLE);     //ʹÄܶ¨Ê±Æ÷3
    TIM_ClearFlag(TIM1, TIM_FLAG_Update);
    TIM_CtrlPWMOutputs(TIM1, ENABLE);
     void NVIC_Configuration(void)
  NVIC_InitTypeDef NVIC_InitStructure;
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
  NVIC_InitStructure.NVIC_IRQChannel = TIM1_CC_IRQn;   //TIM1ÖжÏ
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 6;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
void TIM1_SPWM_Init(void)
     TIM1_Mode_Config();
     NVIC_Configuration();
gejigeji521 发表于 2023-7-27 23:10 | 显示全部楼层
怎么还在用老库
温室雏菊 发表于 2023-8-12 17:08 | 显示全部楼层
你用官方的例程试试,也许会好使
故意相遇 发表于 2023-8-12 19:23 | 显示全部楼层
你想要实现定时器的输出啊?
白马过平川 发表于 2023-8-12 21:45 | 显示全部楼层
用仿真器的方式看看程序咋运行的呗
风凉 发表于 2023-8-12 22:12 | 显示全部楼层
这看着没啥问题啊,你用的还是官方的例程吧,是吧
MessageRing 发表于 2023-8-12 23:33 | 显示全部楼层
可能是老产品传下来的
西洲 发表于 2023-8-13 01:12 | 显示全部楼层
是编译报错,还是程序运行的逻辑不对啊?
捧一束彼岸花 发表于 2023-8-13 03:12 | 显示全部楼层
定时器一般得配置一下才行吧?
春日负喧 发表于 2023-8-13 05:13 | 显示全部楼层
建议楼主还是用个例程,参考例程去写和实现吧
将爱藏于深海 发表于 2023-8-13 11:12 | 显示全部楼层
用示波器抓波形看看
她已醉 发表于 2023-8-13 14:22 | 显示全部楼层
感觉进不来中断是不是哪个变量没变化导致的呢
月亮一键变蓝 发表于 2023-8-13 16:13 | 显示全部楼层
你的复用时钟没开吧,AFIO这个
Mowergy 发表于 2023-10-21 16:09 | 显示全部楼层
用官方的例程试试
