因为项目上对时钟要求不高,只需要用到一个9600波特率的串口和一些普通IO口,下面是简单的使用方法。
- void MYRCC_DeInit(void)
- RCC->APB1RSTR = 0x00000000;//复位结束
- RCC->APB2RSTR = 0x00000000;
- RCC->AHBENR = 0x00000014; //睡眠模式闪存和SRAM时钟使能.其他关闭.
- RCC->APB2ENR = 0x00000000; //外设时钟关闭.
- RCC->APB1ENR = 0x00000000;
- RCC->CR |= 0x00000001; //使能内部高速时钟HSION
- RCC->CFGR &= 0xF8FF0000; //复位SW[1:0],HPRE[3:0],PPRE1[2:0],PPRE2[2:0],ADCPRE[1:0],MCO[2:0]
- RCC->CR &= 0xFEF6FFFF; //复位HSEON,CSSON,PLLON
- RCC->CR &= 0xFFFBFFFF; //复位HSEBYP
- RCC->CFGR &= 0xFF80FFFF; //复位PLLSRC, PLLXTPRE, PLLMUL[3:0] and USBPRE
- RCC->CIR = 0x00000000; //关闭所有中断
- //配置向量表
- #ifdef VECT_TAB_RAM
- NVIC_SetVectorTable(0x20000000, 0x0);
- #else
- NVIC_SetVectorTable(0x08000000, 0x0);
- #endif
- void Stm32_Clock_Init(u8 PLL)
- unsigned char temp = 0;
- MYRCC_DeInit(); //复位并配置向量表
- RCC->CR |= 0x00000001; //内部高速时钟使能HSION
- while(!(RCC->CR >> 1)); //等待内部时钟就绪
- RCC->CFGR = 0X00000400; //APB1=DIV2;APB2=DIV1;AHB=DIV1;
- PLL -= 2; //抵消2个单位
- RCC->CFGR |= PLL << 18; //设置PLL值 2~16
- RCC->CFGR |= 0 << 16; //PLLSRC ON HSI经2分频后作为PLL输入时钟
- FLASH->ACR |= 0x32; //FLASH 2个延时周期
- RCC->CR |= 0x01000000; //PLLON
- while(!(RCC->CR >> 25)); //等待PLL锁定
- RCC->CFGR |= 0x00000002; //PLL作为系统时钟
- while(temp != 0x02) //等待PLL作为系统时钟设置成功
- temp = RCC->CFGR >> 2;
- temp &= 0x03;
- int main(void)
- int i;
- Stm32_Clock_Init(12);
- delay_init(); //延时函数初始化
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //设置NVIC中断分组2:2位抢占优先级,2位响应优先级
- uart_init(9600); //串口初始化为115200
- LED_Init(); //LED端口初始化
- TIM3_Int_Init(49, 48 - 1); //10Khz的计数频率,计数到5000为500ms
- while(1)
- printf("hello\r\n");
- delay_ms(1000);
