循迹小车功能实现
灰度部分
- uint8_t stop_way = 0;//停止线检测
- uint8_t sensor_val[5];//灰度返回值
- uint16_t gray_state = 0x0;//当前灰度状态
- uint16_t gray_status[2]={0},gray_status_backup[2][20]={0};//灰度传感器状态与历史值
- uint32_t gray_status_worse=0; //灰度管异常状态计数器
- 函数名称:
- 函数作用:5路循迹获取状态
- 函数参数:无
- 函数返回值:当前巡线状态 16进制
- uint16_t Sensor_GetState(void)
- uint16_t State = 0X0000;
- // sensor_val[0] = HAL_GPIO_ReadPin(GPIOA,GPIO_PIN_0);
- // sensor_val[1] = HAL_GPIO_ReadPin(GPIOA,GPIO_PIN_1);
- // sensor_val[2] = HAL_GPIO_ReadPin(GPIOA,GPIO_PIN_2);
- // sensor_val[3] = HAL_GPIO_ReadPin(GPIOA,GPIO_PIN_3);
- // sensor_val[4] = HAL_GPIO_ReadPin(GPIOA,GPIO_PIN_4);
- // State |= (sensor_val[4] << 4);
- // State |= (sensor_val[3] << 3);
- // State |= (sensor_val[2] << 2);
- // State |= (sensor_val[1] << 1);
- // State |= (sensor_val[0] << 0);
- for(int8_t i=4;i>=0;i--)
- sensor_val[i] = HAL_GPIO_ReadPin(GPIOA,GPIO_PIN_0<<i);
- State |= (sensor_val[i]<<i);
- return State;
- void gray_check(void)
- gray_state = Sensor_GetState();
- //记录上一次传感器量
- for(uint16_t i=19;i>0;i--)
- gray_status_backup[0][i]=gray_status_backup[0][i-1];
- gray_status_backup[0][0]=gray_status[0];
- //灰度检测
- switch(gray_state)
- case 0x01:gray_status[0] = 4; gray_status_worse/=2;break; //00001b
- case 0x03:gray_status[0] = 3; gray_status_worse/=2;break; //00011b
- case 0x02:gray_status[0] = 2; gray_status_worse/=2;break; //00010b
- case 0x06:gray_status[0] = 1; gray_status_worse/=2;break; //00110b
- case 0x04:gray_status[0] = 0; gray_status_worse/=2;break; //00100b
- case 0x0C:gray_status[0] = -1;gray_status_worse/=2;break; //01100b
- case 0x08:gray_status[0] = -2;gray_status_worse/=2;break; //01000b
- case 0x18:gray_status[0] = -3;gray_status_worse/=2;break; //11000b
- case 0x10:gray_status[0] = -4;gray_status_worse/=2;break; //10000b
- case 0x00:gray_status[0] = gray_status_backup[0][0];gray_status_worse++;break; //00000b
- default://其它特殊情况单独判断
- gray_status[0]=gray_status_backup[0][0];
- gray_status_worse++;
- switch(gray_state)//停止线检测
- case 0x0F://01111b
- case 0x1E://11110b
- case 0x1F://11111b
- stop_way++;
- break;
