[STM32WBA] 【STM32WBA52CG测评】+电子时钟显示牌
1573|3
 楼主| jinglixixi 发表于 2023-8-8 22:45 | 显示全部楼层 |阅读模式
#申请原创#
在通常的情况下,我们所所用的显示器件多是数码管、液晶屏、OLED屏及TFT屏。但在公共场合要显示信息,就要有较大尺寸以便观察。
通常多使用半板来拼接成较大的广告牌,这里使用的是一款P4.75的红色点阵板,其显示分辨率为16*64像素点。
图1 点阵屏外观
该点阵屏采用的接口方式为HUB08,各引脚的名称如图2所示。
图2  HUB08接口
图3 硬件构成
该点阵屏与开发板的连接关系为:
A  ----PB0
B  ----PB14
C  ----PB2
D  ----PA12
R1 ----PB3
CLK----PB4
EN ----PA9
STB----PA15
图4 所用接口
所用引脚输出高低电平的语句定义为:
#defineLA_high    HAL_GPIO_WritePin(GPIOB,GPIO_PIN_0, GPIO_PIN_SET)
#defineLA_low     HAL_GPIO_WritePin(GPIOB,GPIO_PIN_0, GPIO_PIN_RESET)
#defineLB_high    HAL_GPIO_WritePin(GPIOB,GPIO_PIN_14, GPIO_PIN_SET)
#defineLB_low     HAL_GPIO_WritePin(GPIOB,GPIO_PIN_14, GPIO_PIN_RESET)
#defineLC_high    HAL_GPIO_WritePin(GPIOB,GPIO_PIN_2, GPIO_PIN_SET)
#defineLC_low     HAL_GPIO_WritePin(GPIOB,GPIO_PIN_2, GPIO_PIN_RESET)
#defineLD_high    HAL_GPIO_WritePin(GPIOA,GPIO_PIN_12, GPIO_PIN_SET)
#defineLD_low     HAL_GPIO_WritePin(GPIOA,GPIO_PIN_12, GPIO_PIN_RESET)
#defineLR1_high   HAL_GPIO_WritePin(GPIOB,GPIO_PIN_3, GPIO_PIN_SET)
#defineLR1_low    HAL_GPIO_WritePin(GPIOB,GPIO_PIN_3, GPIO_PIN_RESET)
#defineCLK_high   HAL_GPIO_WritePin(GPIOB,GPIO_PIN_4, GPIO_PIN_SET)
#defineCLK_low    HAL_GPIO_WritePin(GPIOB,GPIO_PIN_4, GPIO_PIN_RESET)
#defineLEN_high   HAL_GPIO_WritePin(GPIOA,GPIO_PIN_9, GPIO_PIN_SET)
#defineLEN_low    HAL_GPIO_WritePin(GPIOA,GPIO_PIN_9, GPIO_PIN_RESET)
#defineLSTB_high  HAL_GPIO_WritePin(GPIOA,GPIO_PIN_15, GPIO_PIN_SET)
#defineLSTB_low   HAL_GPIO_WritePin(GPIOA,GPIO_PIN_15, GPIO_PIN_RESET)
所用引脚的初始化函数为:
  1. void dzb_GPIO_Init(void)
  3.   __HAL_RCC_GPIOB_CLK_ENABLE();
  4.   GPIO_InitStruct.Mode  = GPIO_MODE_OUTPUT_PP;
  5.   GPIO_InitStruct.Pull  = GPIO_NOPULL;
  6.   GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
  7.   GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_2|GPIO_PIN_3|GPIO_PIN_4|GPIO_PIN_10|GPIO_PIN_14;
  8.   HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
  9.   __HAL_RCC_GPIOA_CLK_ENABLE();
  10.   GPIO_InitStruct.Pin = GPIO_PIN_9|GPIO_PIN_12|GPIO_PIN_15;
  11.   HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  12. }
点阵板发送数据的函数为:
  1. void OutByte(u16 dat)
  3.     u8 i=0 ;
  4.     for(i=0;i<16;i++)
  5.     {
  6.         CLK_low;
  7.         if(dat&0x0001)
  8.         {
  9.             LR1_high;
  10.         }
  11.         else
  12.         {
  13.             LR1_low;
  14.         }
  15.         dat=dat>>1;
  16.         CLK_high;
  17.     }
  18. }
发送多列数据的函数为:
  1. void DisCol(u16 lenght)
  3.     u16 dat;
  4.     u8 m=0;
  5.     while(lenght--)
  6.     {
  7.          dat=(S[sj[m+1]*16+ScanRow]<<8)+S[sj[m]*16+ScanRow];
  8.          OutByte(dat);
  9.          m=m+2;
  10.     }
  11. }
输出行地址的函数为:
  1. void  SeleRow(u8 Nd)
  3.     u8 N;
  4.     N=Nd;
  5.     N=N%16;
  6.     if(N&0x01)   LA_high;
  7.     else  LA_low;
  8.     if (N&0x02)  LB_high;
  9.     else  LB_low;
  10.     if (N&0x04)  LC_high;
  11.     else  LC_low;
  12.     if (N&0x08)  LD_high;
  13.     else  LD_low;
  14. }
实现显示输出的函数为:
  1. void  Display(void)
  3.       DisCol(4);
  4.       LEN_high;
  5.       LSTB_high;
  6.       LSTB_low;
  7.       SeleRow(ScanRow);
  8.       LEN_low;
  9.       ScanRow++;
  10.       if(ScanRow>15)  ScanRow=0;
  11. }
为实现数字符号的显示,以字模提取软件所构建的字库存储结构为:
u8 S[]={
0x00,0x00,0x00,0x18,0x24,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x24,0x18,0x00,0x00,/*"0",0*/
0x00,0x00,0x00,0x08,0x0E,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x3E,0x00,0x00,/*"1",1*/
0x00,0x00,0x00,0x3C,0x42,0x42,0x42,0x20,0x20,0x10,0x08,0x04,0x42,0x7E,0x00,0x00,/*"2",2*/
0x00,0x00,0x00,0x18,0x24,0x42,0x42,0x42,0x64,0x58,0x40,0x40,0x24,0x1C,0x00,0x00,/*"9",9*/
0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x18,0x00,0x00,0x00,0x00,0x18,0x18,0x00,0x00,/*":",10*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"-",11*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",12*/
读取RTC计时值函数为:
  1. static void RTC_CalendarShow(uint8_t *showtime, uint8_t *showdate)
  3.   RTC_DateTypeDef sdatestructureget;
  4.   RTC_TimeTypeDef stimestructureget;
  5.   HAL_RTC_GetTime(&hrtc, &stimestructureget, RTC_FORMAT_BIN);
  6.   HAL_RTC_GetDate(&hrtc, &sdatestructureget, RTC_FORMAT_BIN);
  7.   sj[0]=stimestructureget.Hours/10;
  8.   sj[1]=stimestructureget.Hours%10;
  9.   sj[3]=stimestructureget.Minutes/10;
  10.   sj[4]=stimestructureget.Minutes%10;
  11.   sj[6]=stimestructureget.Seconds/10;
  12.   sj[7]=stimestructureget.Seconds%10;
  13.   Display();
  14. }
实现显示输出效果的函数为:
  1. int main(void)
  3.   HAL_Init();
  4.   SystemClock_Config();
  5.   MX_RTC_Init();
  6.   MX_ICACHE_Init();
  7.   RTCStatus = 1;
  8.   dzb_GPIO_Init();
  9.   ScanRow=0;
  10.   while (1)
  11.   {
  12.     RTC_CalendarShow(aShowTime, aShowDate);
  13.   }
  14. }
经程序的编译与下载,其执行效果如图4所示。在添加字库的情况下,其汉字显示效果如图5所示。
图5 显示效果
视频演示:
gejigeji521 发表于 2024-1-12 17:05 | 显示全部楼层
这个是什么接口的?
gejigeji521 发表于 2024-1-12 17:06 | 显示全部楼层
第一次看到这个接口。
 楼主| jinglixixi 发表于 2024-1-12 21:44 | 显示全部楼层
这个是什么接口的?
HUB08接口,一种点阵板常用的接口。
