ccs simulate FIR 求助
3353|3
 楼主| cflky 发表于 2012-5-3 23:17 | 显示全部楼层 |阅读模式
main.c已编译通过了,生成.out文件.然后我在CCS 软件的File->Load Program 里打开这个.out 文件。想将滤波器设计文件载入到内存中。出现如下错误Loader: One or more sections of your program falls into a memory region that is not writable.  These regions will not actually be written to the target.  Check your linker configuration and/or memory map.(见截图)请问怎么办?cmd文件如下
  1. MEMORY
  3. PAGE 0: EPROG: origin = 0x1400, len = 0x7c00
  4. VECT: origin = 0xff80, len = 0x80
  5. PAGE 1: USERREGS: origin = 0x60, len = 0x1c
  6. BIOSREGS: origin = 0x7c, len = 0x4
  7. IDATA: origin = 0x80, len = 0x1380
  8. EDATA: origin = 0x1400, len = 0x8000
  9. EDATA1: origin = 0x9400, len = 0x4c00
  10. }
  11. SECTIONS
  12. {
  13. .vectors: {} > VECT PAGE 0
  14. .sysregs: {} > BIOSREGS PAGE 1
  15. .trcinit: {} > EPROG PAGE 0
  16. .gblinit: {} > EPROG PAGE 0
  17. frt: {} > EPROG PAGE 0
  18. .text: {} > EPROG PAGE 0
  19. .cinit: {} > EPROG PAGE 0
  20. .pinit: {} > EPROG PAGE 0
  21. .sysinit: {} > EPROG PAGE 0
  22. .bss: {} > IDATA PAGE 1
  23. .far: {} > IDATA PAGE 1
  24. .const: {} > IDATA PAGE 1
  25. .switch: {} > IDATA PAGE 1
  26. .sysmem: {} > IDATA PAGE 1
  27. .cio: {} > IDATA PAGE 1
  28. .MEM$obj: {} > IDATA PAGE 1
  29. .sysheap: {} > IDATA PAGE 1
  30. .stack: {} > IDATA PAGE 1
  31. }
highcad 发表于 2013-2-14 23:47 | 显示全部楼层
顶一下,同样的问题呀!
airwill 发表于 2013-2-17 22:26 | 显示全部楼层
提示内存区域不可写, 应该是 CMD 文件问题.
jlass 发表于 2013-2-21 16:11 | 显示全部楼层
重叠了
把其中一个往后移
