[文档下载] MG0023_从AT32F415移植到AT32F423
1186|1
 楼主| ArterySW 发表于 2023-8-15 20:04 | 显示全部楼层 |阅读模式
这篇迁移指南旨在帮助您分析从现有的AT32F415器件迁移到AT32F423器件所需的步骤。本文档收
集了最重要的信息,并列出了需要注意的重要事项。
要将应用程序从AT32F415系列迁移到AT32F423系列,用户需要分析硬件迁移、软件迁移。
目录
AT32F423 与AT32F415 异同 ...................................................................................... 5
相同点概述 ............................................................................................................... 5
差异点概述 ............................................................................................................... 5
硬件迁移 .................................................................................................................. 6
启动模式兼容性 ........................................................................................................ 7
软件迁移 .................................................................................................................. 8
外设对比 .................................................................................................................. 8
功能区别 .................................................................................................................. 8
存储器映射 ............................................................................................................... 8
中断向量 .................................................................................................................. 9
ADC 接口 ................................................................................................................. 12
CAN 接口 ................................................................................................................. 13
CRM 接口 ................................................................................................................. 13
DMA 接口 ................................................................................................................. 13
Flash 接口 ................................................................................................................ 13
实时时钟ERTC 接口 .................................................................................................. 13
EXINT 中断源选择 .................................................................................................... 14
GPIO ....................................................................................................................... 14
I2C 接口................................................................................................................... 14
IOMUX .................................................................................................................... 14
PWC 接口 ................................................................................................................ 15
SPI 接口 .................................................................................................................. 15
安全库区保护接口 .................................................................................................... 15
TMR 接口 ................................................................................................................ 15
WDT 接口 ............................................................................................................... 15
USART 接口 ............................................................................................................ 16
外设增强 ................................................................................................................. 16
AT32F423 新增WKUP 引脚 ....................................................................................... 16
AT32F423 新增红外发射器........................................................................................ 16
AT32F423 新增TMR 的16 位RPR 寄存器 .................................................................... 16
AT32F423 新增HICK 自动时钟校准模块 ..................................................................... 16
AT32F423 新增OTGFS 设备端点号和主机通道 ............................................................ 16
AT32F423 新增XMC 外设 .......................................................................................... 16
AT32F423 新增DAC 外设 .......................................................................................... 16
AT32F423 新增I2S 全双工功能 ................................................................................. 17
AT32F423 新增SPI 的TI 模式功能 ............................................................................. 17
AT32F423 新增GPIO 位翻转功能 ............................................................................... 17
MG0023_Migrating_from_AT32F415_to_AT32F423_V2.0.0.pdf (1.02 MB, 下载次数: 7)
