[STM32F4] 0.96寸OLED在STM32f103上实现滚动显示长字符
1393|11
 楼主| grfqq325 发表于 2023-8-25 16:42 | 显示全部楼层 |阅读模式
OLED屏的滚屏命令
  • 水平左右移
  1. OLED_WR_Byte(0x2E,OLED_CMD);        //关闭滚动
  2. OLED_WR_Byte(0x26,OLED_CMD);        //水平向左或者右滚动 26/27
  3. OLED_WR_Byte(0x00,OLED_CMD);        //虚拟字节
  4. OLED_WR_Byte(0x00,OLED_CMD);        //起始页 0
  5. OLED_WR_Byte(0x07,OLED_CMD);        //滚动时间间隔
  6. OLED_WR_Byte(0x07,OLED_CMD);        //终止页 7
  7. OLED_WR_Byte(0x00,OLED_CMD);        //虚拟字节
  8. OLED_WR_Byte(0xFF,OLED_CMD);        //虚拟字节
  9. OLED_WR_Byte(0x2F,OLED_CMD);        //开启滚动
本篇博客只用到了水平移动
对需要显示的文字进行取模
  1.   "晓",0x00,0x80,0x00,0x80,0x78,0xBC,0x4B,0xC0,0x48,0x50,0x48,0x24,0x48,0xD4,0x7B,0x0C,
  2.   0x48,0x00,0x4B,0xFE,0x48,0x90,0x48,0x90,0x79,0x12,0x49,0x12,0x02,0x0E,0x04,0x00,/*"晓",0*/
  3.   "看",0x00,0xF8,0x7F,0x00,0x01,0x00,0x3F,0xF8,0x02,0x00,0xFF,0xFE,0x04,0x00,0x08,0x00,
  4.   0x1F,0xF0,0x28,0x10,0x4F,0xF0,0x88,0x10,0x0F,0xF0,0x08,0x10,0x0F,0xF0,0x08,0x10,/*"看",1*/
  5.   "天",0x00,0x00,0x3F,0xF8,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0xFF,0xFE,0x01,0x00,
  6.   0x02,0x80,0x02,0x80,0x04,0x40,0x04,0x40,0x08,0x20,0x10,0x10,0x20,0x08,0xC0,0x06,/*"天",2*/
  7.   "色",0x08,0x00,0x08,0x00,0x1F,0xE0,0x20,0x20,0x40,0x40,0xBF,0xF8,0x21,0x08,0x21,0x08,
  8.   0x21,0x08,0x3F,0xF8,0x20,0x00,0x20,0x02,0x20,0x02,0x20,0x02,0x1F,0xFE,0x00,0x00,/*"色",3*/
  9.   "暮",0x04,0x40,0x7F,0xFC,0x04,0x40,0x1F,0xF0,0x10,0x10,0x1F,0xF0,0x10,0x10,0x1F,0xF0,
  10.   0x04,0x00,0xFF,0xFE,0x10,0x10,0x2F,0xE8,0xC8,0x26,0x0F,0xE0,0x08,0x20,0x0F,0xE0,/*"暮",4*/
  11.   "看",0x00,0xF8,0x7F,0x00,0x01,0x00,0x3F,0xF8,0x02,0x00,0xFF,0xFE,0x04,0x00,0x08,0x00,
  12.   0x1F,0xF0,0x28,0x10,0x4F,0xF0,0x88,0x10,0x0F,0xF0,0x08,0x10,0x0F,0xF0,0x08,0x10,/*"看",5*/
  13.   "云",0x00,0x00,0x3F,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFE,0x02,0x00,
  14.   0x04,0x00,0x04,0x00,0x08,0x40,0x10,0x20,0x20,0x10,0x7F,0xF8,0x20,0x08,0x00,0x08,/*"云",6*/
 楼主| grfqq325 发表于 2023-8-25 16:43 | 显示全部楼层
修改程序代码
main函数:
  1. int main(void)
  3.         delay_init();                           //延时函数初始化
  4.         NVIC_Configuration();            //设置NVIC中断分组2:2位抢占优先级,2位响应优先级
  5.         OLED_Init();                                 //初始化OLED
  6.         OLED_Clear(0);             //清屏(全黑)
  7.         OLED_WR_Byte(0x2E,OLED_CMD);        //关闭滚动
  8.     OLED_WR_Byte(0x27,OLED_CMD);        //水平向左或者右滚动 26/27
  9.     OLED_WR_Byte(0x00,OLED_CMD);        //虚拟字节
  10.         OLED_WR_Byte(0x00,OLED_CMD);        //起始页 0
  11.         OLED_WR_Byte(0x07,OLED_CMD);        //滚动时间间隔
  12.         OLED_WR_Byte(0x07,OLED_CMD);        //终止页 7
  13.         OLED_WR_Byte(0x00,OLED_CMD);        //虚拟字节
  14.         OLED_WR_Byte(0xFF,OLED_CMD);        //虚拟字节
  15.         TEST_MainPage();
  16.         OLED_WR_Byte(0x2F,OLED_CMD);        //开启滚动
  17. }
显示数据函数
  1. void TEST_MainPage(void)
  3.         GUI_ShowCHinese(10,20,16,"晓看天色暮看云",1);
  4.         delay_ms(1500);
  5.         delay_ms(1500);
  6. }
、烧录运行结果
总结
本次实验相比上次多出了让数据滚动的功能,主要差别在主函数中的代码,其他的和上次实验几乎相同。
zhuhuis 发表于 2023-8-25 21:50 | 显示全部楼层
一模一样的帖子?
daichaodai 发表于 2023-8-26 09:16 来自手机 | 显示全部楼层
这个和OLED屏的驱动器有关系。
AIsignel 发表于 2023-8-28 13:46 | 显示全部楼层
是整个屏幕都进行滚动嘛?
鹿鼎计 发表于 2023-8-28 13:46 | 显示全部楼层
可以指定某个区域进行滚动嘛?
理想阳 发表于 2023-8-28 13:47 | 显示全部楼层
这种全屏滚动应用场景还是不多的吧。
