hc32l130 Sysctrl_ClkSourceEnable问题请教
2023|0
 楼主| jackcaj 发表于 2023-8-29 10:27 | 显示全部楼层 |阅读模式
** \brief 系统时钟源使能
** \param [in]  enSource   目标时钟源
** \param [in]  bFlag      使能1-开/0-关
** \retval      Ok         设定成功
**             其他        设定失败
en_result_t Sysctrl_ClkSourceEnable(en_sysctrl_clk_source_t enSource, boolean_t bFlag)
    en_result_t enRet = Ok;
    uint32_t u32Temp;
    _SysctrlUnlock();
    bFlag = !!bFlag;
    u32Temp = M0P_SYSCTRL->PERI_CLKEN;
    switch (enSource)
        case SysctrlClkRCH:
            M0P_SYSCTRL->SYSCTRL0_f.RCH_EN = bFlag;
            while(bFlag && (1 != M0P_SYSCTRL->RCH_CR_f.STABLE))
            break;
        case SysctrlClkXTH:
            M0P_SYSCTRL->PERI_CLKEN_f.GPIO = TRUE;
            M0P_GPIO->PDADS |= 3u;
            M0P_SYSCTRL->SYSCTRL0_f.XTH_EN = bFlag;
            while(bFlag && (1 != M0P_SYSCTRL->XTH_CR_f.STABLE))
            break;
        case SysctrlClkRCL:
            M0P_SYSCTRL->SYSCTRL0_f.RCL_EN = bFlag;
            while(bFlag && (1 != M0P_SYSCTRL->RCL_CR_f.STABLE))
            break;
        case SysctrlClkXTL:
            M0P_GPIO->PCADS |= 0xC000;
            M0P_SYSCTRL->SYSCTRL0_f.XTL_EN = bFlag;
            while(bFlag && (1 != M0P_SYSCTRL->XTL_CR_f.STABLE))
            break;
        case SysctrlClkPLL:
            M0P_SYSCTRL->PERI_CLKEN_f.ADC = TRUE;
            M0P_BGR->CR_f.BGR_EN = TRUE;
            delay10us(20);
            M0P_SYSCTRL->SYSCTRL0_f.PLL_EN = bFlag;
            while(bFlag && (1 != M0P_SYSCTRL->PLL_CR_f.STABLE))
            break;
        default:
            enRet = ErrorInvalidParameter;
            break;
    M0P_SYSCTRL->PERI_CLKEN = u32Temp;
    return enRet;
下划线代码主要作用是什么?
