在nuc972进行Linux移植的过程中出现下面一个问题
1069|0
 楼主| 含蓄1111111 发表于 2023-9-7 15:24 | 显示全部楼层 |阅读模式
VFS: Mounted root (yaffs2 filesystem) on device 31:2.
devtmpfs: mounted
Freeing unused kernel memory: 144K (c04b5000 - c04d9000)
Kernel panic - not syncing: No init found.  Try passing init= option to kernel. See Linux Documentation/init.txt for guidance.
CPU: 0 PID: 1 Comm: swapper Not tainted 3.10.107 #136
Backtrace:
[<c0012c68>] (dump_backtrace+0x0/0x10c) from [<c0012d8c>] (show_stack+0x18/0x1c)
r7:00000000 r6:00000000 r5:c03baa0c r4:c051b3c0
[<c0012d74>] (show_stack+0x0/0x1c) from [<c03bb36c>] (dump_stack+0x20/0x2c)
[<c03bb34c>] (dump_stack+0x0/0x2c) from [<c03bb01c>] (panic+0xa0/0x208)
[<c03baf7c>] (panic+0x0/0x208) from [<c03baad4>] (kernel_init+0xc8/0xec)
r3:c00c5ce4 r2:c3a5f000 r1:c05d8070 r0:c0454c58
[<c03baa0c>] (kernel_init+0x0/0xec) from [<c000f698>] (ret_from_fork+0x14/0x3c)
r5:c03baa0c r4:00000000
