[其他模拟产品-信号链] TI ADS1115 16位精密模数转换方案
3775|1
 楼主| tianyu01 发表于 2012-5-5 11:39 | 显示全部楼层 |阅读模式
TI公司的ADS1113, ADS1114和ADS1115是超小型16位精密模数转换器(ADC),具有板载基准电压和振荡器,通过I2C兼容接口传输数据,工作电压从2.0V到5.5V,取样频率高达860SPS,.连续模式的功耗仅为150uA, 工作温度从–40℃ 到+140℃,可用在手提仪表,消费类产品,电池监视,温度测量以及工厂自动化和过程控制.本文介绍了ADS1113, ADS1114和ADS1115的主要特性,方框图, 基本硬件配置图, 典型连接图, 多个ADS1113/4/5连接图以及评估板ADS1015EVM/ADS1115EVM电路图和材料清单.
The ADS1113, ADS1114, and ADS1115 are precision analog-to-digital converters (ADCs) with 16 bits of resolution offered in an ultra-small, leadless QFN-10 package or an MSOP-10 package. The ADS1113/4/5 are designed with precision, power, and ease of implementation in mind. The ADS1113/4/5 feature an onboard reference and oscillator. Data are transferred via an I2C-compatible serial interface; four I2C slave addresses can be selected. The ADS1113/4/5 operate from a single power supply ranging from 2.0V to 5.5V.
The ADS1113/4/5 can perform conversions at rates up to 860 samples per second (SPS). An onboard PGA is available on the ADS1114 and ADS1115 that offers input ranges from the supply to as low as ±256mV, allowing both large and small signals to be measured with high resolution. The ADS1115 also features an input multiplexer (MUX) that provides two differential or four single-ended inputs.
The ADS1113/4/5 operate either in continuous conversion mode or a single-shot mode that automatically powers down after a conversion and greatly reduces current consumption during idle periods. The ADS1113/4/5 are specified from –40℃to +125℃.
ADS1115主要特性:
ULTRA-SMALL QFN PACKAGE:
2mm × 1,5mm × 0,4mm
WIDE SUPPLY RANGE: 2.0V to 5.5V
LOW CURRENT CONSUMPTION:
Continuous Mode: Only 150µA
Single-Shot Mode: Auto Shut-Down
PROGRAMMABLE DATA RATE:
8SPS to 860SPS
INTERNAL LOW-DRIFT
VOLTAGE REFERENCE
INTERNAL OSCILLATOR
INTERNAL PGA
I2C INTERFACE: Pin-Selectable Addresses
FOUR SINGLE-ENDED OR TWO DIFFERENTIAL INPUTS (ADS1115)
PROGRAMMABLE COMPARATOR (ADS1114 and ADS1115)
OPERATING TEMPERATURE: –40℃ to +140℃
ADS1115应用:
PORTABLE INSTRUMENTATION
CONSUMER GOODS
BATTERY MONITORING
TEMPERATURE MEASUREMENT
FACTORY AUTOMATION AND PROCESS CONTROLS
图1.ADS1115功能方框图
图2.ADS1115基本硬件配置图
图3.ADS1115典型连接图
图4.多个ADS1113/4/5连接图
图5.多个器件类型连接图
图6.ADS1115EVM (左)和ADS1115EVM-PDK (右)外形图
ADS1015EVM/ADS1115EVM 评估板主要特性:
Contains all support circuitry needed for the ADS1015/ADS1115
Two ADS1015/ADS1115 devices onboard to demonstrate I2C™ bus functionality
+3.3, +5V, or external power supply options for ADC
Compatible with the TI Modular EVM System
ADS1015EVM-PDK/ADS1115EVM-PDK 主要特性:
Easy-to-use evaluation software for Microsoft® Windows® XP
Data collection to text files
Built-in analysis tools including scope, FFT, and histogram displays
Complete control of board settings
Easily expandable with new analysis plug-in tools from Texas Instruments
图7.MMB3方框图
图8. ADS1015EVM/ADS1115EVM电路图
ADS1015EVM/ADS1115EVM 材料清单:
liwsx 发表于 2012-5-5 11:40 | 显示全部楼层
能送我一块评估板就好了
