构造GNUARM 出错了,知道的仁兄帮忙解决一下
2736|1
 楼主| shenhm 发表于 2008-8-24 10:52 | 显示全部楼层 |阅读模式
第一步构造binutils 时出错了:
显示如下
loading cache ./config.cache
checking host system type... i686-pc-cygwin
checking target system type... arm-unknown-elf
checking build system type... i686-pc-cygwin
checking for a BSD compatible install... /usr/bin/install -c
checking whether ln works... yes
checking whether ln -s works... yes
checking for gcc... gcc
checking whether the C compiler (gcc  ) works... no
conifgure:error:installation or configuration problem:c compiler cannot executables
cygwin 我选的完全安装,肯定装了GCC的,怎么还会报错了,
config.log信息
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
configure:595: checking host system type
configure:616: checking target system type
configure:634: checking build system type
configure:689: checking for a BSD compatible install
configure:742: checking whether ln works
configure:766: checking whether ln -s works
configure:1809: checking for gcc
configure:1922: checking whether the C compiler (gcc  ) works
configure:1938: gcc -o conftest    conftest.c  1>&5
configure: failed program was:
#line 1933 "configure"
#include "confdefs.h"
main(){return(0);}
armecos 发表于 2008-8-24 11:27 | 显示全部楼层
《ecos增值包》里有现成的GNU for ARM环境,
还有汇编、C/C++、混合编程范例程序以及详细的cygwin安装使用方法。
更多内容,详见:
《培训系列“丛书”》
www.armecos.com
More details, see:
《"Series Books" of Training》
www.armecos.com
