[应用相关] mcu stm32 gui lvgl8.2 软件示例
686|1
 楼主| coshi 发表于 2023-9-19 15:20 | 显示全部楼层 |阅读模式
lvgl 8.2
void ui_init(void)
      lv_disp_t * dispp = lv_disp_get_default();
    lv_theme_t * theme = lv_theme_default_init(dispp, lv_palette_main(LV_PALETTE_BLUE), lv_palette_main(LV_PALETTE_RED),
                                               false, LV_FONT_DEFAULT);
    lv_disp_set_theme(dispp, theme);
    ui_START_screen_init();
    ui_M1_screen_init();
    ui_M2_screen_init();
    ui_M11_screen_init();
    ui_M22_screen_init();
    ui____initial_actions0 = lv_obj_create(NULL);
    lv_disp_load_scr(ui_START);
void ui_START_screen_init(void)
    ui_START = lv_obj_create(NULL);
    lv_obj_clear_flag(ui_START, LV_OBJ_FLAG_SCROLLABLE);      /// Flags
    ui_Image7 = lv_img_create(ui_START);
    lv_img_set_src(ui_Image7, &ui_img_1311359175);
    lv_obj_set_width(ui_Image7, LV_SIZE_CONTENT);   /// 244
    lv_obj_set_height(ui_Image7, LV_SIZE_CONTENT);    /// 244
    lv_obj_set_align(ui_Image7, LV_ALIGN_CENTER);
    lv_obj_add_flag(ui_Image7, LV_OBJ_FLAG_ADV_HITTEST);     /// Flags
    lv_obj_clear_flag(ui_Image7, LV_OBJ_FLAG_SCROLLABLE);      /// Flags
    lv_obj_add_event_cb(ui_Image7, ui_event_Image7, LV_EVENT_ALL, NULL);
    lv_obj_add_event_cb(ui_START, ui_event_START, LV_EVENT_ALL, NULL);
void ui_event_START(lv_event_t * e)
    lv_event_code_t event_code = lv_event_get_code(e);
    lv_obj_t * target = lv_event_get_target(e);
    if(event_code == LV_EVENT_SCREEN_LOADED) {
        _ui_screen_change(&ui_M1, LV_SCR_LOAD_ANIM_FADE_ON, 500, 1000, &ui_M1_screen_init);
void ui_M1_screen_init(void)
    ui_M1 = lv_obj_create(NULL);
    lv_obj_clear_flag(ui_M1, LV_OBJ_FLAG_SCROLLABLE);      /// Flags
    ui_S1 = lv_img_create(ui_M1);
    lv_img_set_src(ui_S1, &ui_impng);
    lv_obj_set_width(ui_S1, LV_SIZE_CONTENT);   /// 244
    lv_obj_set_height(ui_S1, LV_SIZE_CONTENT);    /// 244
    lv_obj_set_align(ui_S1, LV_ALIGN_CENTER);
    lv_obj_add_flag(ui_S1, LV_OBJ_FLAG_ADV_HITTEST);     /// Flags
    lv_obj_clear_flag(ui_S1, LV_OBJ_FLAG_SCROLLABLE);      /// Flags
```cpp
void _ui_screen_change(lv_obj_t ** target, lv_scr_load_anim_t fademode, int spd, int delay, void (*target_init)(void))
    if(*target == NULL)
        target_init();
    lv_scr_load_anim(*target, fademode, spd, delay, false);
版权声明:本文为CSDN博主「8421plus」的原创文章,遵循CC 4.0 BY-SA版权协议,转载请附上原文出处链接及本声明。
原文链接:https://blog.csdn.net/iyy123IUU/article/details/132907598
Henryko 发表于 2023-9-19 22:50 | 显示全部楼层
有演示视频吗、
