[开发工具] 求助帖,MAPLAB编译失败问题
1407|6
 楼主| lllccc1 发表于 2023-9-20 13:45 | 显示全部楼层 |阅读模式
导入一个项目,然后点击编译,一直报错,如下文所示:
../APP_Model_V002.X/APP_Model_V002.c:5: error: stray '\209' in program
../APP_Model_V002.X/APP_Model_V002.c:5: error: stray '\219' in program
../APP_Model_V002.X/APP_Model_V002.c:5: error: stray '#' in program
../APP_Model_V002.X/APP_Model_V002.c:5: error: stray '\228' in program
../APP_Model_V002.X/APP_Model_V002.c:5: error: stray '\221' in program
../APP_Model_V002.X/APP_Model_V002.c:5: error: stray '\193' in program
../APP_Model_V002.X/APP_Model_V002.c:5: error: stray '\183' in program
../APP_Model_V002.X/APP_Model_V002.c:5: error: stray '\153' in program
../APP_Model_V002.X/APP_Model_V002.c:5: error: stray '\173' in program
../APP_Model_V002.X/APP_Model_V002.c:5: error: stray '\30' in program
../APP_Model_V002.X/APP_Model_V002.c:5: error: stray '\8' in program
../APP_Model_V002.X/APP_Model_V002.c:5: error: stray '\162' in program
../APP_Model_V002.X/APP_Model_V002.c:5:82497: warning: no newline at end of file
make[2]: *** [build/default/production/_ext/1572851945/APP_Model_V002.o] Error 1
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
"C:\Users\chuang.li\AppData\Roaming\Microchip\MPLAB C30\bin\pic30-gcc.exe" -g -omf=elf -x c -c -mcpu=30F4011 -MMD -MF build/default/production/_ext/1572851945/APP_Model_V002.o.d -o build/default/production/_ext/1572851945/APP_Model_V002.o ../APP_Model_V002.X/APP_Model_V002.c
nbproject/Makefile-default.mk:322: recipe for target 'build/default/production/_ext/1572851945/APP_Model_V002.o' failed
make[2]: Leaving directory 'C:/Users/chuang.li/Desktop/Mplab_CCU_21.X'
nbproject/Makefile-default.mk:84: recipe for target '.build-conf' failed
make[1]: Leaving directory 'C:/Users/chuang.li/Desktop/Mplab_CCU_21.X'
nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
编译已失败 (退出值2, 总时间: 3m 6s)
 楼主| lllccc1 发表于 2023-9-20 13:47 | 显示全部楼层
file:///C:/Users/chuang.li/Desktop/24784656-e6e1-454f-85b0-934385d80806.jpeg
1564564 发表于 2023-10-8 18:22 | 显示全部楼层
这意思是文件丢失嘛
heisexingqisi 发表于 2023-10-9 22:08 | 显示全部楼层
不如上传工程,不然真不好看是什么问题。
heisexingqisi 发表于 2023-10-9 22:09 | 显示全部楼层
这个是要求最后要有一行空行。
hu9jj 发表于 2023-10-10 08:22 | 显示全部楼层
那么多的报错也许就是一个问题引起的,先按楼上说的在代码最末尾加上空行试试看。
Henryko 发表于 2023-10-10 13:31 | 显示全部楼层
可以把代码上传一下吗
