[超级CRC计算器] CRC32L_04C11DB7_FFFFFFFF_00000000源码(www.hotcrc.com自动生成)
611|0
 楼主| hotpower 发表于 2023-9-21 10:17 | 显示全部楼层 |阅读模式
  1. /*------------------------------------------------------------------------------
  2.    本C语言核心代码由菜农HotPower@163.com的超级CRC计算器自动生成
  3.    Copyright 1996-2022 HotPower Software, Inc.
  4.    菜农HotPower[url=home.php?mod=space&uid=516618]@163.com[/url] 2023年9月21日 10:15:27 于西安雁塔菜地
  5. ------------------------------------------------------------------------------*/
  6. //CRC单表大表表格:
  7. const unsigned long CRC32L_04C11DB7_Table[256] = {//特别注意Keil C51请用code替换const
  8.   0x00000000L,0x04C11DB7L,0x09823B6EL,0x0D4326D9L,0x130476DCL,0x17C56B6BL,0x1A864DB2L,0x1E475005L,
  9.   0x2608EDB8L,0x22C9F00FL,0x2F8AD6D6L,0x2B4BCB61L,0x350C9B64L,0x31CD86D3L,0x3C8EA00AL,0x384FBDBDL,
  10.   0x4C11DB70L,0x48D0C6C7L,0x4593E01EL,0x4152FDA9L,0x5F15ADACL,0x5BD4B01BL,0x569796C2L,0x52568B75L,
  11.   0x6A1936C8L,0x6ED82B7FL,0x639B0DA6L,0x675A1011L,0x791D4014L,0x7DDC5DA3L,0x709F7B7AL,0x745E66CDL,
  12.   0x9823B6E0L,0x9CE2AB57L,0x91A18D8EL,0x95609039L,0x8B27C03CL,0x8FE6DD8BL,0x82A5FB52L,0x8664E6E5L,
  13.   0xBE2B5B58L,0xBAEA46EFL,0xB7A96036L,0xB3687D81L,0xAD2F2D84L,0xA9EE3033L,0xA4AD16EAL,0xA06C0B5DL,
  14.   0xD4326D90L,0xD0F37027L,0xDDB056FEL,0xD9714B49L,0xC7361B4CL,0xC3F706FBL,0xCEB42022L,0xCA753D95L,
  15.   0xF23A8028L,0xF6FB9D9FL,0xFBB8BB46L,0xFF79A6F1L,0xE13EF6F4L,0xE5FFEB43L,0xE8BCCD9AL,0xEC7DD02DL,
  16.   0x34867077L,0x30476DC0L,0x3D044B19L,0x39C556AEL,0x278206ABL,0x23431B1CL,0x2E003DC5L,0x2AC12072L,
  17.   0x128E9DCFL,0x164F8078L,0x1B0CA6A1L,0x1FCDBB16L,0x018AEB13L,0x054BF6A4L,0x0808D07DL,0x0CC9CDCAL,
  18.   0x7897AB07L,0x7C56B6B0L,0x71159069L,0x75D48DDEL,0x6B93DDDBL,0x6F52C06CL,0x6211E6B5L,0x66D0FB02L,
  19.   0x5E9F46BFL,0x5A5E5B08L,0x571D7DD1L,0x53DC6066L,0x4D9B3063L,0x495A2DD4L,0x44190B0DL,0x40D816BAL,
  20.   0xACA5C697L,0xA864DB20L,0xA527FDF9L,0xA1E6E04EL,0xBFA1B04BL,0xBB60ADFCL,0xB6238B25L,0xB2E29692L,
  21.   0x8AAD2B2FL,0x8E6C3698L,0x832F1041L,0x87EE0DF6L,0x99A95DF3L,0x9D684044L,0x902B669DL,0x94EA7B2AL,
  22.   0xE0B41DE7L,0xE4750050L,0xE9362689L,0xEDF73B3EL,0xF3B06B3BL,0xF771768CL,0xFA325055L,0xFEF34DE2L,
  23.   0xC6BCF05FL,0xC27DEDE8L,0xCF3ECB31L,0xCBFFD686L,0xD5B88683L,0xD1799B34L,0xDC3ABDEDL,0xD8FBA05AL,
  24.   0x690CE0EEL,0x6DCDFD59L,0x608EDB80L,0x644FC637L,0x7A089632L,0x7EC98B85L,0x738AAD5CL,0x774BB0EBL,
  25.   0x4F040D56L,0x4BC510E1L,0x46863638L,0x42472B8FL,0x5C007B8AL,0x58C1663DL,0x558240E4L,0x51435D53L,
  26.   0x251D3B9EL,0x21DC2629L,0x2C9F00F0L,0x285E1D47L,0x36194D42L,0x32D850F5L,0x3F9B762CL,0x3B5A6B9BL,
  27.   0x0315D626L,0x07D4CB91L,0x0A97ED48L,0x0E56F0FFL,0x1011A0FAL,0x14D0BD4DL,0x19939B94L,0x1D528623L,
  28.   0xF12F560EL,0xF5EE4BB9L,0xF8AD6D60L,0xFC6C70D7L,0xE22B20D2L,0xE6EA3D65L,0xEBA91BBCL,0xEF68060BL,
  29.   0xD727BBB6L,0xD3E6A601L,0xDEA580D8L,0xDA649D6FL,0xC423CD6AL,0xC0E2D0DDL,0xCDA1F604L,0xC960EBB3L,
  30.   0xBD3E8D7EL,0xB9FF90C9L,0xB4BCB610L,0xB07DABA7L,0xAE3AFBA2L,0xAAFBE615L,0xA7B8C0CCL,0xA379DD7BL,
  31.   0x9B3660C6L,0x9FF77D71L,0x92B45BA8L,0x9675461FL,0x8832161AL,0x8CF30BADL,0x81B02D74L,0x857130C3L,
  32.   0x5D8A9099L,0x594B8D2EL,0x5408ABF7L,0x50C9B640L,0x4E8EE645L,0x4A4FFBF2L,0x470CDD2BL,0x43CDC09CL,
  33.   0x7B827D21L,0x7F436096L,0x7200464FL,0x76C15BF8L,0x68860BFDL,0x6C47164AL,0x61043093L,0x65C52D24L,
  34.   0x119B4BE9L,0x155A565EL,0x18197087L,0x1CD86D30L,0x029F3D35L,0x065E2082L,0x0B1D065BL,0x0FDC1BECL,
  35.   0x3793A651L,0x3352BBE6L,0x3E119D3FL,0x3AD08088L,0x2497D08DL,0x2056CD3AL,0x2D15EBE3L,0x29D4F654L,
  36.   0xC5A92679L,0xC1683BCEL,0xCC2B1D17L,0xC8EA00A0L,0xD6AD50A5L,0xD26C4D12L,0xDF2F6BCBL,0xDBEE767CL,
  37.   0xE3A1CBC1L,0xE760D676L,0xEA23F0AFL,0xEEE2ED18L,0xF0A5BD1DL,0xF464A0AAL,0xF9278673L,0xFDE69BC4L,
  38.   0x89B8FD09L,0x8D79E0BEL,0x803AC667L,0x84FBDBD0L,0x9ABC8BD5L,0x9E7D9662L,0x933EB0BBL,0x97FFAD0CL,
  39.   0xAFB010B1L,0xAB710D06L,0xA6322BDFL,0xA2F33668L,0xBCB4666DL,0xB8757BDAL,0xB5365D03L,0xB1F740B4L
  40. };
  41. //CRC单表大表查表算法:
  42. unsigned long GetCRC32L_04C11DB7_FFFFFFFF_00000000_Table(unsigned char *crcBuff, unsigned int crcLen) {
  43. unsigned int i;
  44. unsigned long crc = 0xFFFFFFFF;//初值
  45.   for(i = 0; i < crcLen; i ++){
  46.     crc = (crc << 8) ^ CRC32L_04C11DB7_Table[(crc >> 24) ^ crcBuff[i]];
  47.     crc &= 0xFFFFFFFFL;//请注意此语句为了防止数据溢出,有时可删除,具体看编译环境!
  48.   }
  49.   return crc;
  50. }
  51. int main(){
  52. //数据格式:HEX
  53. const unsigned char dataTable[] = {
  54.   0x01, 0x23, 0x45, 0x67, 0x89, 0xAB, 0xCD, 0xEF
  55. };//特别注意Keil C51请用code替换const
  56. unsigned long crc;
  57.   crc = GetCRC32L_04C11DB7_FFFFFFFF_00000000_Table((unsigned char *)dataTable, sizeof(dataTable));
  58. //表格函数返回crc=0x09EEDE06,与HotWC3运算相同
  59.   while(crc | 1);//死循环,请在此处设置断点,验证函数返回值crc是否正确!!!
  60.   return 0;
  61. }
个人签名:[url=http://www.21ic.com/tools/HotWC3_V1.23.html]
1460
