gd32l23cct6 硬件i2c 等待TI / RBNE标志位超时
4158|11
 楼主| gakiki 发表于 2023-9-21 14:18 | 显示全部楼层 |阅读模式
gd32l23cct6芯片在硬件i2c读写过程中会偶尔出现write函数在TI标志位超时跳出,read函数在RBNE标志位超时跳出,TIMEOUT时间测试200ms+,在这两个标志位超时异常跳出导致i2c通信时序缺少stop位,bsy标志位一直位1,i2c再也无法继续通信,一定要通过复位i2c外设才能解决。硬件i2c驱动代码去下
int gd32_i2c_write(unsigned char bus, unsigned short addr, unsigned char *data, unsigned int data_len)
    drv_i2c_mgr_t *i2c_mgr = NULL;
    unsigned int timeout = DRV_I2C_TIME_OUT;
    unsigned int idx;
    if (bus >= DRV_I2C_BUS_MAX)
        return -1;
    i2c_mgr = &s_st_i2c_mgr[bus];
    if (0 == i2c_mgr->is_init)
        return -1;
    /* wait until I2C bus is idle */
    i2c_master_addressing(i2c_mgr->periph, addr<<1, I2C_MASTER_TRANSMIT);
    i2c_address_config(i2c_mgr->periph, DRV_I2C_OWN_ADDRESS7, I2C_ADDFORMAT_7BITS);
    /* len not include addr byte */
    i2c_transfer_byte_number_config(i2c_mgr->periph, data_len);
    while(i2c_flag_get(i2c_mgr->periph, I2C_FLAG_I2CBSY))
        if ((timeout--) == 0)
            return -1;
    /* send a start condition to I2C bus */
    i2c_start_on_bus(i2c_mgr->periph);
    /* wait until the transmit data buffer is empty */
    I2C_STAT(i2c_mgr->periph) |= I2C_STAT_TBE;
    while(!i2c_flag_get(i2c_mgr->periph, I2C_FLAG_TBE))
            return -1;
    for(idx = 0; idx < data_len; idx++)
        /* data transmission */
        i2c_data_transmit(i2c_mgr->periph, data[idx]);
        while(!i2c_flag_get(i2c_mgr->periph, I2C_FLAG_TI))
                LOG_DIRECT_ERR("ti\r\n");
                return -1;
    while(!i2c_flag_get(i2c_mgr->periph, I2C_FLAG_TC))
            return -1;
    /* send a stop condition to I2C bus */
    i2c_stop_on_bus(i2c_mgr->periph);
    /* wait until stop condition generate */
    while(!i2c_flag_get(i2c_mgr->periph, I2C_FLAG_STPDET))
            return -1;
    /* clear the STPDET bit */
    i2c_flag_clear(i2c_mgr->periph, I2C_FLAG_STPDET);
    return 0;
int gd32_i2c_read(unsigned char bus, unsigned short addr, unsigned char *data, unsigned int data_len)
    unsigned int idx;
        return -1;
        /* I2C init fail ,value invalid */
        return -1;
    i2c_master_addressing(i2c_mgr->periph, addr<<1, I2C_MASTER_RECEIVE);
    i2c_address_config(i2c_mgr->periph, addr<<1, I2C_ADDFORMAT_7BITS);
            return -1;
        /* wait until the RBNE bit is set */
        while(!i2c_flag_get(i2c_mgr->periph, I2C_FLAG_RBNE))
                LOG_DIRECT_ERR("rbne\r\n");
                return -1;
        /* read a data from I2C_DATA */
        data[idx] = i2c_data_receive(i2c_mgr->periph);
            return -1;
            return -1;
    return 0;
 楼主| gakiki 发表于 2023-9-21 17:37 | 显示全部楼层
补充一下:排查问题发现是在TBE标志位等待,异常情况的波形TBE标志位等待延时了20us左右,导致会在TI标志位等待超时跳出。手动在这个地方加了一个20us的延时函数测试验证问题就是出在这里,在TBE后TI前的地方加了一个us级延时函数,i2c必定异常。各位大佬有没有遇到过类似情况的,帮忙看看,谢谢!
tpgf 发表于 2023-10-12 14:03 | 显示全部楼层
为什么iic对时序的要求这么严格呢
八层楼 发表于 2023-10-12 14:32 | 显示全部楼层
为什么iic对时序的要求这么严格呢
而且不知道为啥 用io模拟的iic反而运行起来更顺畅
guanjiaer 发表于 2023-10-12 15:57 | 显示全部楼层
一般是什么原因导致等待这个标志位超时呢
keaibukelian 发表于 2023-10-12 16:16 | 显示全部楼层
iic有没有复位函数呢 如果有的话 当复位后 iic还需要重新进行初始化吗
观海 发表于 2023-10-12 20:12 | 显示全部楼层
主从双方都可以通过重发机制进行保护吗
heimaojingzhang 发表于 2023-10-12 22:33 | 显示全部楼层
是不是可以考虑定时对iic设备进行初始化
1358001518 发表于 2023-10-13 11:36 | 显示全部楼层
老哥能把gd32l23x的cmsis那些文件发一份给我吗 在官网找不到 麻烦您了
cr315 发表于 2024-2-11 18:51 | 显示全部楼层
检查硬件连接
cr315 发表于 2024-2-11 18:52 | 显示全部楼层
I2C的初始化配置、软件配置是否有误
可能是硬件故障
