- /* USER CODE BEGIN Header */
-   * [url=home.php?mod=space&uid=288409]@file[/url]           : main.c
-   * [url=home.php?mod=space&uid=247401]@brief[/url]          : Main program body
-   * @attention
-   * <h2><center>© Copyright (c) 2019 STMicroelectronics.
-   * All rights reserved.</center></h2>
-   * This software component is licensed by ST under Ultimate Liberty license
-   * SLA0044, the "License"; You may not use this file except in compliance with
-   * the License. You may obtain a copy of the License at:
-   *                             www.st.com/SLA0044
- /* USER CODE END Header */
- /* Includes ------------------------------------------------------------------*/
- #include "main.h"
- #include "fatfs.h"
- /* Private includes ----------------------------------------------------------*/
- /* USER CODE BEGIN Includes */
- #include "SDdriver.h"
- /* USER CODE END Includes */
- /* Private typedef -----------------------------------------------------------*/
- /* USER CODE BEGIN PTD */
- /* USER CODE END PTD */
- /* Private define ------------------------------------------------------------*/
- /* USER CODE BEGIN PD */
- /* USER CODE END PD */
- /* Private macro -------------------------------------------------------------*/
- /* USER CODE BEGIN PM */
- /* USER CODE END PM */
- /* Private variables ---------------------------------------------------------*/
- SPI_HandleTypeDef hspi1;
- UART_HandleTypeDef huart1;
- /* USER CODE BEGIN PV */
- /* USER CODE END PV */
- /* Private function prototypes -----------------------------------------------*/
- void SystemClock_Config(void);
- static void MX_GPIO_Init(void);
- static void MX_SPI1_Init(void);
- static void MX_USART1_UART_Init(void);
- /* USER CODE BEGIN PFP */
- /* USER CODE END PFP */
- /* Private user code ---------------------------------------------------------*/
- /* USER CODE BEGIN 0 */
- int fputc(int ch, FILE *f)
-     HAL_UART_Transmit(&huart1, (unsigned char *)&ch, 1, 0xFFFF);
-     return ch;
- uint16_t uart_value[3];
- uint8_t aRxBuffer1;        //uart rx buff
- void WritetoSD(BYTE write_buff[],uint8_t bufSize);
- char SD_FileName[] = "hello.txt";
- uint8_t WriteBuffer[] = "01 窝室嫩叠\r\n";
- //uint8_t test_sd =0;        //用于测试格式化
- uint8_t write_cnt =0;        //写SD卡次数
-         FATFS fs;
-         FIL file;
-         uint8_t res=0;
-         UINT Bw;
-         res = SD_init();                //SD卡初始化
-         if(res == 1)
-                 printf("SD卡初始化失败! \r\n");
-         else
-                 printf("SD卡初始化成功! \r\n");
-         res=f_mount(&fs,"0:",1);                //挂载
- //        if(test_sd == 0)                //用于测试格式化
-         if(res == FR_NO_FILESYSTEM)                //没有文件系统,格式化
- //                test_sd =1;                                //用于测试格式化
-                 printf("没有文件系统! \r\n");
-                 res = f_mkfs("", 0, 0);                //格式化sd卡
-                 if(res == FR_OK)
-                         printf("格式化成功! \r\n");
-                         res = f_mount(NULL,"0:",1);                 //格式化后先取消挂载
-                         res = f_mount(&fs,"0:",1);                        //重新挂载
-                         if(res == FR_OK)
-                                 printf("SD卡已经成功挂载,可以进进行文件写入测试!\r\n");
-                 else
-                         printf("格式化失败! \r\n");
-         else if(res == FR_OK)
-                 printf("挂载成功! \r\n");
-         else
-                 printf("挂载失败! \r\n");
-         res = f_open(&file,SD_FileName,FA_OPEN_ALWAYS |FA_WRITE);
-         if((res & FR_DENIED) == FR_DENIED)
-                 printf("卡存储已满,写入失败!\r\n");
-         f_lseek(&file, f_size(&file));//确保写词写入不会覆盖之前的数据
-         if(res == FR_OK)
-                 printf("打开成功/创建文件成功! \r\n");
-                 res = f_write(&file,write_buff,bufSize,&Bw);                //写数据到SD卡
-                 if(res == FR_OK)
-                         printf("文件写入成功! \r\n");
-                 else
-                         printf("文件写入失败! \r\n");
-         else
-                 printf("打开文件失败!\r\n");
-         f_close(&file);                                                //关闭文件
-         f_mount(NULL,"0:",1);                 //取消挂载
- void Get_SDCard_Capacity(void)
-         FRESULT result;
-         FATFS FS;
-         FATFS *fs;
-         DWORD fre_clust,AvailableSize,UsedSize;
-         uint16_t TotalSpace;
-         uint8_t res;
-         if(res == 1)
-         else
-         /* 挂载 */
-         res=f_mount(&FS,"0:",1);                //挂载
-         if (res != FR_OK)
-                 printf("FileSystem Mounted Failed (%d)\r\n", result);
-         res = f_getfree("0:", &fre_clust, &fs);  /* 根目录 */
-         if ( res == FR_OK )
-                 TotalSpace=(uint16_t)(((fs->n_fatent - 2) * fs->csize ) / 2 /1024);
-                 AvailableSize=(uint16_t)((fre_clust * fs->csize) / 2 /1024);
-                 UsedSize=TotalSpace-AvailableSize;
-                 /* Print free space in unit of MB (assuming 512 bytes/sector) */
-                 printf("\r\n%d MB total drive space.\r\n""%d MB available.\r\n""%d MB  used.\r\n",TotalSpace, AvailableSize,UsedSize);
-         else
-                 printf("Get SDCard Capacity Failed (%d)\r\n", result);
- /* USER CODE END 0 */
-   * @brief  The application entry point.
-   * @retval int
- int main(void)
-   /* USER CODE BEGIN 1 */
-   /* USER CODE END 1 */
-   /* MCU Configuration--------------------------------------------------------*/
-   /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
-   HAL_Init();
-   /* USER CODE BEGIN Init */
-   /* USER CODE END Init */
-   /* Configure the system clock */
-   SystemClock_Config();
-   /* USER CODE BEGIN SysInit */
-   /* USER CODE END SysInit */
-   /* Initialize all configured peripherals */
-   MX_GPIO_Init();
-   MX_SPI1_Init();
-   MX_FATFS_Init();
-   MX_USART1_UART_Init();
-   /* USER CODE BEGIN 2 */
-         HAL_UART_Receive_IT(&huart1,&aRxBuffer1,1);         //enable uart
-         printf(" main \r\n");
-         Get_SDCard_Capacity();        //得到使用内存并选择格式化
-   /* USER CODE END 2 */
-   /* Infinite loop */
-   /* USER CODE BEGIN WHILE */
-   while (1)
-                 WritetoSD(WriteBuffer,sizeof(WriteBuffer));
- //                HAL_Delay(500);
-                 WriteBuffer[0] = WriteBuffer[0] +0;
-                 WriteBuffer[1] = WriteBuffer[1] +1;
-                 write_cnt ++;
-                 while(write_cnt > 5)
-                         printf(" while \r\n");
-                         HAL_Delay(500);
-     /* USER CODE END WHILE */
-     /* USER CODE BEGIN 3 */
-   /* USER CODE END 3 */
-   * @brief System Clock Configuration
-   * @retval None
-   RCC_OscInitTypeDef RCC_OscInitStruct = {0};
-   RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
-   /** Initializes the CPU, AHB and APB busses clocks
-   RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
-   RCC_OscInitStruct.HSIState = RCC_HSI_ON;
-   RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
-   RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
-   RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI_DIV2;
-   RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL16;
-   if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
-     Error_Handler();
-   RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
-                               |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
-   RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
-   RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV2;
-   RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
-   RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
-   if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
-     Error_Handler();
-   * @brief SPI1 Initialization Function
-   * @param None
-   * @retval None
-   /* USER CODE BEGIN SPI1_Init 0 */
-   /* USER CODE END SPI1_Init 0 */
-   /* USER CODE BEGIN SPI1_Init 1 */
-   /* USER CODE END SPI1_Init 1 */
-   /* SPI1 parameter configuration*/
-   hspi1.Instance = SPI1;
-   hspi1.Init.Mode = SPI_MODE_MASTER;
-   hspi1.Init.Direction = SPI_DIRECTION_2LINES;
-   hspi1.Init.DataSize = SPI_DATASIZE_8BIT;
-   hspi1.Init.CLKPolarity = SPI_POLARITY_LOW;
-   hspi1.Init.CLKPhase = SPI_PHASE_1EDGE;
-   hspi1.Init.NSS = SPI_NSS_SOFT;
-   hspi1.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_2;
-   hspi1.Init.FirstBit = SPI_FIRSTBIT_MSB;
-   hspi1.Init.TIMode = SPI_TIMODE_DISABLE;
-   hspi1.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
-   hspi1.Init.CRCPolynomial = 10;
-   if (HAL_SPI_Init(&hspi1) != HAL_OK)
-     Error_Handler();
-   /* USER CODE BEGIN SPI1_Init 2 */
-   /* USER CODE END SPI1_Init 2 */
-   * @brief USART1 Initialization Function
-   * @param None
-   * @retval None
-   /* USER CODE BEGIN USART1_Init 0 */
-   /* USER CODE END USART1_Init 0 */
-   /* USER CODE BEGIN USART1_Init 1 */
-   /* USER CODE END USART1_Init 1 */
-   huart1.Instance = USART1;
-   huart1.Init.BaudRate = 115200;
-   huart1.Init.WordLength = UART_WORDLENGTH_8B;
-   huart1.Init.StopBits = UART_STOPBITS_1;
-   huart1.Init.Parity = UART_PARITY_NONE;
-   huart1.Init.Mode = UART_MODE_TX_RX;
-   huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
-   huart1.Init.OverSampling = UART_OVERSAMPLING_16;
-   if (HAL_UART_Init(&huart1) != HAL_OK)
-     Error_Handler();
-   /* USER CODE BEGIN USART1_Init 2 */
-   /* USER CODE END USART1_Init 2 */
-   * @brief GPIO Initialization Function
-   * @param None
-   * @retval None
-   GPIO_InitTypeDef GPIO_InitStruct = {0};
-   /* GPIO Ports Clock Enable */
-   __HAL_RCC_GPIOA_CLK_ENABLE();
-   /*Configure GPIO pin Output Level */
-   HAL_GPIO_WritePin(SD_CS_GPIO_Port, SD_CS_Pin, GPIO_PIN_RESET);
-   /*Configure GPIO pin : SD_CS_Pin */
-   GPIO_InitStruct.Pin = SD_CS_Pin;
-   GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
-   GPIO_InitStruct.Pull = GPIO_NOPULL;
-   GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
-   HAL_GPIO_Init(SD_CS_GPIO_Port, &GPIO_InitStruct);
- /* USER CODE BEGIN 4 */
- /* USER CODE END 4 */
-   * @brief  This function is executed in case of error occurrence.
-   * @retval None
- void Error_Handler(void)
-   /* USER CODE BEGIN Error_Handler_Debug */
-   /* User can add his own implementation to report the HAL error return state */
-   /* USER CODE END Error_Handler_Debug */
- #ifdef  USE_FULL_ASSERT
-   * @brief  Reports the name of the source file and the source line number
-   *         where the assert_param error has occurred.
-   * @param  file: pointer to the source file name
-   * @param  line: assert_param error line source number
-   * @retval None
- void assert_failed(uint8_t *file, uint32_t line)
-   /* USER CODE BEGIN 6 */
-   /* User can add his own implementation to report the file name and line number,
-      tex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
-   /* USER CODE END 6 */
- #endif /* USE_FULL_ASSERT */
- /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
