代码示例:
- int main(void)
- /* USER CODE BEGIN 1 */
- uint8_t pwm_value=0; //PWM占空比
- /* USER CODE END 1 */
- /* MCU Configuration--------------------------------------------------------*/
- /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
- HAL_Init();
- /* USER CODE BEGIN Init */
- /* USER CODE END Init */
- /* Configure the system clock */
- SystemClock_Config();
- /* USER CODE BEGIN SysInit */
- /* USER CODE END SysInit */
- /* Initialize all configured peripherals */
- MX_GPIO_Init();
- MX_TIM1_Init();
- /* USER CODE BEGIN 2 */
- HAL_TIM_PWM_Start(&htim1,TIM_CHANNEL_1); //使能TIM1的PWM Channel1 输出
- /* USER CODE END 2 */
- /* Infinite loop */
- /* USER CODE BEGIN WHILE */
- while (1)
- /* USER CODE END WHILE */
- /* USER CODE BEGIN 3 */
- while (pwm_value < 500)
- pwm_value++;
- __HAL_TIM_SetCompare(&htim1, TIM_CHANNEL_1, pwm_value); //修改比较值,修改占空比
- // TIM1->CCR1 = pwm_value; //与上方作用相同,直接修改寄存器
- HAL_Delay(1);
- while (pwm_value)
- pwm_value--;
- // TIM1->CCR1 = pwmVal; //与上方作用相同,直接修改寄存器
- HAL_Delay(1);
- HAL_Delay(200);
- /* USER CODE END 3 */
