全志R128蓝牙占用内存资源较大,修改menuconfig配置后经常编译不过或无法运行解决方法
415|0
 楼主| 神棍地海棠 发表于 2023-11-1 09:58 | 显示全部楼层 |阅读模式
R128蓝牙占用内存资源较大,尝试修改过以下两处的蓝牙配置,修改后再重新编译就会失败
1、使用menuconfig修改配置CONFIG_BT_VAR_MEM_DYNC_ALLOC=y,后初始化蓝牙失败
[cmd ERR] bt_ready():556, Bluetooth init failed (err -105)
添加打印定位到是内存分配失败
2、使用menuconfig修改配置CONFIG_BT_SMP关闭可以减少很多内存,但是编译出错,提示缺少smp_null.c。
CONFIG_BT_VAR_MEM_DYNC_ALLOC配置问题,修改方法如下。,即交换
_net_buf_pool_list_end = .;
KEEP(*(SORT_BY_NAME("._net_buf_pool.static.*")))
这两行
diff --git a/include/ble/linker/common-ram.ld b/include/ble/linker/common-ram.ldindex e97433c91..40744e392 100755--- a/include/ble/linker/common-ram.ld+++ b/include/ble/linker/common-ram.ld@@ -84,8 +84,8 @@        {                _net_buf_pool_list_start = .;                _net_buf_pool_list = .;                KEEP(*(SORT_BY_NAME("._net_buf_pool.static.*")))                _net_buf_pool_list_end = .;        } GROUP_DATA_LINK_IN(RAMABLE_REGION, ROMABLE_REGION)
CONFIG_BT_SMP 配置问题,下面内容保存为smp_null.c 放到
./src/ble/host/smp_null.c/** * @file smp_null.c * Security Manager Protocol stub *//* * Copyright (c) 2015-2016 Intel Corporation * * SPDX-License-Identifier: Apache-2.0 */#include <zephyr.h>#include <errno.h>#include <ble/sys/atomic.h>#include <ble/sys/util.h>#include <bluetooth/bluetooth.h>#include <bluetooth/conn.h>#include <bluetooth/buf.h>#define BT_DBG_ENABLED IS_ENABLED(CONFIG_BT_DEBUG_HCI_CORE)#define LOG_MODULE_NAME bt_smp#include "common/log.h"#include "hci_core.h"#include "conn_internal.h"#include "l2cap_internal.h"#include "smp.h"static struct bt_l2cap_le_chan bt_smp_pool[CONFIG_BT_MAX_CONN];int bt_smp_sign_verify(struct bt_conn *conn, struct net_buf *buf){        return -ENOTSUP;}int bt_smp_sign(struct bt_conn *conn, struct net_buf *buf){        return -ENOTSUP;}static int bt_smp_recv(struct bt_l2cap_chan *chan, struct net_buf *req_buf){        struct bt_conn *conn = chan->conn;        struct bt_smp_pairing_fail *rsp;        struct bt_smp_hdr *hdr;        struct net_buf *buf;        ARG_UNUSED(req_buf);        /* If a device does not support pairing then it shall respond with         * a Pairing Failed command with the reason set to "Pairing Not         * Supported" when any command is received.         * Core Specification Vol. 3, Part H, 3.3         */        buf = bt_l2cap_create_pdu(NULL, 0);        /* NULL is not a possible return due to K_FOREVER */        hdr = net_buf_add(buf, sizeof(*hdr));        hdr->code = BT_SMP_CMD_PAIRING_FAIL;        rsp = net_buf_add(buf, sizeof(*rsp));        rsp->reason = BT_SMP_ERR_PAIRING_NOTSUPP;        if (bt_l2cap_send_cb(conn, BT_L2CAP_CID_SMP, buf, NULL, NULL)) {                net_buf_unref(buf);        }        return 0;}static int bt_smp_accept(struct bt_conn *conn, struct bt_l2cap_chan **chan){        int i;        static const struct bt_l2cap_chan_ops ops = {                .recv = bt_smp_recv,        };        BT_DBG("conn %p handle %u", conn, conn->handle);        for (i = 0; i < ARRAY_SIZE(bt_smp_pool); i++) {                struct bt_l2cap_le_chan *smp = &bt_smp_pool;                if (smp->chan.conn) {                        continue;                }                smp->chan.ops = &ops;                *chan = &smp->chan;                return 0;        }        BT_ERR("No available SMP context for conn %p", conn);        return -ENOMEM;}BT_L2CAP_CHANNEL_DEFINE(smp_fixed_chan, BT_L2CAP_CID_SMP, bt_smp_accept, NULL);int bt_smp_init(void){        return 0;}#if defined(CONFIG_BT_DEINIT)int bt_smp_deinit(void){        return 0;}void bt_smp_mem_deinit(void){        return;}void bt_keys_mem_deinit(void){    return;}#endif#if defined(CONFIG_BT_VAR_MEM_DYNC_ALLOC)void keys_dynamic_mem_alloc(void){}void keys_dynamic_mem_free(void){}#endif
回复 引用
