AT32f323电池供电数据寄存器ERTC_BPRx半字操作不成功
560|0
gaolf_2000|  楼主 | 2023-11-2 11:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
参照库里面的
void ertc_bpr_data_write(ertc_dt_type dt, uint32_t data)
  __IO uint32_t reg = 0;
  reg = ERTC_BASE + 0x50 + (dt * 4);
  *(__IO uint32_t *)reg = data;
uint32_t ertc_bpr_data_read(ertc_dt_type dt)
  return (*(__IO uint32_t *)reg);
写的:
void ertc_bpr_16bitdata_write(uint16_t dt, uint16_t data)
    __IO uint16_t reg = 0;
    reg = ERTC_BASE + 0x50 + (dt * 2);
    *(__IO uint16_t *)reg = data;
uint16_t ertc_bpr_16bitdata_read(uint16_t dt)
    return (*(__IO uint16_t *)reg);
时钟使能了,访问也使能了,但还是写不进去,读出来都是0xffff,不明白原因
   crm_periph_clock_enable(CRM_PWC_PERIPH_CLOCK, TRUE);
    pwc_battery_powered_domain_access(TRUE);
