CY7C68013A GPIF通信读数据的问题
7973|2
 楼主| xlu0706 发表于 2012-5-9 11:25 | 显示全部楼层 |阅读模式
FPGA循环16进制数向CY7C68013A 发送数据,在MASTER端以GPIF方式读取数据,其读数据函数是:
void GPIF_SingleWordRead( WORD xdata *gdata )
  static BYTE g_data = 0x00;     // dummy variable
  while( !( GPIFTRIG & 0x80 ) )  // poll GPIFTRIG.7 Done bit
  // using register in XDATA space
  g_data = XGPIFSGLDATLX;        // dummy read to trigger GPIF
                                 // Single Word Read transaction
  // using register(s) in XDATA space, retrieve word just read from ext. FIFO
  *gdata = ( ( WORD )XGPIFSGLDATLNOX << 8 ) | ( WORD )XGPIFSGLDATH;
  //*gdata = ( ( WORD )XGPIFSGLDATH << 8 ) | ( WORD )XGPIFSGLDATLNOX;
在poll函数中循环取数据:
if(in_enable) // if IN transfers are enabled,
    if(!(EP2468STAT & bmEP6FULL) && (EXTFIFONOTEMPTY))
      // if EP6IN is not full AND there is data in the external FIFO,
      Destination = (WORD *)(&EP6FIFOBUF);
      for( i = 0x0000; i < Tcount; i++ )
        // transfer data from external FIFO to EP6IN buffer
        GPIF_SingleWordRead (Destination);
        Destination++;
   Tcount *= 2;          // multiply by 2 to obtain byte count value
      EP6BCH = MSB(Tcount);
      SYNCDELAY;
      EP6BCL = LSB(Tcount); // arm EP6IN to send data to the host
      SYNCDELAY;
自己写了个应用程序从pc端读取usb数据,发现读取的数据全都是0,那位大侠能给我分析一下,万分感谢!
 楼主| xlu0706 发表于 2012-5-10 09:51 | 显示全部楼层
求人不如求己呀,还好经过痛苦的历程还是有办法了
szjlj168 发表于 2012-11-19 16:39 | 显示全部楼层
:D 有道理哟 2# xlu0706
