IPQ8074- Reinventing the wireless world - Faster, stronger and more stable connectivity
Wireless networks have become an indispensable part of our lives. To make our daily life more convenient and efficient, we need advanced wireless network technology to support. IPQ8074 is an outstanding representative in this field, it not only meets the needs of modern people for high-speed, stable and reliable network connections, but also has a number of powerful technical features, bringing unlimited possibilities for future wireless networks.
The IPQ8074 is a high-performance network processor from Qualcomm that is designed to solve the challenges of today's wireless networks. Its technical characteristics can be described by the following keywords: high performance, high integration, versatility, scalability and security.
High performance:
The IPQ8074 features Qualcomm's latest technology and supports total throughput of up to 10.8 Gbps, making it ideal for handling multiple devices, multimedia streaming, and large file transfers. Whether in a home network or an enterprise network environment, the IPQ8074 delivers superior performance to ensure that your network experience is smoother.
Highly integrated:
The IPQ8074 has a number of built-in functional units, including a multi-core CPU, hardware acceleration engine and security subsystem, and the high integration of these components makes it not only excellent performance, but also better able to meet the needs of a variety of applications. This high level of integration not only improves performance, but also reduces power consumption and extends the service life of the device.
Versatility:
Whether you need to set up a home network, an enterprise network or a smart city infrastructure, the IPQ8074 has you covered. It supports multiple communication protocols, including 802.11ax, 802.11ac, 802.11ad and 802.11ah, as well as 4G and 5G connections. This versatility makes it ideal for a variety of application scenarios.
Scalability:
As network demands continue to increase, scalability becomes critical. The IPQ8074 is designed with this in mind, supporting the convergence of multiple wireless technologies, as well as easy scaling and upgrading. This enables network administrators to better respond to future challenges and keep the network advanced.
Security:
Cybersecurity has always been an important topic, and the IPQ8074 excelled at this. It integrates Qualcomm's cybersecurity technologies, including WPA3 encryption and threat detection, to protect your network from potential threats. Whether you are a home user or an enterprise customer, the IPQ8074 provides reliable network security performance.
The IPQ8074 supports a variety of WiFi cards and covers multiple frequency bands. The supported WiFi bands and standards may vary depending on the specific implementation and product, but in general, the IPQ8074 can support the following WiFi bands:
2.4GHz band: The IPQ8074 supports 802.11b/g/n and 802.11ax (Wi-Fi 6) standards, which operate in the 2.4GHz band to provide a wider range of wireless connectivity. The 2.4GHz band performs well for low bandwidth and long distance transmission.
5GHz band: The IPQ8074 also supports the 802.11a/n/ac and 802.11ax standards, which operate in the 5GHz band and provide higher bandwidth and faster speeds. The 5GHz band is typically used to provide high quality video streaming and online gaming for demanding applications.
60GHz band: The IPQ8074 also supports the 802.11ad standard, a WiFi technology that operates in the 60GHz band, also known as WiGig. The 60GHz band offers extremely high speeds and is suitable for high-volume data transfers, such as high-definition video transmissions and high-speed data transfers between wirelessly connected devices.
900MHz band: The IPQ8074 also supports the 802.11ah standard, a WiFi technology that operates in the 900MHz band and is typically used for low-power, long-distance Internet of Things (IoT) device connectivity.
