关于STM32 PWM捕获模式
2009|0
 楼主| wxxsnowman 发表于 2012-5-9 19:37 | 显示全部楼层 |阅读模式
/* Time base configuration */
    TIM_TimeBaseStructure.TIM_Period = 65535;
   TIM_TimeBaseStructure.TIM_Prescaler = 0;
   TIM_TimeBaseStructure.TIM_ClockDivision = 0;
    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
   TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
TIM_ICInitStructure.TIM_Channel = TIM_Channel_2;
    TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;
    TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
    TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;
   TIM_ICInitStructure.TIM_ICFilter = 0x0;
   TIM_ICInit(TIM3, &TIM_ICInitStructure);
  TIM_PWMIConfig(TIM3, &TIM_ICInitStructure);                 //根据参数配置TIM外设信息
    TIM_SelectInputTrigger(TIM3, TIM_TS_TI2FP2);                //选择IC2为始终触发源
     TIM_SelectSlaveMode(TIM3, TIM_SlaveMode_Reset);//TIM从模式:触发信号的上升沿重新初始化计数器和触发寄存器的更新事件
     TIM_SelectMasterSlaveMode(TIM3, TIM_MasterSlaveMode_Enable); //启动定时器的被动触发
/* PWM1 Mode configuration: Channel3 */
   TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
   TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
   TIM_OCInitStructure.TIM_Pulse = CCR3_Val;
   TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
   TIM_OC1Init(TIM3, &TIM_OCInitStructure);
   TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable);
TIM_ARRPreloadConfig(TIM3, ENABLE);
   /* TIM3 enable counter */
   TIM_Cmd(TIM3, ENABLE);
  /* Enable the CC2 Interrupt Request */
     TIM_ITConfig(TIM3, TIM_IT_CC2, ENABLE);
void TIM3_IRQHandler(void)
if(TIM_GetITStatus(TIM3, TIM_IT_CC2) == SET)
     /* Clear TIM3 Capture compare interrupt pending bit */
     TIM_ClearITPendingBit(TIM3, TIM_IT_CC2);
     if(CaptureNumber == 0)
      USART_SendData(USART1, TIM3 -> CNT);
   while(USART_GetFlagStatus(USART1, USART_FLAG_TC)==RESET);
        /* Get the Input Capture value */
        IC3ReadValue1 = TIM_GetCapture2(TIM3);
      USART_SendData(USART1, IC3ReadValue1);
   TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Falling;
        CaptureNumber = 1;
     else if(CaptureNumber == 1)
        IC3ReadValue2 = TIM_GetCapture1(TIM3);
   CaptureNumber = 2;
  else if(CaptureNumber == 2)
   IC3ReadValue3 = TIM_GetCapture2(TIM3);
        /* Capture computation */
        if (IC3ReadValue3 > IC3ReadValue1)
          Capture = (IC3ReadValue3 - IC3ReadValue1);
        else
          Capture = ((0xFFFF - IC3ReadValue1) + IC3ReadValue3);
        /* Frequency computation */
   capture = (IC3ReadValue2 - IC3ReadValue1)*100/ Capture;
        //TIM3Freq = (u32) 72000000 / Capture;
        CaptureNumber = 0;
以上是我的捕获代码,但是每次从IC3ReadValue3、IC3ReadValue1这两个值都是3,不知道是怎么回事
