[N32G430] CAN相关问题
1221|8
 楼主| 春风知意 发表于 2023-11-20 11:23 | 显示全部楼层 |阅读模式
配置如下:
*\*\name   CAN_CONFIG
*\*\fun    CAN configure.
*\*\param  none
*\*\return none
void CAN_CONFIG(void)
    RCC_APB1_Peripheral_Clock_Enable(RCC_APB1_PERIPH_CAN);
    /* Initializes CAN*/
    CAN_NVIC_Configuration();
    CAN_GPIO_Configuration();
    CAN_Reset(CAN);
    CAN_Structure_Initializes(&CAN_InitStructure);
    /* CAN cell init */
    CAN_InitStructure.TTCM          = DISABLE;
    CAN_InitStructure.ABOM          = DISABLE;
    CAN_InitStructure.AWKUM         = DISABLE;
    CAN_InitStructure.NART          = DISABLE;
    CAN_InitStructure.RFLM          = DISABLE;
    CAN_InitStructure.TXFP          = ENABLE;
    CAN_InitStructure.OperatingMode = CAN_NORMAL_MODE;
    /* Baud rate calculation = CAN clock/(BaudRatePrescaler*(TBS1+TBS2+1)) */
    CAN_InitStructure.RSJW          = CAN_RSJW_1TQ;
    CAN_InitStructure.TBS1          = CAN_TBS1_8TQ;
    CAN_InitStructure.TBS2          = CAN_TBS2_7TQ;
    CAN_InitStructure.BaudRatePrescaler = 4;
    /*Initializes the CAN */
    CAN_Initializes(CAN, &CAN_InitStructure);
    /* CAN filter init */
    CAN_FilterInitStructure.Filter_Num            = 0;
    CAN_FilterInitStructure.Filter_Mode           = CAN_FILTER_IDLISTMODE;
    CAN_FilterInitStructure.Filter_Scale          = CAN_FILTER_32BITSCALE;
    CAN_FilterInitStructure.Filter_HighId         = CAN_STD_ID_LIST_32BIT_H(0x00000400);
    CAN_FilterInitStructure.Filter_LowId          = CAN_STD_ID_LIST_32BIT_L(0x00000400);
    CAN_FilterInitStructure.FilterMask_HighId     = CAN_STD_ID_LIST_32BIT_H(0x00000200);
    CAN_FilterInitStructure.FilterMask_LowId      = CAN_STD_ID_LIST_32BIT_L(0x00000200);
    CAN_FilterInitStructure.Filter_FIFOAssignment = CAN_FIFO0;
    CAN_FilterInitStructure.Filter_Act            = ENABLE;
    CAN_Filter_Initializes(&CAN_FilterInitStructure);
    /* IT Configuration for CAN */
    CAN_Config_Interrupt_Enable(CAN, CAN_INT_FMP0);
*\*\name   CAN_NVIC_Configuration
*\*\fun    CAN NVIC configure.
*\*\param  none
*\*\return none
void CAN_NVIC_Configuration(void)
    NVIC_InitType NVIC_InitStructure;
    /* NVIC priority group set */
    NVIC_Priority_Group_Set(NVIC_PER2_SUB2_PRIORITYGROUP);
    /* NVIC configure */
    NVIC_InitStructure.NVIC_IRQChannel                   = CAN_RX0_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority        = 0x1;
    NVIC_InitStructure.NVIC_IRQChannelCmd                = ENABLE;
    NVIC_Initializes(&NVIC_InitStructure);
*\*\name   CAN_GPIO_Configuration
*\*\fun    CAN GPIO configure.
*\*\param  none
*\*\return none
void CAN_GPIO_Configuration(void)
   GPIO_InitType GPIO_InitStructure;
   /* Initializes the GPIO */
   GPIO_Structure_Initialize(&GPIO_InitStructure);
   /* configure CAN pin */
   RCC_AHB_Peripheral_Clock_Enable(RCC_AHB_PERIPH_GPIOB);
   RCC_APB2_Peripheral_Clock_Enable(RCC_APB2_PERIPH_AFIO);
   GPIO_InitStructure.Pin            = GPIO_PIN_6;
   GPIO_InitStructure.GPIO_Mode      = GPIO_MODE_AF_PP;
   GPIO_InitStructure.GPIO_Alternate = GPIO_AF11_CAN;
   GPIO_Peripheral_Initialize(GPIOB, &GPIO_InitStructure);
   GPIO_InitStructure.Pin             = GPIO_PIN_7;
} 用的都是官方例程,只是把引脚修改了下,没办法通信,麻烦帮忙看下,谢谢。
 楼主| 春风知意 发表于 2023-11-20 11:24 | 显示全部楼层
修改成回环可以测到tx,rx波形,正常模式波形都没办法测到。
flyfish79 发表于 2023-11-20 12:05 | 显示全部楼层
收发器有没有接。没有收发器的话,RX要接高电平才能检测到空闲,初始化工作。
找到问题,收发器芯片出问题导致的,谢谢回答  发表于 2023-11-20 13:16
长的帅怪我落 发表于 2023-11-20 22:30 | 显示全部楼层
这个单片机不知道,但是之前GD32的IO管脚有个重映射什么的需要设置,就是复用那里看一下手册
skg65874200 发表于 2023-11-21 11:13 | 显示全部楼层
提供技术支持:V:18151082510
储小勇_526 发表于 2023-11-21 11:22 | 显示全部楼层
最近也一直在搞CAN,不过还好有cubeMX和CANOpen协议栈,轻松许多,不过移植的时候别人给的代码被封装成lib,在他基础上只能手动添加代码,最后遇到的问题时中断HAL库没初始化,头疼。
可口可口 发表于 2023-11-22 20:41 | 显示全部楼层
这个N32有点不一样,有些复用接口又不需要开启复用时钟,有些要开启,这个can在官方例程中就开启了,而在usart上又没有开启,用户手册上也没找到关于复用时钟的具体说明。看楼主的代码是没有开启复用时钟。(补,看到帖子最后发现也开启了复用时钟)
GHenry 发表于 2024-12-1 04:35 | 显示全部楼层
正常模式为啥测不了啊
